Question about Logitech X-530 Computer Speakers
I bought these x 240 speakers used. do i need a driver to run them? where do i connect the plugs, black and green?
  • 700 Answers
These are "decent" quality 5.1 speakers, new were on about $100.00 to $150.00, have two years warranty from time of purchase.
Now, to your question, you will not have 5.1 "surround sound" effect with standard sound card, standard sound card will provide only three speakers sound, rear speakers will not connect.
Connect speakers as follows:
1. Audio from PC, orange, green and black connecting to front right speaker.
2. DB15 (D-SUB) connecting to subwoofer, subwoofer is serving as mixer, power board, amplifier and connection box
3. White plug is connecting to front left speaker
4. Red is connecting to front centre speaker
5. Black is connecting right rear speaker
6. Yellow is connecting left rar speaker.
Establish location of the speakers, from experience in ideal world:
1. Sub should be on about your knee level or below,
2. Front centre speaker should be about twice your hight distance from you, on front and slightly above your head.
3. Front left and right speakers should be at about 45degree from your axis, at distance of about 1.5 your hight and on the level of your head or slightly below.
4. Rear left and right speakers should be located similiary to front speakers, on they level or slightly above them, again, about 45degree from your axis.
Location of the speakers is more actually important than it is assumed, total sound immersion is not possible without proper speakers installation. Head in these instruction meant a location of your head while you are listening to your music or recording not whil eyou are standing.
In reality... hang them higher than your head in four corners of your room, front centre higher than sides, woofer lower than sides and below front centre, if they interfere with each other - increase the distance. I hate reality...
After speakers are connected:
1. Plug power cord in,
2. Turn all sounds totally down, including subwoofer
3. Increase sound on PC to maximum, let play any known to you music, tufftuff or bach, whatever, do not bother with metallica as you cannot discredit on it correct levels.
4. Increase subwoofer volume, holding one hand on the front of the grill till you get some vibration from it
5. Increase sound on centre button of the right fron speaker till you achieve equality of the sound
6. Decrease sound volume on your PC to about 60% - 70%
7. Increse subwoofer volume till you feel sound on your hand in front of the speaker.
8. Increase sound volume on front/rear speakers as required.
Hope that short intro solved all your speaker problems, enjoy! if you require any additional help, do not hesitate to answer to this post with request.
Posted on Aug 06, 2010
Logitech Z506 Speakers
Go into the Control Panel and identify the sound card. Make sure you have the most up to date drivers and also software if there is a software package. Deep into Sound Card Properties there is a setting that asks what the Profile of your Sound Speakers, twin at front, 2 plus 1 Bass, or Surround Sound, Theatre System etc. I think your answer is in there.
Also in Sounds, you can assign sounds to Programs. Or, from the QuickBooks program, assign the sound card.
Nov 29, 2017 | Logitech Audio Players & Recorders
I have a new heater with diferant terminals from the old one so not sure how to atach the wires
There is no need to rewire the internal of the heater!
Just bring in the electrical supply to the heater, it can be either 120 or 240 volts.
If the heater you have is like the picture associated with your post, then all then have to do is change the supplied plug from 240 to 120. It comes pre set for 240. That plug is inside the cabinet.
If any other brand, then you need to change the wires at the transformer of the heater. All heaters need to be supplied with primary voltage: 120 or 240. Then the control system is supplied with secondary voltage out of the transformer. The secondary voltage is no more than 28 volts. and these wires are normally colored as blue or yellow.
Secondary power is already wired within the heater. NO need to change where they are. You will only need to deal with the Primary wiring.
There are many varieties of transformers that transform high primary voltage to a low secondary voltage of 28 volts. and these transformers have many wires: primary & secondary.
I will try to make this easy to understand.
If you have a Gas Heater Transformer with these colors:
  • Red
  • Black
  • White
  • Green
Or...
  • Red
  • White with Red Stripe
  • Black
  • White with Black Stripe
  • Green
These are Dual Voltage Transformers, you can bring in either 120 Volts or 240 Volts
If you bring in only 120 Volts...
1st example:
The Red wire will not be used! Hot wire to the Black, and the Neutral/Common, to the white wire. Green to ground.
2nd example:
Connect the Red wire with the White with Red Stripe together and connect these to the incoming Neutral/Common wire, normally White.
Connect the Black Wire with the White with Black Stripe to your incoming Hot Wire, which is normally Black.
Green to ground
If you bring in 240 Volts...
1st example.
1 Hot wire to the Red, the Other Hot wire to the Black, and White wire is not used. Green to ground
2nd Example:
Wire nut the two Striped wires together. then one incoming Hot wire to the Black, the other incoming Hot wire to Red.
Green to ground
Or This is only a Low voltage - 120 Volts Only
  • Black
  • White
  • Green
Or either any of these combinations...
  • 2 Blacks w/Green
  • 2 Reds w/Green
  • 1 Black, 1 Red w/green
This type will only be a high voltage, 240 volts only
Picture below is what a transformer looks like and it is where your incoming supply wires go. The smaller leads with the spade connections will go to a specific location & is the 'Secondary" .
Good Luck
Mar 14, 2015 | Pool & Spa
Hi .. i have just bought a logitech x 530 speaker and only 2 of the speaker parts work .. can you please give me some solution advice?
Hi names Rui i like to help you by giving you step by step instruction in propely hocking up your logitech speakers:
Instructions
1. Connect the black plug of the rear right speaker into the black plug on the subwoofer.
2. Connect the yellow plug on the rear left speaker into the yellow input on the subwoofer.
3. Connect the red plug of the front center speaker into the red input on the subwoofer.
4. Connect the white plug of the front left speaker into the white input on the subwoofer.
5. Connect the d-sub connector plug from the front right speaker into the d-plug connector on the subwoofer.
6. Connect the green, black and orange input to the matching plugs on your computer. If you have a four-channel sound card, connect the green plug from the input audio cable to the front plug of the card and the black plug to the rear plug. Do not connect the orange input. If you are using a two-channel sound card, connect the green plug from the input audio cable to the "Line Out" jack on the sound card. Do not connect the green and orange plug.
7. Plug the subwoofer power chord into the electrical power outlet.
8. Place your subwoofer on ground around your computer desk. Position the front center speaker on top of your computer monitor.
9. Place the left and right front speakers on the sides of the monitor. Position the left and right rear speakers behind you, making sure they are pointing toward the front left and right speakers.
10. needs to support 5.1 surround. Normally, more than three sockets for sound indicates that it does. Then you need to use the software that comes with the sound hardware to configure it for 5.1 - Default will be 2.1 or just 2.
Check the control panel out. This is a lot easier under Windows 7.- Here you can access what you need via the speaker icon on the system tray (right click)
There is NO problem with your OS or hardware, this is pretty standard...
hope this will help you solve your problem.
Jul 18, 2011 | Logitech X-530 Computer Speakers
My speakers X-240 speakers just stopped working
there could be a number of problems here ,bad connection at jack going into computer ,or jack could be faulty try and move around wire at jack entering the pc i presume these are plug in 240v check there is power running to them if there is try them on another computer and see will they work ,you might have to down load sound drivers aswell above all check connections first goodluck
Mar 19, 2011 | Logitech X-240 Computer Speakers
I cannot get any sound from my speakers or the monitor speakers. I have plugged the green cable to the monitor and to the green connector on the tower with no luck. I have also plugged the extra speaker...
It sound like you have connected them correctly however unless they are multi-channel speakers you should only have to connect the green cable. Check to see if the volume control on your speakers/monitor and also OS are turned up and not on mute and also check to see that you have sound drivers installed for your sound device/card.
Oct 23, 2010 | Acer Aopen MS698 Computer Speakers
How do i connect new speakers to my HP2009 PC?
Plug 1/8th plug (green or black) from speakers into the green jack on pc.
Jun 29, 2009 | HP (ZD929AA) Computer Speakers
Need the speaker wiring diagram for Pioneer KEH-1080
Yellow = +12V constant; Red = +12V switched; Black = ground; Blue-white = remote on; White/White-black = FL speaker; Grey/Grey-black = FR speaker; Green/Green-black = RL speaker; Violet/Violet-black = RR speaker.
--- hope that helps ya
May 20, 2009 | Pioneer Car Audio & Video
I have logitech X 240 i need to hook them back to my pc, i cant figure it out, it either vibrates or a tone sound..."HELP""""
Hi. Did you plug in the subwoofer/control to the Green Slot on the back of your pc ? (should be green wire connected in the green slot)
Then you connect the 2 speakers in the back of the woofer. you will see a little slot with the label Speakers next to it.
Hope this helps, if this is not what you have already tried.
Dec 30, 2008 | Logitech X-240 Computer Speakers
X-240 subwoofer not working.
plug the double head phone thing (about 3 inch long ,included) in to your computer and other end in the ipod dock slot ( with the musical note NOT the head phone slot) and plug speakers plug (black NOT green) into back of subwoofer and plug in to power and maker sure volume on computer also you might want to reset or log of the computer somtines music doesnt play (i.e itunes) and enjoy music also i have a macbook im not sure if its same with windows but it should work
Dec 27, 2008 | Logitech X-240 Computer Speakers
Need instalation instructions
Usually the speaker setup is easy, connecting with the manual all the respective cables, and the black , green, orange, to the back out to the Sound card. if you have of course I presume a 5.1 sound card. if not, just use the green cable to the green on the sound card, and black according.
you have to connect the SUB alone and send the green and black signals to the port on the sound card.
good luck
Nov 14, 2007 | Audio Players & Recorders
Logitech X-530 Computer Speakers Logo
156 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
