I hooked up my cold and hot but there are two more tubes that are disconnected and I don't know where to connect them... please help
    Genius:
  • 1,028 Answers
Are they the size of drain lines if so you may a suds saver version better ck owners manual
Posted on Apr 27, 2008
Hot water keeps running hot and old
Fastjet,
I can't understand what you are asking...
Please clarify via a comment.
perhaps a leak?
Jan 09, 2015 | Water Water Heaters
Have a Dishlex Global 500. Can this be connected to cold water only & if so do we just not connect the hot water hose? Thanks, Kyle
yea, don't connect the hot water, but if it has an automatic hot cycle, you will have to hook up the hot WATER
May 01, 2011 | Dishwashers
USING PERKO SWITCH HOW DO I POSITION SWITCH USING 120 VOLT AC CHARGER USING 2 MARINE BATTERIES AND WHAT TERMINALS ON BATTERIES DO I HOOK UP ALLIGATOR CHARGING CLIPS? THANK YOU DON
Hi Don!
If you wish to charge one battery at a time, the switch should be set to "off". Charger clips will connected to the batt you wish to charge hot-to-hot and cold-to-cold. If you want to charge both batts at once (not really recommended) switch set to "all".
Hope this helps.
Mar 26, 2011 | Perko Battery Selector Switches Ignition...
How does rhe hot and cold water hook up on a 71-40d which is which top and bottom
Tanks are marked with Hot and Cold.
1) If water connections are on top of tank, look for red marking or word HOT that shows where hot water pipe connects. Look for blue marking or word COLD that shows cold water connection.
2) If water connections are on side of tank, cold water connects to bottom one, and hot connects to top.
3) If hot and cold are reversed, the tank will not work.
Pipes on top of tank: cold water enters tank and is sent to bottom of tank in a long tube called the dip tube. This means the cold is on the bottom since hot water rises to the top. The hot water exits top of tank.
Pipes on side of tank: You want cold water to enter bottom, so hot water naturally rises to the top outlet.
Nov 14, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Not enough hot water to complete shower. Noticed
If it is a new water heater it might be that the water supplies are crossed. The cold water should be installed on the right hand side of the tank or on the bottom if your tank hooks up on the side. If its an older water heater the dip tube may have broken off. This is a tube that runs from the top of your water heater on the cold side to the lower portion of the tank.It puts the cold water in the bottom of the heater which pushes the hot water to the top.To change the dip tube out you must disconnect the cold water supply from the 3/4 inch nipple at the top of the tank. Then with a pipe wrench unscrew the nipple from the tank it will have the remainder of the tube on it.You can get a replacement dip tube at a plumming supply. Installation is opposite of removal. If this is your problem I suggest you get a new water heater .Usually its caused from minnerals in the water or buy two dissimiler metals being connected together in the water piping system causing corrosion Your water heater will probably fail in the near future.
Dec 15, 2009 | Water Heaters
Faucet connector
If I am reading this correctly you want to connect washer to the faucet inputs. This requires washer hose kit at any hardware store. Kit has two hoses,<simular to garden hose> they have double end that will connect to both washer and faucet.Make sure when hooking up you hook cold to cold and hot to hot,< washer has C and H to know which is which.
Apr 25, 2009 | Washing Machines
Warm water out of water dispenser
If this is a new hook-up please be sure that your water line is connected to the cold plumbing on the house and not the hot.
IF it is on the hot the fridge is cooling it down to warm.
Please let me know if this helps you.
Jan 06, 2009 | Whirlpool Refrigerators
Water supply
Hi Don,
Cold water supply at Fridge location. Run 1/4" tubing and connectors to match the supply valve and solenoid valve on the Fridge. Should be just one tubing connection.
If you do not have a supply at your Fridge, you can shut off your main supply and tap into the cold water line and run you a supply over to the fridge. use 1/2" PVC pipe and fittings to route over to the fridge. Get a Threaded adapter to connect a shutoff Valve. This way you have a way to keep the main supply on and hook up the Tubing from the fridge to the supply.
Nov 28, 2007 | Admiral 26 cu. ft. Side-By-Side...
Washing Machines Logo
Top Washing Machines Experts
