Question about Alpine CDA-9805 CD Player
My cda-9805 unit quit working after changing out my car battery. When I remove the face and hit the reset button, I hear it cycle through the CD mechanism but when I attach the face, the unit will not turn on. It looks as if there is no power but I know there is by hearing the CD mech after the reset.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Alpine Master
  • 2,226 Answers
Did ;you check all your fuses? it sounds like you may not have power going to the red (ignition) wire.
Posted on Aug 06, 2010
What's your problemI bought a used car that has an alpine cda 9805 radio. It has an auxillary cable that appears can hook up to my I pod nano. I can't find the function/ mode on the radio to g
The source/power button in the top left corner changes the mode. Press the button until the aux appears. The auxillary device must be plugged in to register on the stereo.
Aug 19, 2012 | Alpine CDA-9805 CD Player
I have a CDA-9855 Alpine head unit. It worked just fine when removed from my prior vehicle (05 VW Golf). I just installed it in an 01 Land Rover Discovery II using a wiring harness adapter so no cutting or...
it sounds like you have the blue wire (antenna remote turn on) instead of the blue/white wire (amplifier remote turn on) turning on an external amplifier in your rover. the antenna remote wire turns off when you leave tuner mode.
Jan 26, 2011 | Alpine CDA-9855 CD Player
Intermittent power to head unit
no inline fuse? I usually just slip the wire inside the battery connector, remove connector lay wire across battery with stripped end running up the side of the battery terminal place connector down on terminal and wire, tighten connector back up.
Feb 21, 2010 | Alpine CDA-9805 CD Player
My display stays on for about 3 seconds then it turns off until
If this model has a detachable faceplate,
Remove the faceplate and clean down the contacts with metho and a cotton bud.
Over time usually corrosion and dirt etc builds up on these terminals making them loose cotact when you touch the faceplate.
This is the most commonly known problem alpine units.
Other common problems is the power supply failing /amplifier.
Hope this helps you out
Cheers
Steve
Apr 02, 2009 | Alpine CDA-9805 CD Player
Alpine CDA-7865R won't play CD and won't eject it either.
On the face, where the buttons are that control the tilt of the face there is a small reset button (In between). I pressed this whilst the unit was off, and when I switched it on again, the CD started playing but I couldn't tilt the face and eject the CD, so I hit the reset button again and it all worked!
Regards,
Nov 11, 2008 | Audio Players & Recorders
Hooking up an MP3 to Alpine CDA-9805 head unit
ok when you look at the front of your system there is a button that has a (F) on it press and hold tell stuff comes on the screen then just keep pressing it tell you get to AUX off you should get it from there hope this helps
Jul 23, 2008 | Alpine CDA-9805 CD Player
Nothin will work
If you've got 12v constant on the yellow, 12v switched on the red, and chassis ground to black, your fuses are good the radio is powered properly.
When you plug the harness into the back of the radio you should hear the CD transport cycle. That's telling you the radio's getting power. Hit the reset button (pin-hole switch on front panel) and hold the small square open/close button for 2-3 seconds.
If still nothing, the radio needs service. I'd send that model to Alpine in CA for repair.
Jan 26, 2008 | Alpine CDA-7998 CD Player
Alpine CDA-9805 head unit - frequency hops
make sure no switches are jammed on radio or radio face.Liquid spillage and or intermittent switches on tunning section can also cause this.
Nov 29, 2007 | Alpine CDA-9805 CD Player
Hidden coupled frequencies and 2 buttons not working
try reseting the unit if i dont work new face required
Aug 15, 2007 | Alpine CDA-9827 CD Player
Alpine CDA-9805 CD Player Logo
151 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Jaime Hernandez
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
