Question about LG 42LC2D 42 in. LCD HDTV
I have a LG 42LC6DF Television and the sound works fine, it's that it is showing no picture. What could be the cause of the problem?
  • 11,361 Answers
Either failed 24vdc power supply or shorted out backlight inverter board, but try unplugging it for an hour to let it reset itself first.
First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board.
if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx
Posted on Aug 06, 2010
  • saf_28 Nov 06, 2010
    Hi!
    I have exactly the same issue with my LG - just out of warranty and I had thought I bought 5 years, but looking at my invoice it doesn't have that - major bummer! :(
    Am going to be calling a pro to get this fixed, but they only cover me for parts up to 150 pounds, would all these parts be of that value? or more? if more, I may as well not call the professional and just get a new TV.....
  • Bud Martin
    Bud Martin Nov 07, 2010
    You can sell each parts on EBAY, they will be worth more than the whole TV. Look at www.shopjimmy.co to see how much your parts are worth, especially the LCD panel.
My 32" LG LCD is losing its resolution; picture washed out but sound working fine, any ideas?
Check your settings, you might just need to track and reinstall all channels again...sometimes caused by bad weather/showing
( no signal ) or you can see your manual trouble shooting guide.
Hope this tip helps.
Aug 03, 2015 | LG Televison & Video
LG LCD 42" sound but no picture
From this web site it says:
http://www.ehow.com/about_5379235_lg-television-problems.html
Powering Off
  • Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
Read more: http://www.ehow.com/about_5379235_lg-television-problems.html#ixzz2qeK8T3SU
Jan 17, 2014 | LG 42LC2RR 42 in. HD-Ready LCD TV
Flashing black and white squares instead of picture on screen.
This might require attention by a qualified service technician.
Jul 13, 2012 | LG 50PC3D 50 in. Plasma Television
I have a LG 50PX1D 50 in. Plasma Television. it turns on and stays my sounds or working fine. but no picture.. i have checked the power board and the capacitors are ok, and the fans are working @ normal...
You need to replace both the Y and X-sustain boards to light the tv. If the voltage is fine from the power supply then those are the only other boards related to lighting the plasma gas.
Thank you!
Jul 07, 2011 | LG 50PX1D 50 in. Plasma Television
Have a LG 42LC6DF Television and the sound works fine, it's that it is showing no picture. What could be the cause of the problem?
Bad 24vdc power supply, T-CON board, backlight inverter board.<br /> <a name="OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">First, look at the screen in darkened room to see if you can see any slight glow from the screen, if it does, then the problem can be the T-CON (not getting the 12vdc) or the main logic board not feeding the signals to the T-CON board. </span></a><br /> <span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">if not, next place to check will be the power supply module, make sure it has 24vdc which is required by the backlight inverter to work, the reason for not having 24vdc can be from bad DC filter caps (leaking/bulging top, high ESR) or short circuits in the inverter board which will cause the 24vdc supply to go into shutdown mode, so you may have to disconnect the power cable that feed the inverter board to see if the 24vdc will work without the inverter board hookup, you will need to apply about 3~4 amp of load to the 24vdc to make sure it can handle that. There are fuses on the backlight inverter boards also. So there are some troubleshoot you will have to do to find out the causes of the problem you are having.</span></span><br /> <span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"> </span></span><br /> <span style="mso-bookmark: OLE_LINK1"><b><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:</span></b></span><br /> <span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"> </span></span><br /> <span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Please see my basic troubleshooting guide here:</span></span><br /> <span style="mso-bookmark: OLE_LINK1"></span><a href="http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide"><span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide</span></span><span style="mso-bookmark: OLE_LINK1"></span></a><span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"></span></span><br /> <span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"> </span></span><br /> <span style="mso-bookmark: OLE_LINK1"></span><a href="http://s807.photobucket.com/home/budm/allalbums"><span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt">http://s807.photobucket.com/home/budm/allalbums</span></span><span style="mso-bookmark: OLE_LINK1"></span></a><span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"></span></span><br /> <span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"> </span></span><br /> <span style="mso-bookmark: OLE_LINK1"></span><a href="http://en.wikipedia.org/wiki/Capacitor_plague"><span style="mso-bookmark: OLE_LINK1"><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">http://en.wikipedia.org/wiki/Capacitor_plague</span></span><span style="mso-bookmark: OLE_LINK1"></span></a><span style="mso-bookmark: OLE_LINK1"></span><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'"></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"> </span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt">Parts: <a href="http://www.shopjimmy.com/">www.shopjimmy.com</a></span><br /> <span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'">Capacitors kit: <a href="http://lcdalternatives.auctivacommerce.com/Viewsonic-C196320.aspx"><span style="mso-spacerun: yes"> </span>http://lcdalternatives.auctivacommerce.com/Default.aspx</a></span><span style="FONT-SIZE: 10pt; FONT-FAMILY: 'Arial','sans-serif'; mso-bidi-font-size: 12.0pt"></span><br />
Aug 25, 2010 | LG 42LC2D 42 in. LCD HDTV
62SX4D with no sound and won't turn on.
Lamp would be the first thing to check but lamp failure will not cause the picture to be fussy. Lamp only affects brightness. Nor would it cause sound to go out.It could be several thing . Diagnosis by qualified serv tech will be required.
Aug 29, 2009 | LG 62SX4D 62" Television
LG "NO PICTURE" , IF FIX WILL RECUR? ,DID LG FIX DESIGN FLAW 42PC3D
I had same problem - no picture, but sound worked - LG 42PC3d - was two months past warranty, but LG agreed to fix it as a warranty call. Service guy was out within a week to replace the Z SUS(?) board. Works fine now. This must be a typical problem, as LG did fix it, even though the warranty had expired. Good luck.
Nov 03, 2008 | LG 42PC3D 42 in. Plasma Television
LG LCD TV no sound
LG tv flatron no sound, picture everything else is fine but no sound what can be done to fix it
Jun 16, 2008 | LG 42LB1DRA 42 in. LCD Television
LG 42LC2D 42 in. LCD HDTV Logo
828 people viewed this question
