Question about Sega Genesis Console
My sega genesis turns on and the tv it's hooked up to looks like it's trying really hard to get some sort of picture from the genesis but it just cant quite get it.
    Problem Solver:
  • 5 Answers
Hmmm... see, I had that SAME problem with my dad's old Genesis. So, I went out and got a new video wire for it (Can be found at Slackers if you're in the midwest of America... if you aren't, go on Ebay or Amazon and hunt around!), and a new AC cord. Then it worked just fine.
If that doesn't work, try cleaning the copper part of the game you stick into the system with Q-Tips. Sometimes Windex helps, and then you can use a Q-Tip to get the Windex off, and let it dry for about 20 minutes. And if those don't work, get a pencil with a clean pink eraser at the tip, and rub it in the game. Use a Q-Tip to get off all of the eraser shavings. The eraser breaks the electro-static cling made when the game is being read/played.
Good luck, and I really hope this helps!
Posted on Aug 10, 2010
My sega genesis has a clear picture but static sound can someone help?
Try an older TV set. I am not joking. It might very well be the case that newer TV sets/high-end TV systems can't handle the signals of the older video game consoles. Because the newr tv;s don't have the signal transfer inside of them to make the old consoles work so you could use the genesis av cables to hook up to a digital tv instead of the rf switch.
gen_av_cable_2_3_tmb.jpg&maxx=130&maxy=120gen_av_cable_v1_tmb.jpg&maxx=130&maxy=120
Mar 17, 2012 | Sega Genesis Console
How can I hook my sega genesis console to my Direct tv box?
Don't plug your Genesis into your satellite box. Plug your Sega into the back of your TV set. Get a Sega Genesis composite video cable. Run that cable from the mini-DIN connector on the back of your Sega to the RCA (yellow, red white) connectors on the back of your TV set. If you don't have any spare RCA connectors on your TV set, try a composite video switch.
Aug 20, 2011 | Sega Genesis Console
My sega is turning on but the picture looks snowy how do I fix it?
Well instead of using an rf switch use the av cables for sega genesis console lukue games I use the av cables instead of the rf switch easier to hook up as well.
Nov 15, 2010 | Sega Genesis Console
How to hook sega genesis up to a flat screen tv
You need to hook up the cable coming in from the outside to one end of the Sega RF cable and hook the male end of the RF connector from the Sega into the cable input on the TV.On the back of the game console there is a channel selector switch.It is either CH3 or CH4 which is what your TV needs to be on when you turn on the console.If one looks bad try switching the channel selector on Sega and on the TV.
Good luck and game on!
Jun 09, 2010 | Sega Genesis Console
Need step by step directions to hook up a 16 bit Sega Genesis
There should be two plugs on the back of the sega. One for the power cord, and one for the audio/video cord. The audio/video cord is a coax cord with a little box in line. Hook your cable or antenna cable into the jack on the box and hook the end of the cable from the sega into your tv. There will be a switch on the sega or on the box somewhere that designates channel three or four, this is what channel your tv will need to be on to use the sega.
Sep 23, 2009 | Sega Genesis Console
Picture scrolls up
HAD THE SAME PROBLEM ,, TILL I GOT THE S VIDEO CABLE FOR MY SEGA,,BETTER PICTURE,,NO MORE LINES ,,
Aug 16, 2008 | Sega Genesis Console
Problem with the 1st generation sega genesis
If the screen changes (From snow to black or something) when the console is turned on it sound like the console is partially working. Try cleaning the Cardridge pins que tip and some sort of cleaning fluid.
Once this is done insert and eject the cartridge several times then repeat the cleaning process on the cartridge. Hope this helps.
Jul 10, 2008 | Sega Genesis Console
Line across top of screen
Hey I had that same problem with my sega genesis,on my 52 inch rca hdtv,,its because your using the antenna plug to plug it to your tv,,look on ebay youll find for like 3 or 4 $. a s video for your genesis ,,no more lines ,, way better picture,, very clear,,hope to help,,, thanks
Jul 02, 2008 | Sega Genesis Console
Sega Genesis Console Logo
148 people viewed this question
Top Sega Video Game Consoles & Games Experts
DROPNDEAL
DROPNDEAL
Reggie brown
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
