Question about Acer Aspire One Netbook 8.9" Notebook
Turn on and get Check cable connection No bootable device insert boot disk and press any key
  • 31 Answers
The problem is with your Hard Drive
Salim
Posted on Aug 06, 2010
4 Suggested Answers
  • 104 Answers
SOURCE: When I turn on my Acer minilaptop it say: Check
Your BIOS setting or boot order was changed to enable network booting (Intel's PXE).
reboot,tap F2 to enter BIOS and navigate menu to disable network booting.
Posted on Mar 28, 2010
igor106
  • 277 Answers
SOURCE: my Toshiba at start up
If I understand you well, before Windows loads, you get a notification about the ethernet controler which is waiting for a boot data stream to come from a local server. If you don't use a client-server network setup, you'll need to go to BIOS and change the boot options, so that your hard drive is set as first boot device, then DVD as second boot device, then USB drive as fourth boot device, and lastly LAN as fifth boot device.
What happens is that your PC thinks that the LAN is the primary boot device, and in corporate networks PCs get such a setup so that there's one large server feeding data to the local cubicle PCs. In some cases the server-dependancy is set to such extent that these cubicle units are just "dumb terminals". In your situation, your PC thinks it should also get boot infro from the LAN, but as your PC is not a part of a corporate network it waits in vain, and after a while it should move on to the second/third boot device, and eventually find that it has Windows installed localy and starts loading the OS.
So, to wrap up, you'll need to go to BIOS and set your local hard drive as the primary boot option. This will fix the problem only if your hard drive is OK and you've installed Windows on it.
If your hard drive is failing/gone, then your laptop may not even recognize it and therefore moves on to the next bootable device, which is usually the DVD, and then a USB drive and lastly LAN boot.
Anyway, go to BIOS, and see what is the current setup. If the hard drive is set as first boot option, then this is a good sign that you'll need a new drive.
If this was informative please give it a Thumb Up. Thank you.
Posted on Jan 20, 2011
  • 132 Answers
SOURCE: Check cable connection..! PXE-E63: Error while
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Posted on Jun 16, 2011
What to do when my acer laptop is saying no bootable device---please insert boot disk and press any key
Check the boot device list in the bios. Make sure it tries to boot from the hard drive and drive C
Nov 01, 2015 | Acer Aspire E1-531-4444 15.6" Notebook...
How do I fix this error messageFor Athros PC/E Ethernetnet Controller v2.01.9 12/15/09 Check cable Connection! PXE-MOF:Exiting Intel PXE Rom No bootable device--insert boot disk and press any key Inte
That error comes up when the computer cannot find the hard drive or any other device to boot from so it looks for a network booting program and when it cannot find that, the error shows up. REPLACE YOUR HARD DISK,
Aug 01, 2014 | Toshiba Satellite Computers & Internet
Acer Aspire one 722 windows 7 netbook. "Check cable connection" and "no bootable device--insert boot disk and press any key" are two common things appearing. The computer recognized hardrive, hardr
Hello, it looks like somehow the master boot record was erased from the hard drive, maybe viral? You mentioned the hard drive was recognized in the bios correct? If you need data from the hard drive the easiest way would be to pull the hard drive out and use an external hard drive enclosure to remove the data before you erase everything from the hard drive. If you dont need anything thing you can proceed to do a new install of Windows 7. Turn the computer on then hold alt and the f10 key to perform a factory recovery. This will erase everything and reinstall Windows 7. If this doesnt work then you will need a new hard drive and a bootable usb drive with Windows 7 on it. Hope this helps.
Feb 22, 2013 | Computers & Internet
No bootable device packard bell-what do i do?
check your bios settings and make sure your hard drive is first in the boot order.
Nov 24, 2012 | Computers & Internet
My gateway says "Check cable connection!PXE-MOF: Exiting Intel PXE ROM. No bootable device--insert boot disk and press any key". What should I do?
Sounds like the hard drive isn't getting power,the data cable to the drive isn't connected,or the drive controller on the motherboard is toast(I'm a novice tinkerer,not an expert).
May 25, 2012 | Computers & Internet
My daughter's ACER inspire one gives the following message and makes a beeping sound "Check Cable connection! PXE-MOF: Exiting Intel PXE Rom No bootable device---insert boot disk and press any key
There is a loose connection between the hard drive and motherboard of the computer, that's why you are getting that message. You most likely need to take it to a computer repair shop so they can fix it.
Mar 06, 2011 | Acer Aspire One PC Notebook
When i turn on my Acer Aspire One D255 it says: "check cable connection! PXE-M0F: Exiting Intel PXE ROM. No bootable device -- insert boot disk and press any key"
The PXE ROM is part of your system's network interface controller. It is being entered on your system's startup to look for a bootable image on a physical network connection and if found, to boot from that image. If there is no network cable connection to your system or if there is but no bootable device is found on that connection, the result is the error message that you got. As to why your system is entering the PXE ROM can be explained by looking at your system's Setup Utility,,,
Press F2 while powering up to enter the Setup Utility and use the cursor control keys to go to the Boot tab which then shows the Boot priority order. The default order is as follows...
1. IDE0
2. IDE1
3. USB FDD
4. USB HDD
5. Network Boot : LEGACY PCI DEVICE
6. USB CDROM
Your system's internal hard disk drive should be listed beside IDE0 and it will be accessed first to look for a boot record. If the drive fails to boot, the next devices in the list will be accessed accordingly until either a bootable device is found or the last item which is USB CDROM. If a USB CDROM is plugged in on one of the system's USB ports, it will be checked for a bootable record and if not found or no CDROM is plugged in, then the system displays the last part of the message -- insert boot disk and press any key.
Press F12 while powering up enters the Boot Menu which has the Boot Option Menu. This menu should show by default the following...
1. IDE 0: (the name/type information for your system's internal hard disk drive
2. Network Boot: LEGACY PCI DEVICE
If there is no hard disk drive information shown beside IDE 0, then the possibilities are that
1. there is no internal hard drive present
2. there is a hard drive but it has failed
If there is hard disk drive information and pressing enter to select it does not result in an operating system startup, then the drive's startup partition has been wiped and so it has no bootable image.
If there seems to be an internal hard drive present but it has no bootable image, you may attempt recovery from the installation images in the hidden partition. The recovery allows restoration of...
1. operating system to factory defaults
2. applications (selectable)
3. drivers (selectable)
Press Alt and F10 keys together while powering up and the Acer logo is showing to enter Acer's eRecovery Management. Follow the instructions to do the recovery.
Feb 09, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an Acer Aspire1 Netbook and below is the problem. Went to BIOS set defaults but still get the same thing: For Atheros PCIE Ethernet Controller... check cable connection PXE-MOF:exiting intel PXE...
A computer tries to "boot" from many devices:
* 3.5-inch floppy-disk (if available)
* USB memory-stick (if connected)
* internal CD/DVD device
* external CD/DVD device
* internal disk-drive
* over your network-cable, by talking to a "network boot server".
When it tries to boot over the network-cable, and *NO* "boot-server" responds,
you get the "check cable connection" and "exiting from P(re)(e)X(ecution)E(nvironment)" mode.
If it cannot boot from your 'C:' drive, and cannot boot from the network boot-server,
your computer responds "no bootable device" and "insert boot disk" (into CD or floppy-disk),
and "press any key" (to try again to boot).
What this USUALLY means is that your 'C:' disk-drive has stopped working,
meaning that Windows cannot be "booted" from it.
Seek help from a qualified technician to trouble-shoot your disk-drive, and/or to replace it, and/or to reinstall Windows, and/or to "repair" your existing Windows installation.
Dec 28, 2010 | Computers & Internet
My computer is telling me to check cable connection No bootable device-insert boot disk and press any key
that error message means that the computer cannot detect any bootable device(hard disk) try to check if you connect your hard disk properly
Nov 02, 2010 | Computers & Internet
Acer Aspire One Netbook 8.9" Notebook Logo
708 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
