Question about Electrolux 30" Self-Cleaning Freestanding Double Oven Electric Convection Range - White
I put my oven on self-clean. It has been a few hours and we still can't use it. We even tried to "reset" it by unplugging it. What's up?
4 Suggested Answers
fridgetech
  • 473 Answers
SOURCE: Kenmore gas range--oven won't come on
Give me the complete model # from the sticker on the oven and I can tell what you need to fix it.
Posted on Nov 15, 2007
SOURCE: F7
I just fixed my F7 GE Oven. The ribbon cable on the control module was misplaced. disconnect the ribbon cable, cleaning it and re connecting fixed the problem for good.
Posted on Dec 28, 2007
SOURCE: Door won't open after Self Cleaning Oven
if you are facing this problem still yet, I suggest that call a service guy to fix it and turn off the power.
Posted on Apr 19, 2013
I purchased my maytag double oven February 2011 and it has worked great. This morning I used the self clean cycle on top oven for only 2 hours. But after it cooled and unlocked I realized I needed to clean...
you might have to clean it YOURSELF....
umm, power down at circuit breaker for a minute, power up, reset clock and try again.
otherwise wait a few days.
Oct 14, 2013 | Ovens
Oven door is locked somehow
UNplug it and let it sit for a half hour to a hour then plug it back in and it might reset itself.
Jan 05, 2013 | Maytag Stove / Oven / Range Cooktop -...
Closed door, pushed clean button, but door lock button keeps flashing and door won't lock.
Hello there and welcome to Fixya
This is a fairly common problem with self cleaning ovens
The problem normally is that the user has interrupted the clean cycle and the door is locked by default or the door lock assy has failed all together .
Now here is the thing these ovens have a built in memory module that stores a number of commands that the user has input in it like self clean or broil ect.ect so what you will have to do is to clear the memory and it is done like this.
First unplug the oven and do not touch it leave it sit for a minimum of 1 hour this will reset the memory module
Now only after the hour is up plug in the oven and you may hear a beep ora click if so great wait a few min then you can press the cancel button then try to open the door again.
Sep 16, 2011 | Frigidaire GLEB27S7A Electric Single Oven
I was using the Self Clean on the oven after a couple of hours I got an error message E1 and F5 - and the oven door is locked. I have no idea what that means or how to get the door open again. I tried...
Hello there and thank you for choosing fixya
Ok before i get into the error codes just a few words here about the self cleaning feature
This the feature that is the most harsh on these ovens due to the extremly high temperatures that is produced then this can and will cause serious problems if not done correctly
I know that people like this feature but i highly suggest that if you are going to use it please try to get the oven as clean as possiable before using this feature this helps the cleaning cycle tremendously ok?
Now for the error code
the e1 error dode is due to the door being locked so to repair this you need to unplug the oven and leave it sit for at least 1 hour this allows for the internal reset feature to reset the oven controle
after the hour is over plug it back in and in 1 to 5 min you may hear a audiable beep or click if so simply press the cancel button and attempt to open the door if so great you should be ok
Now for the bad one
The F5 code is due to the oven control sensing the extreem heat during self cleaning
and sensing that the controls are not controlling the temperature during cleaning which is a bad thing this can and will cause the control board to fail and once again due to the excessive heat
So hopefully once the oven has been unplugged for the hour and reset you should be allright but if not than you do have a bigger problem meaning that your controle board is shot ok?
Please keep me posted on how this is going so i can send you more information on this
Best regards Mike
Feb 18, 2011 | Whirlpool Ovens
Oven door locked
ah, you lucky guy. You can try a hard reset by unplugging the range for a good 1/2 hour, then plug back in. Unfortunutely this probably won't work, as these clock/timers are notorious for only lasting a few years. You have to blow $150+ and replace the clock/timer. Note: A hair dryer will help you get the face off the old one to put onto the new one.
Nov 10, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
Door lock lites keeps flashing but the door is not locked
The F9 code indicates there is a problem with the door lock.
Try disconnecting the power to the range for 10 seconds and reconnecting. Open the oven door and hold the door switch plunger in while you try these things. Put the control into clean for 5 minutes then cancel clean. You must hold the door switch plunger in for the 5 minutes.
Try canceling the clean cycle without putting the control into clean.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question^%$@#$%
Mar 02, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
GE Hotpoint electric stove
If you ran a self cleaning cycle and now the door won't open you may just need to wait a while. The door locks to avoid anyone from opening it as the over heats up to around 700 or more degrees to burn anything off. Sometimes what will happen however is that the heat will get to intense and cause the door lock mechanism to jamb. If the door doesn't open for you after a good few hours or so you can try unplugging the oven for a while to try and reset it. If not though you will have to go through the front panel and go down to manually unlock the door. Let me know if you have any other questions and let me know if this was helpful. Keep me updated on the outcome too if you wouldn't mind. Good luck and glad I could help.
Jan 22, 2009 | GE Hotpoint 30" Self-Cleaning Freestanding...
Oven door won t open after self clean cycle
Frigidaire CGEB27S7CB built in wall oven. Set to clean oven yesterday and after cycle door stays in locked position. Can not open door. I tried re setting clean cycle and cancelling but will not unlock door.
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Electrolux 30" Self-Cleaning Freestanding Double Oven Electric Convection Range - White Logo
Top Electrolux Kitchen Ranges Experts
Craig Butler
Craig Butler
Robert Plante
Andrew Taylor
Andrew Taylor
Are you an Electrolux Kitchen Range Expert? Answer questions, earn points and help others
