OUr air conditioning system works well until the circuit breaker trips. We added another large return vent in the hall to try to get more air circulating and that didn't work. We just replaced the outdoor airconditioning unit and the circuit trips again. The electrician says the wattage is fine. Any ideas what could be the problem. Everyone is baffled because the house is only 5 years old.
Current (amps) is voltage (volts) divided by resistance (ohms) or I=v/r. Breakers "trip" when there is too much current flowing through them. This can be caused by wiring that is too small for the application or a short (or a bad breaker, but since you just replaced that).
Cable Size:
The conductors have resistance and heat up when current runs through them. Properly sized conductors allow this heat to be dissipated. Long cable runs or cable runs which are tightly bundled with other cables can prevent this dissipation. Heat adds additional resistance which in turns causes more heat, eventually tripping the breaker to prevent a fire. For a 40 amp breaker, the cable should be a dedicated, 8 gauge wire.
Short:
A short (low impedance connection) can be between two conductors or between one conductor and ground (also called a ground fault). Shorts can be tough to track down when they are intermittent. This can be because the insulation was damaged (during installation, by rodents, etc). Moisture can deteriorate insulation or conductors.
It may only be present under certain conditions, so you can try this immediately following a trip. Shut both the breaker and the cutoff at the condenser (you want to isolate the cable), then use a meter to check for bleed between each of the conductors and each other conductor or ground. The neutral eventually connects to ground so it will have zero impedance. If you find there is a connection, you (or your electrician if you don't know what you're doing) will have to track it down and repair it.
It could be a clamp that is too tight where the line enters a jbox or panel, a staple that was driven too far and is biting into the insulation, a bend that is too tight, or a length that isn't supported well and subjected to vibration from a nearby motor .
Other possibilities:
At 40 Amps they'd be really expensive, but are you using a GFI or Arc-Fault breaker? Either of those could cause unwanted tripping.
Good luck with it.
jack g
Posted on Aug 07, 2010
    President:
  • 1,515 Answers
Hi, you say you installed a new condenser outside, but the unit keeps tripping the breaker? I don't know what all this electrician did, but if the new condenser trips the breaker, its drawing to many amps.Its not the watts that need to be checked, its how many amps the unit draws and compare it to the breaker it has to run it. It will tell you on the data sticker max. and min. circuit size, and compare it to the circuit breaker size. It may be to small. If its max is 35 amps, make sure the breaker is 35 amps. Make sure the connections at the breaker are good and tight also. For that breaker to trip, your problem is in the electrical supply. The breaker may be weak and getting hot causing it ti trip. The electrician needed to put his amp probe on each leg of the breaker with the unit on, and see how many amps it is drawing and compare that to the units amps. Either the breaker is to small, or it is weak, or the 2- wires may be loose. This is your problem for sure, from the breaker to the disconnect box at the condenser. Even though the home is only 5 years old, that main a/c breaker could be burned or what ever, but this is the problem. Look at the amps, 30, 35, or so and compare it to the unit. If its OK, turn the breaker off and pull it out and look it over for hot spots. If you replace that breaker, your mystery will be solved. Please keep me posted and let me know the out come. I know this is your problem as the condenser is new. Please be kind when rating me as I know you will. I will be here if you need me, just get in touch by my user name below. Keep me posted. It has to be from the breaker to the new condenser, so check and replace the breaker. This will solve the problem. I keep records of all of my solutions if I need to go back on them, so get back to me. Thank you and
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contractor
Posted on Aug 06, 2010
  • tasteofthyme Aug 06, 2010
    Actually I used the wrong terminology the electrician checked the amps and they were at 40 the same as the breaker, which is also new. We increased the breaker from 35 to 40 hoping this would solve the problem, but no such luck
How do i fix my central air conditioner from tripping the circuit breaker?
tripping circuit breakers indicate shorts in the system or overload from a compressor failure
call in a technician to properly diagnose the problem and get a quote
Jun 01, 2016 | Heating & Cooling
I have no power to bathroom or hall how do i fix
I recommend you check your main panel for a tripped circuit breaker. If no tripped circuit breaker, check your gfci outlet in the bathroom (or sometimes in another bathroom like your ensuite). It could be tripped. Reset it. if it is not tripped, I would check the hall outlet for a bad connection, being careful to ensure power is off when taking apart. If not comfortable doing that safely, contact an electrician who will likely solve the problem with a service call.
Jun 19, 2014 | Electrical Supplies
Air Conditioning Condenser trips @90degrees
the problem may not be the circuit breaker, take an amp reading to see if the breaker is doing its job and tripping on an overload situation. if the circuit is exceeding the breakers rating then the problem is with the unit not the breaker.
Jun 10, 2011 | Bryant 50 Amp 2 Pole Br250 Type Br Ni...
LD3600WV MAIN CIRCUIT BREAKER
I'm not sure what your question is - since all you did was put in a model number of a circuit breaker.
If you need to reset this circuit breaker: 1) Slide the handle to the OFF position. 2) Slide all the other breakers in the panel to the OFF position. 3) Stand to the side (not directly in front of the panel) 4) Slide the handle of the main breaker to the ON position. if it trips, there is a majot fault that should be addressed by a qualified person (electrician).
If the main breaker does not move to the TRIP or OFF position: 1) One by one, starting with the double wide / large value circuit breakers, slide the handles to ON. 2) Any breaker that goes to TRIPPED or OFF should be attempted to be reset ONCE. If it trips again, an electrician should be called, and the breaker left in the TRIPPED or OFF position. 3) One by one, return the handles of the remaining circuit breakers to ON.
If you're looking for different information - please provide as much detail as you can. Include the breaker panel manufacturer's name and model - and the circuit breaker data.
Mar 09, 2011 | Cutler Hammer "WESTINGHOUSE" MAIN DOUBLE...
I have 60 amp circuit breaker on my electrical a/c heater with a 45 amp fuse. I had the unit for 7 years with no problem. This month the 60 amp circuit breaker keeps tripping when the heater goes off. The...
You're unit is a 31/2 ton according to the numbers.Normally, breakers will only be in a half way posistion when tripped. Yes, under most conditions, the fuse will blow before the breaker trips. I have seen this many times, the breaker may be weak, burned, loose wires and so tighten wires, check the condition of the breaker.It sounds like the breaker even though it is 60 amps, is the problem and you should replace it with out hesitating. This will solve you're problem. When you pull the breaker out, look at the metal clips that snap in on the buss bar to see if they have been overheating.And the buss bar its self. You will know. I am sure this will take care of you're problem. Good Luck,
Shastalaker7
Dec 07, 2009 | Goodman CKL42AR42 Air Conditioner
Breaker trips but is ok now on low heat
First clean the vent in the machine and the wall. Try the machine one time not connected to the wall, see if it works better. Carefully tighten the wire connections at the breaker, including the white. It is possible for a breaker to get weak. Your motor may be wearing out.
May 11, 2009 | Dryers
Tripping circuit breaker
You probably have a dirty condenser coil or the con den ser fan motor is bad or the blades are jam that's why it overheat and shut off by overload.
Apr 20, 2009 | Dometic Rooftop RV Air Conditioner
The power plug keeps tripping. when i press the button on the plug. it just trips.
Either there is something wrong with the unit or you have something else plugged into the same circuit. Air Conditioning units draw a lot of power and will trip a breaker if there is a moderate load on the same circuit. Try plugging it in to an outlet that you know doesn't have anything else on it. The other thing you can do is see what else turns off when the breaker trips, that will tell you what else is on the circuit.
Sep 15, 2008 | Haier Heating & Cooling
Heat pump trips circuit breaker
I seem to have the same problem. But when I reset the breakers, they won't stay in the on position. They go back to the off position. What gives? It is 95F inside the house.
Jan 18, 2006 | Haier Energy Star ESA3183 Air Conditioner
Heating & Cooling Logo
141 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
