My Plantronics P950 will only play music on my iPhone when the voicemail button is selected. Wierd. Is there a fix?
My plantronics 590 is not working for yahoo messanger phone conversation
Posted on May 16, 2008
Why i cant stream music from my iphone 4s to play in my nissan 370z via bluetooth
Not sure, If the manual, from the car radio says it should pair with Apple bluetooth devices, it must be a setup problem. If your radio is not (yet) compatible with MP3 over bluetooth from Apple devices, you should ask nissan if they have intentions to upgrade the software in the radio. I think you spent enough on your car, to get this kid of service.
I'm sure most modern car radio's are compatible, because my 2 year old Toyota Yaris can play my music and take my calls from my iPhone 4 without problems.
Jul 22, 2014 | Plantronics Explorer 220 Bluetooth Headset...
Itunes isn't playing in my headset
It is because Plantronics M100 Bluetooth Headset does not support A2DP, without A2DP you can't stream music
Oct 18, 2012 | Plantronics M100 Bluetooth Headset
How do I set up voice mail on an iphone
Adding Voicemail for the First Time
  1. Tap the "Phone" button on your iPhone.
  2. Select "Voicemail." The iPhone will prompt you to create a password for accessing your voicemail, then will allow you to record your first greeting.
  3. Click "Save" to set your recording to your voicemail greeting
Recording a New Greeting
  3. Choose "Greeting > Custom."
  4. Select "Record" and begin recording your voicemail greeting.
  5. Hit "Save" to set your recording to your new voicemail greeting
Dec 06, 2011 | Apple iPhone Smartphone
My headphones will turn on or charge.
Try performing a system reset: While plugging in the AC charger, hold the power/pair button. The headphones will show a solid red or blue light when they have been successfully reset. If it's still giving you problems, contact your retailer for warranty replacement (1 year warranty) or call Plantronics at 800-544-4660 x5 x5538 for warranty service.
Good luck from Headsets Direct!
Mar 17, 2011 | Plantronics Backbeat 903 Bluetooth...
Unexpectedly, my voicemail has a password. I have no idea how that happened but I can't check my voicemail without a password. Not available in "settings" to change anything it remove this...
Hi, you'll need to restore your iphone as a new iphone it will wipe all the data from your phone but its necessary as if you try to restore your phone and use previous back ups it will bring the voicemail password back...Hope this helps..
Use the following steps to restore your iPhone.
***** IF YOU CANT SEE YOU IPHONE IN ITUNES OR IT IS STUCK AT THE APPLE LOGO - POWER DOWN YOUR PHONE - HOLD DOWN THE HOME BUTTON FOR AROUND 6SECS WHILST CONNECTING TO ITUNES - RELEASE BUTTON - ITUNES WILL THEN APPEAR WITH MESSAGE SAYING IT HAS DETECTED IPHONE IN RECOVERY MODE & CONTINUE TO RESTORE YOUR PHONE - FOLLOW FROM STEP 6! ) *****
  1. Make sure you have the latest version of iTunes installed and running before attempting to update.
  2. Connect your device to your computer.
  3. Select your iPhone when it appears in iTunes under Devices.
  4. Select the Summary tab.
  5. Select the Restore option.
  6. When prompted to back up your settings before restoring, select the Back Up option (as seen in the image below). If you have just backed up the device, it is not necessary to create another.
  7. Select the Restore option when iTunes prompts you (as long as you've backed up your device, you should not have to worry about restoring your phone).
  8. Once the restore process has completed, the device restarts and displays the Apple logo while starting up:
    iPhone only: For the iPhone only, after a restore, the iPhone displays the "Connect to iTunes" screen. Keep your device connected until the "Connect to iTunes" screen goes away or you see "iPhone is activated." If iTunes does not have an Internet connection, you cannot complete this step.
  9. The final step is to restore your device from a previous backup. Once your device is restored and-in the case of the iPhone-in the process of activating, you should be able to see the following in iTunes:
    Select the backup you want for your device and select the Continue button to complete your device's restoration.
If you do not want to restore from backup, select "Set up as new...
Dec 26, 2010 | Apple iPhone 3G
Can you play music through a plantronics 220 from a Blackberry 9700?
Yes! I have the same phone and headset :) When your in the song (and your bluetooth is connected, press the BlackBerry button, and select, "enable headset".
Jul 15, 2010 | Plantronics Explorer 220 Bluetooth Headset...
LG KP500 and Plantronics 260 steroe bluetooth music
want to use a Plantronics pulsar 260 headset to listen to music over bluetooth played on LG KP500 phone. After pairing the devices what settings do I need to change on the phone to make it play stereo music over bluetooth to the headset?
May 16, 2009 | LG KP500 Cookie black on T-Mobile U-Fix...
Winamp/bluetooth/plantronics p590
I have found that winamp doesn't automatically output through any hands-free headphones, therefore you need to go into Preferences on Winamp (Ctrl+P), go to:
-Plugins/Output
-select Nullsoft DirectSound Output -->configure
-select Device tab
-select 02: Bluetooth Hands-Free Audio
-click apply
If music is already playing, click STOP then PLAY, pause will not do it.
I have been looking for this fix all day on the internet, but finally worked it out myself.
Hopefully this post will make someone else's day less stressful!
Nov 04, 2008 | Plantronics - Bluetooth Headset Plus Base...
Voicemail does not work all the times
call 1-800-331-0500 press 3 for voicemail and then 3 again to reset it. that should do the trick
Jul 22, 2008 | Apple iPhone Smartphone
Had the same problemwith my iPhone 3G this is how I fixed it -
1) From the iPhone 3G, I called my own iPhone 3G number.
2) Went through the setup. After finishing the ssetup Hang off the iPhone 3G.
3) Then the voicemail button on the iPhone 3G worked - first time, there was a **** pause, it asked me to enter my voicemail password that I had set in step 2, and that's it.
Good luck.
Jul 14, 2008 | Apple iPhone 3G
243 people viewed this question
 Grubhead
Grubhead
