Question about Kenmore Toaster Ovens
Kenmore Non-Convection Dial Toaster Oven. The select dial for Bake and Broil turn on between the detent positions for those functions. The on light does not come on at the detent positions. Can the dial be reset to the detent positions?
  • pelambdin Aug 06, 2010
    The initial solution wasn't even for my appliance. I have a standard Kenmore Toaster Oven with dials for various cooking jobs. One dial can be set for Toast or Bake or Broil or Warm. They all have detent positions. When you turn the dial to one of those positions and set a time and temperature, the red power light comes on. In my case, I have to set the dial between the detent positions to get the power light to come one. How do I fix this problem and get the detent positions to work? Phil
    The #2 expert at least had the problem and appliance correct, but the selection knob doesn't have a stop, so it couldn't have been forced. You can turn the knob continuously among the four selections, but the on light only glows between selections, not at the detents.
  • 6,826 Answers
I think that the dial may have spun inside on its mount. Might be able to take it apart and spin it back and tighten the fastener to repair this problem. If it's possible.
What is the model # of this Kenmore Non-Convection Dial Toaster Oven for more information?
Posted on Aug 06, 2010
    It is 23848449. I tried to pull the knob off, but it won't come out. I also tried to get inside the control compartment from both the front and back, also with no luck. How do I take the thing apart? Phil
  • Duane Wong
    Duane Wong Aug 06, 2010
    http://www.searspartsdirect.com/partsdir...
    I found a site that has some parts for the kenmore small appliance, but it only lists a knob for that area of the toaster oven.
    It occurs to me.. is it possible that the knob has become melted inside and made it seem like it was pointing to the wrong detent?
    According to the parts information, the knob should pry or pull off.
  • Kenmore Master
  • 1,711 Answers
The dial knob have been forced inrecular that is why you have the problem. Due the way a dial knob is constructed the only way to fix it is to force the knob reverce way exactly as the one that cause the problem which is rather impossible.
So you have two option either to replace dial knob with a new so you will have the lights on or continue work the oven like this without the lights but the oven still working ok.
    I would accept that, but this dial knob does not have a stop; it can be turned continuously among the four selections, so there is no way it could have been forced out of the detents.
  • 857 Answers
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Hope this helps else counsult a repair guy.
    This isn't for a microwave; it's for a toaster oven with mannual dial controls. It's a mechanical problem, not an electronic one. Try again.
How do you set the delonghi convection toaster oven to cook chicken nuggetts?
Try this:
Thermostat knob - Toast/ broil
Time - 18 minutes
Wire Rack Position - Upper
Turn after 10 minutes.
For other recipe programs, you can download owner's manual at http://www.delonghiusa.com
Regards.
Jun 16, 2011 | DeLonghi EO1251 Toaster Oven with...
The broil element and bake element both come on set for Bake.
You are correct in your diagnosis. The selection switch has 2 sets of contacts that should only make one when on bake. The contacts internal to that fuse are most likely fused together, the other thing that could be going on is a short circuit in the wires to the selection switch causing the same problem. Typically a repair unless under warranty would be costly unless you are up for the challenge of replacing the switch and checking the wiring yourself.
Apr 20, 2010 | DeLonghi XU1837 Trilogy Bake 'N' Broil...
I broke the plastic dail for the toaster/toast/bake/ dail. Where can i get a new plastic dial?
Contact Euro-Pro by phone at (800) 798-7398. b The replacement knobs will cost you about $10 (3 knobs and shipping and handling) Call-don't email as I got the wrong information when I emailed. You are better off speaking with a person, even if they are in India.
Oct 13, 2009 | Euro-Pro EP278 Bravetti Platinum 1500...
How to clean the inside walls of a delonghi alfredo toaster oven?
pour water in the pan with little detergent for dish,and heat it on 30 deg Celsius for about 30-50 minute,and wipe the walls with cotton rag.
Jun 29, 2009 | DeLonghi XU620 Alfredo Ultima Bake 'N'...
Labels on black and decker toaster oven worn off CT0650C
Top dial is Bake/Broil knob, it goes left to right. Starts with OFF @ 9 0-clock next is 100 dgre then @12 o-clock 180 Deg. is at top center next is 250 Deg. next 350 located opposite of off. Next @ 4 o-clock is 400 Deg. Next @ 5 o-clock is 450 Deg. and finally at the bottom at the 6 o-clock position is BROIL. The Center Knob is BAKE TIMER . Starts @ off position as 0, next @ 10 o-clock is 10-mins. Next @ 12 o-clock position is 20 mins. Next @ 2 o-clock pos. is 30 mins. Next @ 3 o-clock pos. is 40 mins. Next @ 5 o-clock pos. is 50 mins. Next and finial pos. is 60 mins. The Bottom knob is TOAST @ the 9 o-clock is is 0 next @ 11 o-clock pos. is Light , Next between the 12 & 1 o-clock pos. is MEDIUM and the final pos. @ 3 o-clock is DARK. TOAST.
Jun 13, 2009 | Black & Decker CTO650 1500 Watts Toaster...
Farberware Turbo Oven T4850- can't understand temp dial
Use an oven thermometer to test it the temperature at the various dial settings to see which is which.... Good luck!
Dec 08, 2008 | Farberware T490C 1500 Watts Toaster Oven...
Delonghi Toaster Oven Color Select Dial does not turn off
This sounds like a defective timer switch that is not turning the oven off at the end of the time selected. You will need to replace the timer switch. The switches are available but unless you're able to do this kind of work you will need to take it to a repair shop. If you want to DIY you can find the switch at www.thegourmetdepotco.com or www.applianceparts.com. If you don't have a part # you will need the make and model # to get the correct switch.
Jun 19, 2008 | DeLonghi EO1258 - Stainless Steel Toaster...
Toaster Ovens Logo
64 people viewed this question
Top Kenmore Toaster Ovens Experts
Angel Joseph Jr.
Angel Joseph Jr.
Marvin
Marvin
Are you a Kenmore Toaster Oven Expert? Answer questions, earn points and help others
