Question about Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348
No start push mover Briggs motor 6.75 horse 22" blade. Let neighbor borrow. Lol the blade is bent pretty good. The engine turns over. Upon pulling the cable the mower turns over then recoils the cable back into the reel with force. The blade isn't hitting the frame. Haven't checked compression yet. I'm thinking bent crank or the timing off. Maybe sheared the flywheel key? I haven't Che ked spark yet. I don't think it's gonna be air,spark,fuel issue.
  • 252 Answers
You have a sheard flywheel key - if have spark it will be at wrong time
hence the kick back !!!!
replace key in flywheel check flywheel for crackks and check pto for bend if bent have it straightened - replace pto seal and blade
assemble and test
cheers paul
Posted on Aug 06, 2010
Poulan pro 600 6 hp push mower. When you pull start it, half way back thepull start jerks out of your hand and flies back in, meanwhile as this happens the motor turns over once, doesn't start, and a...
hi there kat forsaken
check that your blade and blade carrier is on tight
check your pto is not bent
then check the feather key in the flywheel its likley thats it has been bent / sheard and timming is out , hence the kickback - check 1st two items then replace the feather key think pt # is 222698
cheers pauly46
May 28, 2011 | Poulan Garden
Craftsman 16 HP Electric start 41" mower - on a overhead valve briggs and stratton two stroke engine the hollow push rod bent. We pulled the head and everything seemed in working order. The replacement...
On any pushrod engine you have to make sure that the timing is correct or nearly correct when first firing it up, if you had the cam in the wrong position the pushrod had no place to go when the cam lobe came around=bend push rod.
Sep 24, 2010 | Garden
I have a constant vibration when running my poulan pro self propelled 22 inch cut lawn mower. any solutions to the problem......
My guess is that you have hit something pretty solid while mowing. You have either bent the blade, bent the crankshaft, or both. To check for a bent crankshaft, set the mower up on a table or tailgate where the handle is on the ground and the spark plug is pointed into the air. DISCONNECT THE SPARK PLUG !!! You don't want to risk starting it in this position. While a friend holds the engine brake lever closed, and pulls the rope, you need to watch the blade bolt. If the bolt spins without wobbling, just replace the blade. If the bolt wobbles, then the crankshaft is bent. A bent crankshaft can be straightened by a reputable shop. Not all shops are will to straighten crankshafts. It is not a cheap repair.
Aug 23, 2010 | Poulan Pro 22" Self Propelled High Wheel...
I own a Craftsmen Self Propelled 625 series Briggs and Stratton, 190 CC 22" cut I was mowing and gently swiped the side of a plastic swing and it shutdown. Now when I went to pull the starter cord it...
Check the blade and the blade shaft. Maybe something down there got bent. If the cord won't pull, there is probably something obstructing the blade from moving, or it got bent out of shape. Also try lubricating the shaft to see if that helps.
Aug 22, 2010 | Craftsman 675 Torque 190cc 21" Briggs ...
Engine runs ok until the blades are engaged, if I take the plug wire off the left side, it has no effect on the engine running.I changed plugs and checked the coil and wire, it has fire and compression. If...
Try to determine if the safety switch on the seat is closing or opening.
Does this happen when you are sitting on the seat and engage the blades?
You're ight, if you have gas and spark it should run, if the mixture is right.
Good luck on this one.
Jul 05, 2010 | Briggs & Stratton Briggs Stratton Intek V...
22" Yard Machine Push Mower: The pull is won't pull and it seems that the engin...
check under deck and make sure blade not bent or something bending it-if good try to move blade back and forth if stuck solid than at pull cover look for any screws or bolts loose in area jamming movement if good internal failure possible valve/crank or piston damage
May 05, 2010 | Mtd 22" Yard Machine Push Mower
While driving it there was a rattling in the motor then it lost power and now all it will do is turn over what do i do to fix it
This motor has a known problem for bending push rods.
RECOMENDATIN:
Check for bent push rods.
Change oil every 30 hours of operation or less.
Use a hi quality of oil only.
Hope this tip helps..
R/
David
Feb 02, 2010 | Briggs & Stratton Briggs Stratton Intek V...
I have crafsman 48" riding mower with a 24 hp intek motor
Bent push rods are a function of the valve guide coming loose in the head. The valve binds and you end up with a bent pushrod. Fix: Replace head. $94.00
Jul 13, 2009 | Briggs & Stratton Briggs Stratton Intek V...
I hit a rock and bent the blade on a yard machine. Replaced the blade and tried to start the mower, but the start rope doesn't come out all the way and recoils hard as I'm trying to pull it out.
I did the same exact thing over the weekend, try adjusting your new blade unscrew the main bolt to the blade about 1/2 turn that should get it spinning again, same exact thing happened to me. Good Luck
May 17, 2009 | Mtd 22" Yard Machine Push Mower
Husqvarna Lawn Tractor 48" Deck, 23 Hp, Model# Yth2348 Logo
67 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Tim Whalen
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
