Question about HP OfficeJet J4580 All-In-One Laser Printer
When I try to scan it states no scan options. Once it read no connections but I am able to print from my computer.
  • 700 Answers
No, HP J4580, is not a laser, it is inkjet printer.
You did not state what is your operating system and what is exact error wording. Will try to help with these limited info available, I assume you are using Windows.
Your problem indicates that you did not installed scanner software for this printer or it was not installed correctly. I would suggest re-installation of the scanner program and drivers if this is the problem. Before you do that please run HP Scanner Diagnostic Program and then follow it's instructions:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02073847&tmp_task=solveCategory&lc=en&dlc=en&cc=us&product=3645100
If you require further assistance, please do not hesitate to follow this thread, but please provide me with necessary data, what is your Operating System, what is exact error wording.
Posted on Aug 06, 2010
HP Officejet J5780 All in one printer does not connect to my computer. I need to scan. How can I connect?
First off all check, printer printing properly?, if its printing only scan option not functioning then uninstall the drivers and re install once again. If printer is not at all printing, check system recognizing the printer or not.. if not recognizing, check with another USB cable,Replace formatter...
Feb 01, 2012 | HP Officejet J5780 All-In-One Printer
How to scan soemthing onto a computer
Do you have the full-featured software driver installed? (Installed before connecting the printer to the computer.) Then you have the option of initiating the scan from the computer or the buttons on the unit. (The HP Digital Imaging Monitor Windows System icon should be in your system tray. If the program has been closed, restart the HP Image Zone software or reboot the computer.) There is a Start Scan button on the printer which should launch the HP software. Alternatively, start the Image Zone software and there should an option to start the scan.
These directions will only work if the computer and printer are both on and communicating with each other. If you get an error, try a new USB cable and try using a different USB port. If using a USB hub, try connecting to the computer directly. (If using a print server, try a direct connection. Check if the print server supports bi-directional communication; many only support the print functions not the scan options.)
I hope this helps.
Mar 22, 2010 | HP PSC 1510v All-In-One InkJet Printer
Scanner Issues with my HP officejet pro L7590
Dear Sir,
According to your problem it seems to be your
1.Your Printer USB cable Unpluged or faulty.check your printer USB cable is it connected to the PC or not. if it is correct go to next step
2.May your computer Printer driver uninstalled.You may need to reinstall printer driver and application once again by using printer driver CD. I think these steps helps to solve your problem.If you have any problem regarding this issue post a comment eith more information about the problem,we will glad to assist you.
good luck
Aug 26, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Scanning
Right click on the card in My Computer.
Click Properties, Uncheck READ ONLY
Jun 06, 2009 | HP Photosmart C5180 All-In-One InkJet...
I was searching on Google for sermons on abortion. I had gone to several websites when a ''warning'' window opened from my AVG virus protector program. While I was reading the ''options'' as to what I...
try booting into safe mode? on a pc hit F8 repeatedly while you boot until you get a boot screen with the safe mode option. Some laptops have differant keys, eg F2, <Del>, F10, but ussualy they state this when it boots up.
when you get into safe mode, go to your run prompt and type "msconfig" hit enter. got to startup, disable all.Go to services, disable all. reboot. if this works, try running an pdated antivirus scan. I recommend using Avast! which is like AVG. It can do a start up scan. also try running something like 'trojan remover' which is free to download.
Good luck! :)
Jan 05, 2009 | HP Pavilion dv6000z Notebook
Can't scan from HP psc 2400 to iMac computer
You need to set up the software on the iMac. The reason it gives you that error message is because it can't communicate with the computer and imaging software as the computer doesn't see the scanner and can't communicate with the printer's control interface. The iMac may see the printer and be able to print without any additional software because the driver package for the printer portion may already be installed with the OS X HP printer driver support. You didn't mention whether or not you could print from OS X. I am assuming you can. Faxing and copying from the unit doesn't use the computer at all and doesn't need to communicate with it. Scanning and printing do. If you can't print either then none of the driver or support software is installed and you have to set it up. You can get the instructions for setting the printer up in OS X 10.5 from HP. Just click here and it will take you to the page with the instructions.
Best wishes and cheers
Jan 04, 2009 | HP PSC 2410 All-In-One InkJet Printer
Unable to send scanned document
What error code are you getting? Try to scan again and let it fail. Press system monitor, scan, log. Look for jobs with Result of NG. Highlight one and press details. At the top, look for Result: NG (####). It will display an error number there. What is that error number?
751 cannot connect to server
7xx cannot connect ...
8xx could connect, but error...
801 bad user/pw or firewall
802 user/permissions
899 unknown if successful, may be normal
Check additional functions, system settings, network settings, email/ifax settings. Check SMTP server IP and authentication / encryption.
Ignore POP or recieve options as they are for IFAX.
Nov 18, 2008 | Canon (6981A002AA) for imagerunner 2200,...
HP OfficeJet J4580 All-In-One Laser Printer Logo
159 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
