Question about Bausch and Lomb Legacy 12-1056 Binocular
B/L ZEPHYR 7X35 HARD TO ROTATE CENTER KNOB FOCUS?
Over time the grease in the central pivot shaft hardens to restric the rotation of the focusing wheel. Heat from a hair dryer combined with a little WD-40 can ustally re-soften the grease permitting the wheel to turn slightly. Working the wheel back and forth over a short period of time should get it to work again easily.
Posted on Sep 04, 2010
How to fix when rotating the fine focus knob until it reach the limit of motion and the coarse focus knob get stuck and can only move in very small range.
Based on the fact its a E600 i would suggest to have a engineer look at it : prices range from £120 dependant on your location if you visit www.ukmicroscopy.co.uk they will be able to help
Jan 30, 2014 | Nikon Eclipse E600-fn Microscope Polarizer...
Here?s my problem : My scope model is LX200R 14?. I?ve pulled the focuser shaft out of the focuser arm pin. I?ve turned the locking lock knob several turns before putting back the focuser shaft. I...
Steward, this is Joe Lalumia-- I have seen your post on various forums. The 14 inch is different from the other smaller LX200 scopes.
Probably Dr. Clay, and or Andrew on the Yahoo Group LX200 forum will know the answer because they service these scopes.
Post a message there (register for free) and one of them will answer you about that very nice scope.
Clear Skies!
Joe
Dec 14, 2010 | Meade LX200R 14 in. Telescope
I have a used tasco galaxsee ,model 46114675,114x900 20 mm wide angle eye piece,no manuel.i have never owned a telescope before.problem:I can find objects in the sky,the few i have looked at are all the...
You are OUT of focus -- turn the focus knob until stars are POINTS of light NOT DONUT HOLES!
The disk with a dark center MEANS it is not in focus. Just TURN THE KNOB. Point the scope at the moon and try again.
Sep 01, 2010 | Tasco Luminova 40114675 (675 x 114mm)...
How to adjust the lens-focus?
the lens has a wingnut knob on it, loosen the nut and then rotate the thing to focus in and out. there is also an electical focus in the front of the tv, there is a little black box called a focus block, 6 knobs , 3 focuses for each tube, 3 drive controls (screens).. dont turn the screens, just the focus for the color needed.. look closely they are labeled its just hard to see
the front should pop off, remove what screws you can find, the rest are snaps.. really tough ones.. let me know if you need further assistance.
Jun 25, 2010 | Samsung HCM4216W 42" Rear Projection...
I have a Swift model 802, 7X35 binocular. The
at the bottom hindge there is a nut you can remove . then take a long thin screwdriver and take off the screw that holds the eyepiece focus shaft. turn center wheel till eyepiece xbars come off body,carefull not to touch lenses. gl larry@reichinstruments.com
Jun 23, 2009 | Swift Audubon 804ED BWCF Binocular
Unable to focus my Bushnell 7x35 insta-vision binoculars
insta-vision bino's are self focusing no adjustments.
Jun 05, 2009 | Bushnell "Insta-Focus" Binoculars
Out of focus
Assuming you are focussing correctly. When binoculars are out of collimation the most usual effect is double vision as the optical axis do not line up. The only thing you can do is to take them to a binocular repairer. The problem is the cost. Proper repair need the use of a device known as a collimator and it is a laborious task to do it properly. Your binoculars do not carry a high monetary value and a proper repair will cost more than a new binocular of similar specs. Porro prism binoculars mostly have the objective lenses set further apart than the eyepieces. This holds true except for reverse porro prisms which are the other way round. Roof prisms have both the front and rear lenses inline.
Make sure when you focus that the first eye you use to focus with is the one where the eyepiece does not have its own focus ring (dioptre). The dioptre adjustment is on either the left or the right depending on the brand. That eyepiece should be left alone until you have focused using the center ring. Then leave the center ring alone and focus the eyepiece that has the adjustment ring.
Mar 12, 2009 | Optics
The Dial that adjusts the clarity is frozen.
I thought this was a free service. I am not interested. Thank you anyway!
Nov 22, 2008 | Bushnell ImageView 111025 Binocular
Focus?
The C8 optical tube has a very large focal range. It should be capable of focusing on objects from 15' to infinity. To focus on object at infinity you have to move the primary mirror foward. You do this by rotating the focus knob CCW. Rotate the knob CCW until it comes toa stop them slowly bring the mirror back by rotating the knob CW while viewing the object. It will snap to focus so don't move too fast yor you'll miss it.
Jun 25, 2008 | Celestron NexStar 4 SE Telescope
Bausch and Lomb Legacy 12-1056 Binocular Logo
431 people viewed this question
Top Bausch and Lomb Optics Experts
Jeffrey
Jeffrey
james laughton
james laughton
Are you a Bausch and Lomb Optic Expert? Answer questions, earn points and help others
