Question about John Deere 6300,6300l,6400,6400l Tractor Radiator
I have an old John Deere 1209 hay cutter and I cannot get the gearbox to stop leaking oil. I have replaced the seals once and plan to replace them again tomorrow. If they do not hold this time would there be any problem of just filling the gear boxes with grease? I only use this cutter about three to five days a year probably 30 hours a year at most.
    Problem Solver:
  • 19 Answers
You can fill the gear boxes with grease but also have some oil in there to so they lube till they get warm and grease breaks down reason the seal wont hold is that the seal has wore into shaft
Posted on Aug 24, 2010
How do I replace gearbox seals on John Deere 1145 front deck mower 72
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
May 26, 2017 | John Deere Garden
My john deere 1070 loads up under a load and will stall. I changed fuel filter which was loaded with "gunk" and it ran ok for a while then is doing it again.
I am not sure what you are calling gunk but if this gunk is black it is engine oil. The tractor and the engine was built by Yanmar. The injection pump is lubricated with oil pressure from the engine. The seals in the pump will leak and engine oil will get in the fuel system and contaminate the diesel fuel and plug the fuel. Seals will have to be replaced in the injection pump to correct the gunk.
Nov 08, 2016 | John Deere Garden
730 john deere crankcase full of gas after sitting 2 years what repairs
make sure it hasn't damaged the crankcase seal on bottom drain and replace the oil. it is full of gas because the carburetor failed. put a rebuild kit in the carb. (needle and seat). should stop the gas from leaking in. should be fine
Jul 28, 2016 | John Deere Garden
The steering cylinder is leaking on my John Deere F710 mower. Can this cylinder be rebuilt ? And how do I remove it?
To remove there pins on each end, removed cotter pins.
Your seal is leaking. You can replace the seal youself or take it a hyd. shop.
Aug 26, 2015 | John Deere Garden
What is my problem with my mower oil too full and has gas in it.
Your rings on your piston cylinder provide a seal between the piston and the cylinder wall. If the rings leak, gas from the cylinder can leak into the crankcase. Plus you will lose compression. May need to take it in and have a pro look at it.
Jul 19, 2014 | John Deere Garden
John deere lt133
Engine oil does a couple of things, lubricates and cools. Your crankcase probably takes about 2 qts. Fill it to full and park it over something clean to see if there are leaks.
For your engine to run it needs fuel and air. If the engine is dying, more than likely you have a fuel/air issue. Check your fuel lines for leaks, replace your fuel filter. Clean or replace your air cleaner. Make sure your tank cap can breathe, so air can replace the gas going to the engine.
Verso gearbox leaking oil
There is a seal in the gearbox and this has been damaged so oil is leaking past it out of the gearbox. You will have to carefully replace this seal, to do this you need to take the gearbox out of the car, put it on a bench and carefully remove the old seal and press in a new one.
Dec 20, 2013 | 2006 Toyota Corolla
Changed oil on 17 hp kawasaki engine on my john deere mower. ran engine about one hour and stopped engine. Came back about an hour later and the oil had leaked out. Carried the mower and had the lower...
wipe it off real good and run it for a few minutes and check it to see where it is coming from. could be the drain plug not tight could be the pan gasket is blown in a spot. need to clean it and watch to see where it is leaking at.
May 17, 2017 | Garden
Is the gear box on an old Woods Bush Hog packed in grease or a heavy weight gear oil and what type is best. How do you prevent leaking
90 weight only. Fill through top until level with side opening. If it is leaking, it has likely blown it's seals. If leak is slow, just keep checking and filling it. If it's just flowing out, it's best to replace the box. No too fun. I've had to do it twice in about 15 years. Hope this helps a little:)
Aug 19, 2010 | RTO 1:1.2 Mower Gearbox Brush Hog Rotary...
We have just purchased a john deere 2140 B reg. it seems to have a bad oil leak on the hydraulic system. the position of the leak is in the centre of the vehicle directly below the drivers seat. it drips...
Probably oil from the pto output seal.
Also they leak from the inner linkage arm seals.
Both reasonably easy repairs, seals readily available.
System holds a lot of oil and low oil will affect the hydaulics and steering.
Jul 27, 2009 | Garden
John Deere 6300,6300l,6400,6400l Tractor Radiator Logo
375 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
