Question about Homelite Factory Reconditioned 26cc Gas-Powered MightyLite Hedge Trimmer
Homelite 21" hedge trimmer. Won't start. Has spark, compression, fuel (used a little starter fluid), checker spark arrestor and muffler (clear). I haven't torn it down to check the Woodruff key but it ran fine the last time I used it. Any suggestions will be appreciated.This is a UT 18029D, serial number HT1360994.
  • 34 Answers
Abell, put a little drop of petrol in the plug hole, replace plug and give it a pull. If it fires up for a moment, it is a fuel starvation problem. Check the carb, clean and make sure the nedel valve in the bottom of the carb is not sticking. Good luck!
Posted on Aug 11, 2010
Homelite weed trimmer bogs down and smothers out quits running
This could be a number of things. Clogged air filter/fuel filter/carburetor/fuel tank lid breather hole, cracked fuel line or primer bulb, or clogged spark arrestor in muffler. Here's some links that will help to change the bulb, fuel cap, fuel lines, rebuild carb, replace spark arrestor, and troubleshoot.
Homelite Tune Up
Homelite weed eater gas trimmer will not run how to rebuild weedeater...
http://www.repairclinic.com/RepairHelp/String-Trimmer-Repair-Help
Apr 27, 2014 | Homelite Garden
Any special procedures to starting an old ST-175 homelite weed trimmer that has not been run on over 8 years.
the carb and fuel lines will most likely need repair, i would mix a little extra 2 stroke oil in the gas on the first run, and a few drops 2 stroke oil in the cylinder is a good idea..oh and you might want to check the spark arrester on the muffler .. jay
Dec 31, 2011 | Homelite Garden
I have a echo HC-150 it won't stay on boggs down
Hi, either the carby is flooding and requires a carby kit or the spark arrestor or outlet in the muffler is blocked. Hope this helps, regards Phil.
Jul 18, 2011 | Echo Garden
NEED TO REPLACE SPARK ARRESTER ON HOMELITE LITE 26CC STRING TRIMMER
Remove the Torx screws holding the rear cover on. Then remove the larger Torx screws holding the muffler on to the exhaust port of the cylinder. There will be a gasket there. The spark arrestor will be mounted in the opening to the muffler. You can scrape or burn the carbon off of it. If the spark arrestor is real clogged up, then the muffler probably is too. It should also be cleaned. The inside of the engine probably is carboned up too( if arrestor and muffler are). They all should be cleaned of carbon. It helps the engine perform at its' best and breathe like it needs to.
Oct 15, 2010 | Homelite Mighty Lite Lawn Trimmer
Have zrry30550 Ryobi Hedge Trimmer (reman.) I have good spark,good prime-up, but no fuel into the cylinder. Please help.
Hello. Get a can of starter fluid and a helper. Spray some into the air cleaner and start it up. Have your helper continue to spray a little starter fluid to keep it running for a minute or so. This will clear whatever blockage you have. Once it sounds like it is running well stop adding starter fluid and see. Joe
Jun 12, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Carburater loose
THESE ARE A CHEAP ITEM AND IT JUST WHAT HAPPENS TIGHTEN THE TWO SCREWS UP #20 TORX OR A FLAT BLADE SCREW DRIVER ! OTHER THINGS YOU MIGHT WANT TO KNOW ABOUT THIS .CHECK THE SCREEN ON OUTPUT OF THE MUFFLER. ITS CALLED A SPARK ARRESTOR, THESE GET OIL FOULED AND MAKE EM A BEAR TO RUN . CLEAN IT UP AND SHE WILL RUN LIKE A CHAMP, THE CARB MIGHT NEED REBUILDING ,FUEL FILTER AND A SPARK PLUG IS THE FIRST THING TO REPLACE .. IF'N I WAS ANY HELP VOTE FOR ME ...THANKS.. JAY
May 24, 2010 | Homelite Factory Reconditioned 26cc...
I have a Poulan WeedEater. It had trouble
May 24, 2010 | Poulan WeedEater Hedge Trimmer 25cc Engine
I have a 22 inch 25CC gas hedge trimmer that will start fine but only run for 30-40 sec. in the "full choke" position before stopping. It will also stop if I try to give it gas. What should I do?
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 21, 2009 | Homelite Garden
Hard starting
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 11, 2009 | Garden
Starting problems
Remove the muffler and clean the exhaust port and spark arrestor screen.
Apr 11, 2009 | McCulloch Garden
Homelite Factory Reconditioned  26cc Gas-Powered MightyLite Hedge Trimmer  Logo
758 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
