Question about Kenmore 95002 / 95004 Electric Kitchen Range
I have a kenmore ceramic top electric stove and one of the burners quit getting hot. what could be the problem
    New Friend:
It is a kenmore glass top stove about18 years old. One of the burners stop working just wondering if I can fix it myself?
Posted on Apr 22, 2014
fridgetech
  • 473 Answers
SOURCE: Kenmore Elite Gas Stove
Will have to ask some basic questions first.  How old is the stove?  What is the entire model # from the sticker on the unit?  Is this LP or natural gas?  Also, make sure that the orifices in the center of the burners are clean (can use a safety pin or paper clip to poke them a few times to clean).  Make sure that the black caps are on top of the burners and seated properly or they will not lite.  Let me know what you find.
Posted on Oct 16, 2007
aborcass
  • 2651 Answers
SOURCE: kenmore stove top cermic range
you would need to replace entire glass top itself. part depending on model can run 300 dollars.(part only)
Posted on Mar 16, 2008
SOURCE: Whirlpool electric stove
My sister has a whirlpool electric ceramic top stove/accubake sistem....the problem is that my husband took the door of the oven off to clean and now he can't get it back on......where on vacation at her house and want to fix it before we leave sept. 30/08. We need help fast.
thank you
Posted on Sep 28, 2008
  • 311 Answers
SOURCE: The inner right front element
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Posted on Nov 28, 2008
SOURCE: Kenmore Electric Stove - Gourmet Edition
Hello! I have this stove in black where something went bad inside last week (made like a crunching sound). It still runs but seems to only be getting 110 electricity. Clock and lights work and the large oven stays warm. Everything was working fine until this happened. Could be an inexpensive fix- I willing to sell it for repair or parts if you are interested. The griddle alone sells for $170.00 through Sears. Cynthia
Posted on Jan 01, 2009
I have a kenmore range # 79094152310. And when I turn on the right front burner, the top of the oven gets so hot you would get burnt if you touched it, is this normal for this stove?
no --not normal
stoves even glass top stoves are only hot in vicinity of the hot plates
if the whole top is hot , call an electrician in to check the systems
Oct 02, 2016 | Kenmore Kitchen Ranges
Why do burners not get hot? After rehooking to electrical power, due to a remodel, the burners don't seem to heat up as hot as they used to. Cant boil water on any of the 4 burners.
Could be not enough voltage on your 220.lines ( one wire lose or a bad breaker. or the wires are hooked up wrung causing it to try to operate on 110 instead of 220
Aug 17, 2014 | Kenmore Electric Smooth Top Stove
Maytag ceramic top stove with the double oven, two small burners don't get hot anymore can I fix myself and how?
It is simple . Before the process make sure the the power is off .. There screws on the back after removing them you can lift the top n easily remove the none working ones . You can buy the spear ones online or local shop . I have done it myself or search YouTube with model number youse come a cross with repair option . Good luck .
Aug 06, 2013 | Cooktops
Electric stovetop gets VERY hot
LIFT TOP FROM FRONT ABOVE OVEN DOOR. TURN OFF POWER BEFORE SEVICING.
Oct 20, 2009 | Maytag MER5775Q Electric Kitchen Range
My right front burner will not turn off on my electric stove top.
Its probably the switch for that element, the contacts are fused. If this is a smooth top ceramic stove then the control relay board relay for that element is stuck.
Dec 20, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Soup boiked over on stove top
I had some luck removing food and other stains with the new Vielda Glass Ceramic Scrung (its a sponge)
"Special scour sponge for cleaning glass ceramic cook tops without scratching. Eliminates burnt-in stains and greasy dirt film. Removes grease and loose dirt particles. Microfibre side will create a streak free finish."
I found mine at Walmart. It was a little pricey but if you just use the sponge for the stovetop then it will last a very long time.
Hope this helps.
Dec 17, 2008 | Kenmore 95592 / 95594 / 95595 / 95599...
the sensor is built on to the top of the surface element if it was me id replace both the element and switch so you only have to go in once but its probably the element
Jan 19, 2008 | Kitchen Ranges
Problem with Kenmore Electric stove
I have kenmore stove mod.790-95660103 you turn on any top burner . T he small one inside the big burner comes on Roy
Nov 24, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Kenmore 95002 / 95004 Electric Kitchen Range Logo
307 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
