Question about Intex Automatic Salt Water System for Above Ground Saltwater Pool
Our pump continuosly beeps and reads low flow...no matter what we do.!! Help!! I thought this would keep our water clean like the other reviews I have read. We currently have the Intex 12x4 and are using the pump that it came with, so, why would it say low flow all the time???
  • 297 Answers
It says low flow because that is what is happening.
You either have air in the system, or blockage
Start by checking your hoses and both inlet and outlet areas.
Also check where the inlet hose goes into the motor
there is a plastic grid molded into the front of the motor housing where the hose connects to
this area cloggs up with all kinds of debris
no hook every thing back up
open the bleeder screw on top of the cartridge a few turns and if your motor has one open it also
now open your outlet side first and wait for water to come out of the bleeders
now open the inlet side
now turn pump on for 30 seconds and close the bleeders motor one first if you have one
this should do it
as for thinking the salt system keeps your pool cleaner that is 50% correct
Many things factor into keeping any pool crystal clear
first off the pump is no where near strong enough to circulate the water and therefor causing you to need to filter almost 24/7
There is really to much for me to type for everything you need to know
Please pull up my name and read some of my posts for green water,low flow,
and other code problems
I am sure you will find them all helpfull
I have been running my system and the same 2 filters this being my 4th season and have never gone green or triggered any alarms
Good luck
If you have a specific question get back with me
Posted on Aug 06, 2010
  • mark Gianotto Aug 09, 2010
    well, how did this work for you?
How do i get a higher flow into my pool
The low flow could be caused by a clogged filter. If you have a sand filter and the pressure gauge is reading a high pressure then turn the control valve to Backwash the sand filter until the water is clear in the waste pipe (usually for 2 to 3 mins). then turn the control valve to Rinse for about 1 min then turn the control valve to Filter.
May 09, 2012 | Pool & Spa
Salt water system keeps beeping low flow
Clean or change your filter to increase the flow.
Jul 28, 2011 | Intex Automatic Salt Water System for ...
Will not spray water when set to clean carpet
9 times out of 10 the problem is that the discharge hoses are clogged with old cleaner. The cleaner sets up and solidifies in these hoses. You will need to check these and clean them out to get it to spray again. When get a flow established, use hot water to run through the machine to clean it out. Always empty the cleaning solution from the tank when finished and run hot water through it after each use to keep it cleaned out. Thats the easy solution, if thats not the issue you can either have a bad pump or trigger, let me know what you find.
Mar 27, 2011 | Bissell 9500 ProHeat 2X CleanShot Upright...
When we intially set up the Salt Water System it worked great... Then after about a month and a half, the water started to get cloudy. The system kept giving the "91" Low Salt code and beeping. We then...
Way to much to type for a non typeist
Please look up my name and look at my posts on green water,low salt, and low flow
All of my posts will be very helpful
I am positive of this
Mark
Aug 07, 2010 | Intex Automatic Salt Water System for ...
Intex salt water witha 18x48 witha 2000/gph pump. my salt water system keeps saying low salt... my salt tested fine after adding more and ive cleaned the cell... it will stay on about 20 min then beeps low...
nothing is wrong that you cant fix
you must have your salt no lower than 2800ppm
and no higher than 3800
3000ppm is the best
make sure you run filter only for 24 hours once you have correct salt then start generating
one last thing test with strips that read #'s not the color strips
Jul 03, 2010 | Intex Automatic Salt Water System for ...
Hi- I'm a new intex above ground metal frame pool owner. I bought the saltwater chlorinator to go with my pool. I constantly have a problem with the pool filter not getting enough water to flow through...
You've gotta keep that annoying filter pretty darn clean to please the saltwater pump. I have to scrub my filters daily for this reason. What pump do you have? Mine is rated for 4000gph but I see Intex even offers support for pumps with as little as 500gph.
Jun 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
My intex saltwater chlorine generator & filter beeping forever!!!
hello our pool chlorinator keeps comming up low salt 91 no matter how much salt we put in this is frustrating why is this happening ,,,please help
Jun 06, 2009 | Intex Automatic Salt Water System for ...
Jura Capresso C3000 keeps saying clean unit
We have the S8 here at our office. Ran the cleaning cycle and "Clean Now" message was still on and beeping afterwards. Read the Feb 28 comment and carefully cleaned everything that had grounds stuck to it. Ran the cycle again and it worked. Thanks all.
Feb 28, 2009 | Jura Capresso Impressa S8 Coffee Maker,...
Intex Automatic Salt Water System for  Above Ground Saltwater Pool Logo
656 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
