Question about Technics Audio Players & Recorders
I have a technics sl-b2 that hasn't been used in a while. It was my fathers, looks in good shape. I put a new belt on. I'm having trouble with the pitch adj. It seems to not be able to maintain the same pitch for very long, I'm constantly adjusting it. Is this a simple fix, or should I upgrade to a newer turntable.
    Problem Solver:
  • 5 Answers
Switches and other controls that permit the user to adjust the speed on the turntable often become erratic due to oxidation of the metal contacts contained therein. Dust and smoke add to the problem. Cleaning the controls with quality electronics-type contact cleaners usually gives years of happy service. The job is best left to someone familiar with the complete assembly since other finite adjustment potentiometers are often employed and located on the internal circuit board.
Posted on Aug 13, 2010
NEED A BELT FOR TECHNICS DISC CHANGER MODEL NUMBER SL-MC400
take the belt to your local ace hardware and look for an o-ring that is slightly smaller than the stretched out belt. this will work just as well.
Mar 01, 2015 | Technics SL-MC400 110-Disc CD Changer
I have a technic turntable. SL B2 My needle is worn. I am trying to find the right needle/stylus for it. Do you know where I can purchase one.
You need to look at the cartridge it fits into. It will have a make and model number on it. Put that into Google search and it should come up with suppliers of both.
Feb 21, 2015 | Technics Audio Players & Recorders
Where can I purchase a Technics SL - B2 turntable belt? John Maxwell
try MCM electronics supply. (MCMelectronics.com) You might have to buy a kit of assorted belts or ten belts. MATelectronics is another supply house.(matelectronics.com) or google SL-B2 turntable belt.
Jul 28, 2010 | Audio Players & Recorders
Belt?
Wow, I didn't think anyone still had one. Now that I think about it, I may still have one somewhere myself. :)
The belt you need is a FM 24.5
You can order one for $10.00 at http://www.turntablebasics.com/belts/technics.html
Jul 18, 2009 | Technics SL-1210 Turntable
Adjustments on Technics SL-B2 Automatic Turntable
the pitch is just the speed, adjust to your liking.
"How do I adjust tracking pressure and anti skate?
If you are lucky enough to have these two adjustments here's how: Move tracking force counter weight till needle suspends/hovers above record. then rotate numbers to zero. (this is zero grams pressure on record) then rotate weight AND numbers to recommended tracking pressure for your needle usually 1.5 to 3 grams is average. Then rotate anti skate to be equal. That should get you there. If you still have adjustment related distortion then it may be time for a new needle.
NOTE: Anti skate is adjusting side to side pressure WITHIN GROOVE of record. Tracking pressure is how hard the needle is pushing down inside the groove." from
turntableneedles.com/FAQs_ep_33.html
lots of crackles are caused by crummy records and needles. to some small degree are unavoidable no matter what, but above all the records must be clean.
someday the manual may show up for free here
http://www.vinylengine.com/library/technics/sl-b2.shtml
Dec 02, 2008 | Audio Players & Recorders
Technics SL-B2 Frequency Generator Servo Automatic Turntable will not play
hello
You need a belt.. Lift up the record support..(platter) Underneath you will see a metal post.. Belt goes around that and the bottom of the plate.(there is a rim) . If the belt is there, motor might be bad..
Oct 09, 2008 | Technics SL-1210 Turntable
How do i put my belt back on a technics dc servo automatic turntable system SL-B210 i havnt used it for a while so when i got it out to use the belt was lose uder the thing the disc gose on
Remove the platter, then take the belt, and wrap it to the bottom lip of the platter. You'll see an inner lip underneath the platter... this is where the belt goes.
Next, put the platter back on, and you'll see 2 holes on alternate sides of the platter. Rotate the platter until the brass shaft of the motor is exposed - usually @ the 11 o'clock position. Pinch the belt and pull it out, to wrap around the shaft.
That's it.
- OPTiC
DJ PRO AUDIO
www.djproaudio.com
www.repairnyc.com
Jul 21, 2008 | Technics SL-1210 Turntable
Using Technics SL-B2
check the antiskating. then i don't know.. maybe the tonearm has to be calibrate
Feb 18, 2008 | Technics SL-1210 Turntable
Drive Belt - Technics SLBD22 turntable
Try http://www.vintage-electronics.net/ttbelt.html
Jun 16, 2007 | Technics SL-BD22 Turntable
199 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
