Question about Samsung Digimax S700 Digital Camera
My samsung digimax s700 is not focusing. I've had it about 3 years and has always given me great pictures. But now when I turn the camera on everything works fine except the picture in viewer (and the one I take) are out of focus. This happens in every setting, even the Auto setting. I've tried cleaning the lens (just with a rag) but it didn't seem to help. Any ideas? Or do i just need a new camera?
    Brigadier General:
  • 11,967 Answers
The focus problem is a lens problem. Try these: Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Aug 06, 2010
Hi, i am using samsung digimax s700 for years and recently i took a picture and it become all white. i try to check its white balance on + / - button and found the + / - button is unable to call the...
Yes, I think there is...press "menu/OK" and go to "setup."On the very bottom of that tab, there is a "reset" function.
Comment if this does not solve your problem!
Sep 12, 2010 | Samsung Digimax i6 PMP Digital Camera
Samsung digimax S700 battery problem
Clean the battery terminals and clean the metal contacts in your camera and insert your battery and check, whether you get low battery warning.
Hope this helps.
Jan 31, 2010 | Samsung Digimax S700 Digital Camera
Autofocus not working
Are you depressing the shutter button half way prior to snapping the shot you want. Also check to see if any of you setting are changed...if it's on auto and you still are have the same problem then your lens could be dirty.
Apr 02, 2008 | Samsung Digimax S700 Digital Camera
Pictures either very white/red for Samsung Digimax S700 digital Camera
The iris in the center of the lens may be stuck open or damaged.
you can look inside the front a focus/zoom/ turn on off and see if it opens and closes.
Jan 27, 2008 | Samsung Digimax S700 Digital Camera
Cant download pictures
- install the software
- restart computer
- connect camera to PC, but make sure camera is turned off
- after connecting the camera, and the computer is ready, turn on the camera
- select Computer on camera LCD
- go to My Computer
- click on Removable disk
- click on DCIM
- click on 100SSCAM
- select all the images and copy them
- select a folder where the images will be saved
- paste the images
Jan 01, 2008 | Samsung Digimax S700 Digital Camera
Instructions for camera
You can download the manual from the link below: http://files-upload.com/files/467030/SAMSUNG - DIGIMAX 201_E.PDF You can remove the date as per the attached picture from the manual. The Three images on the front of the camera are the fixed focus ranges. This camera has 3 kinds of fixed focus modes. The focus ranges are : 1. Macro (Flower ) : 0.18m ~ 0.25m 2. Portrait ( Head) : 0.8m ~ 1.3m 3. Normal (Mountain ) : 1.3m ~ Infinity Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 29, 2007 | Samsung Digimax 201 Digital Camera
Samsung Digimax S700 Digital Camera Logo
94 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
