Question about HP Pavilion 515n (DC471A#ABA) PC Desktop
Hp is making a loud noise after being on for awhile
The PC sometimes sounds like a fan is overworking (starts as a low hum but then turns into a loud buzzy kind of noise) and it doesn't happen all the time. i also lost the sound around the same time this happened. do you think it's the power supply fan or the processor fan? i'm not familiar with the guts of an HP but will **** it up & open it with your guidance!
thanks for any and all assistance!
terri tilghman
territ4@hotmail.com
  • territ4 Apr 26, 2008
    i'll give it a whirl, thanks a bunch...
  • territ4 Apr 27, 2008
    thanks, i'm going to take the stupid thing apart as soon as my daughter is done doing her homework!!!
    Scholar:
  • 186 Answers
If you don't want to replace the fan, you can simply pull the plastic sticker label off the back, put a little WD-40 or sewing machine oil on in with the fan both off or on to get the lubricant in the bearings, then wipe off the oil around the surface and cut a piece of electrical tape to cover it from dust in the bearing. It will run good for years then.
Posted on Apr 27, 2008
  • 487 Answers
It is most likely the processor fan which is getting busted or dirty.
Open the machine after having it unplugged and blow it all dut in machine and from both fans. Clean the fans with a soft brush and see if that works. Otherwise you will have to replace it. But normally it is just dirt
Posted on Apr 26, 2008
Program button no response
The cd shouldn't be making a noise, but your cd drive might be, there could be something wrong with it try to identify any cracks or marks on the cd, if there are any that may be the cause behind the program not responding. The loud hum you're hearing could be due to overheating, carefully check your computers temperature, if the cd is damage the loud hum may be produced due to the cd drive overworking itself trying to read a damaged disc. Hope this helps.
Feb 12, 2013 | Computers & Internet
My Maytag MFD2560HES bottom fridge is making a loud humming noise.
Any time there is the sound of humming it is important to locate where the noise is coming from. Sometimes fans wear to a point that at one speed the sound as if humming. Sometimes compressors hum with more catastrophic results. Because your model is a bottom freezer it would be a good idea to open drawer to freezer and see if the sound is from fan in freezer or if pulled away from wall is the sound the fan or compressor area? I believe I will be able to locate a service manual but I will need you to help me pinpoint the location of the loud sound so we can get the sounds back to normal. Let me know if you are able to try that and what you find, Sea Breeze
Mar 23, 2010 | Maytag MFD2560HES Bottom Freezer French...
Hello I have a Dell Dimension 3100 desktop. After
Bad Fan... either the CPU Fan or the Power Supply Fan or the Case Fan. If the PC is older than 4 years it is probably the Power Supply.
Dec 30, 2009 | Dell Dimension 3100 PC Desktop
Making a lot of noise
Sounds like a bearing in the cooling Fan
Thanks for using FIXYA
Sep 21, 2009 | Samsung DLP HL-P5663W 56" TV
How do I remove/install color wheel/balast on a samsung hl-p5063w
We just replaced our color wheel and it took about 2 hours.  We used this site because it was the only one that somewhat resembled our TV http://guides.fixyourdlp.com/samsung/bp96-01579a.php  Our TV had a loud humming noise and no picture.  We also had to replace the bulb.  Hope this helps.
Nov 18, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Loud humming noise as fridge is running
if you have ice buildup then the fridge may be low on freon.
or there is dust clogging around the pump or fan is not running.
remove the bottom or back and look around the compressor.
see that the fan is running.
Jun 04, 2008 | Sub-Zero 661/F Side by Side Refrigerator
Sounds like the freezer fan is rubbing some wires or possible some foam insulation around the fan. I would look into the freezer compartment fan and go from there. The fan Will Shut off when you open the doors. Let me know how you make out and if you need anymore help.
Thanks,
Bill
Apr 27, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
HP Pavilion 515n (DC471A#ABA) PC Desktop Logo
549 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
