Question about Garmin Edge 305 GPS Receiver
I think I left ny edge 305 on over night. It wont turn on now, even after being on the chartger for an hour. Any suggestions?
Try a reset: Hold ON/OFF button pressed and press LAP button briefly.
Posted on Aug 10, 2010
The device is blocked
Hi Have had this happen to me also, try pressing the mode and reset at same time also try lightly tapping frame of garmin on desk (easy though). if this still fails put it on your bike and go for spin??? hope first suggestion works as it did fr me
Mar 23, 2010 | Garmin Edge 305 GPS Receiver
I have an edge 305 and use it mountain biking. O rough trails it shuts down. I think it's a loose conection inside the unit. When I stop it will turn right back on.
It is a connection problem inside the device. If it is under warranty you should send back to garmin, otherwise you can apply trick as described at following site :
http://blog.mtbguru.com/2008/11/06/surgery-on-the-garmin-edge-305/
Oct 20, 2009 | Garmin Edge 305 Bundle Includes Hr And...
Edge 205 turning off through runs
There is a generic battery contact problem in the body of the gps, same in 305...this link will show you how to remedy it..MTBGurublog i have done it with my 305 and now do not have the shutdown anymore.... But, before you perform surgery try a full reboot... turn unit off then press mode and power together... unit will ask if you want to delete data..select yes and then manually insert all data again
Aug 06, 2009 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 won't acquire satellite signals
If the option of working without GPS receiver enabled is turned off, then it may be a real damage.
Only thing is to check this option.
Jun 20, 2009 | Garmin Edge 305 GPS Receiver
Garmin 305 wont power on, wont charge on cradle
Same thing happened to mine. Put the unit in the cradle (just like you are going to recharge it) and press the reset and mode button at the same time for 3 seconds. This will "wake" the unit up.
Mar 30, 2009 | Garmin Forerunner 305 GPS Receiver
I am charging the Garmin Edge 305 for 24 hrs or for at least over night, yet the Edge 305 will show 2 to 3 bars of charges and will last maximum 1 hour of riding time. What to do?
Discharge completely device then charge again for 8 hours.
If not working, then attempt Soft reset :
Hold mode and lap/reset for 10 seconds then release.
Start the device then by long press on start. DEvice should start and charge then
Mar 16, 2009 | Garmin Edge 305 GPS Receiver
Garmin 305 is off and wont come back on.
You have to soft reset it first, and if not solving, then try hard reset.
Soft reset : hold lap/reset with mode key for some seconds
Hard reset : hols start and mode, then pulse on lap/reset.
after soft reset hold on/off for up to ten seconds before it starts.
after hard reset all data are lost
Mar 15, 2009 | Garmin Edge 305 GPS Receiver
Forerunner 305 won't charge
Question: My Edge or Forerunner 205/305 won't power on. Is there a soft reset that I can do?
From the Garmin web site.
--------------------------------------------------------------------------------------------------------------------------------------------- Answer: If a Forerunner or Edge 205/305 is unable to power on, a soft reset can be performed to un-freeze it. This will not erase any user data and is most effective if the device is connected to the computer while performing the reset.
To reset the Forerunner or Edge 205/305:
  1. Connect the device to the computer using the USB cable
  2. Press and hold the mode and reset (lap) buttons together for 10 seconds
  3. Release and wait for 3 seconds
  4. There should be some indication of battery charging (either Finished or In Process)
  5. Power the device on while keeping it connected to the computer
In addition, please make sure that the device has the latest software version
May 26, 2008 | Garmin Forerunner 305 GPS Receiver
Distance and average speed don't compute.
My solution included changing the battery in the cadence sensor (GSC10). You might not need to.
1. After changing battery, take bike outside. Turn on Edge 305 to acquire satellites (might not be necessary..)
2. Press reset button on GSC10. Should see red/green flash.
3. On Edge 305, go to SYSTEM.
4. Scroll down to ACCESSORIES.
5. On Accessory page, scroll to bottom, under Cadence Sensor, and press RESTART SCAN.
That fixed my Edge 305 - cadence and speed do appear now.
Apr 07, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
48 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
Steve
Will Halftowaite
Are you a Garmin GPS Expert? Answer questions, earn points and help others
