Question about Akai LCT3285TA 32 in. LCD Television
I have a AKAI 32" LDC flatscreen with a built in DVD player and the other night while watching a show the screen went black and had a few verticle pinstripe lines going through it. I tried turning it off and on a couple times but the screen is still black. Do you have any remedies to fix this?
  • akpassaretti Aug 06, 2010
    Also the sounds still works so does this mean the whole tv is bad or just the screen.
  • 4,472 Answers
It could very likely be a bad power supply best thing to do is take the back of the tv and inspect any and all capacitors. That is a very common fault in these lcd tv's and the first place to start. If you need further assistance please let me know.
Thank you,
lee
Posted on Aug 07, 2010
    Novelist:
  • 132 Answers
This set has a common problem w/ capacitors going bad on the power supply board. I've replaced bad caps in almost every brand for no picture or dead set. I always start by taking a look at all of the boards, after I get the back off, and take a quick look at all of the electrolytic capacitors to see if any are bulged or mushroomed on top. Any that are should be replaced.
The thing that worries me about your set is that you said it had the vertical lines which could be a bad panel(screen). If it is the panel it wouldn't be worth fixing. Normally the set will remain lit when this happens, and it will have lines that overlap parts of the picture.
If it has bad caps, a repair shop would probably charge $100 - $150 to fix it. If it needs a panel it would probably cost as much as a new set..
Posted on Aug 06, 2010
    I forgot to include that the sound still works so would your suggestion still remain to check the board inside? I will do this tonight and get back to you.
    Thank you.
  • akpassaretti Aug 07, 2010
    I forgot to include that the sound still works so would your suggestion still remain to check the board inside? I will do this tonight and get back to you. Thank you.
DVD player not working, only used a few times AKAI lct32z4adp 32"lcd tv with built-in dvd player
Unfortunately they are a real bare to fix. Unless its a jammed disc it is probably a defective transport. If it is under warranty have it repaired otherwise get an external DVD player.
Sorry I don't know of any easy fix for the integrated units.
Cheers
Jan 06, 2010 | Akai CFTD2085V 20" TV/VCR/DVD
Our vizio flatscreen tv just went off and won't come back on.
Look and see if the fan is working on the inside.
It may a built-up of dust.
Thanks,
Wbigtodd
Jan 01, 2010 | Vizio L32 32 in. LCD HDTV
My durabrand pdv 709 dvd player's screen went black and wont come
It sounds like you have a circuit overloading. But, is this one of the Durabrand models that have been recalled by Durabrand/Wal-Mart? They recalled most or all DVD players built since 2006 because they have a tendency to overheat and catch fire. Look into it by calling your local Wal-Mart.
Sep 12, 2009 | Durabrand DUR7 Portable DVD Player
Picture stretched on right and left edges.
I have a 32 inch Akai that does this from the built in DVD player mode I would try to get into the advanced video options on the menu I don't have a remote so I can only advise that far
hope that helped some.
Apr 03, 2009 | Akai LCT2715 27 in. LCD Television
Tv doesn't turn on
power pack probably has blown capacitors on it. need replacement of those and the tv should be fine.
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
AKAI Black TV screen, but still have audio
I think your Video Drum needs to be replaced since it's bad. You can get replacement Video Drums on the Internet.
Mar 10, 2008 | Akai CFTD2083 20 in. TV/VCR/DVD Combo
Portable DVD player
check settings and make sure your player is set to play NTSC AND NOT IN PAL MODE
Jan 02, 2008 | kawasaki PVS-10921 Portable DVD Player
AKAI 20" TV w/ DVD Player Model # CFTD2052
Your problem could be a backlight problem. But the bulbs may not be the source of your problem, as both and sometimes 3 or 4 bulbs, depending on the set will not all go out at once. You most likely have an inverter problem with your set, that is the circuit that powers the backlights. Good Luck
Mar 30, 2007 | Akai CFTD2052 20 in. EDTV-Ready LCD...
Akai LCT3285TA 32 in. LCD Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Marvin
Marvin
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
