Question about Graco MetroLite Air 6116 Stroller
Model 7308DEL4 front tray lock broken - Graco MetroLite Air 6116 Stroller
  • Anonymous Jul 07, 2008
    my nanny forced the pram into the car & the front wheel broke-please give me a contact from south africa in jhb.
    Novelist:
  • 126 Answers
Replacement parts
LINK: http://www.gracobaby.com/store/order/default.asp?N=10418+10413+10421&Ne=11
Telephone
Graco Customer Service is available Monday through Friday, 8am to 5pm Eastern Time.
1-800-345-4109 (US)
Postal Address
Graco Children's Products Inc.
Attn: Graco Store Consumer Services
150 Oaklands Boulevard
Exton, PA 19341
Posted on Apr 28, 2008
My Sony DVD DVP-NS508P keeps saying tray locked, I've every method nothing is working..are there other quicker ways to unlock it? my name is Nelly
Hi nelly? Yes. open the top cover by un screwing all the screws. Care fully disconnect all cables that connect to the motherboard from the tray. Un screw the 4 screws from the main unit to release the tray. If the tray wont come off, un screw the front panel from the main unit and look for some locks on the side. Unlock the locks and pull the tray plus front panel out. Turn the tray upside down and on the left side near the top of the tray, check for a gear. Try to move the gear in the direction that it is moving without forcing it and gently the tray will open. Once it opens, unlock the front cover attached to the tray to be able to have the tray on its own without the front panel. Check if a black rubber band that drives the tray is working or has lost elasticity and also check if the load motor is in good working condition. If any of the two has an issue, just replace and your dvd is good to go.
Oct 03, 2016 | Sony Televison & Video
Top tray of a Kenmore dish washer stuck at mid point. Will not open fully or close.
Something is broken inside... You may be forced to force it.
Apr 04, 2015 | Kenmore Dishwashers
My SR750H has the tray locked and whatever I do it will not unlock
Is it locked, or jammed? Is there a small unmarked hole above the tray mechanism? If so, gently push a straightened paper clip into the hole until you see the tray open a bit. At this point you should be able to carefully use your fingernail to draw out the tray and retrieve your disc. Sometimes this is all it takes to unjam the mechanism. Other times a broken belt or gear renders the mechanism broken.
Sep 12, 2013 | Sony Televison & Video
Bypass tray locked out for printing
Please the copiers models.The paper tray is selected in the computer.To the Ricoh copiers the by pass cassette selected mannually.
Feb 07, 2012 | Ricoh Office Equipment & Supplies
My disc tray will not open and sounds like it's running but locked.
On the front of the tray you should see a small pin hole, get a fine jewelers screwdriver or needle, next push it in until you hear a click, the door should pop open, now pull it out all the way and check for any debris or possible broken belt or slippage under tray. If you can't find anything try a disc to see if it will work, if yes! try the eject button if no! remove disc as outlined and have it checked out.
Jan 22, 2011 | Compaq Evo D510 PC Desktop
How to remove drip tray
Hi
Lift up on the front of the drip tray and pull out the front. There are 2 locking pins on the bottom of the drip tray that lock into the machine, that is why you lift up on the front of the drip tray before you pull out.
Apr 20, 2010 | Saeco Royal Cappuccino Espresso Machine
How do I install the envelope feeder tray on the HP 4050n printer I have the feeder tray but no instructions to put it in. thank you
As long as you have the correct envelope feeder then it just locks into place on the front of the printer. Simply open the tray 1 feed door (the one with the model number 4050 on it) and your envelope feeder just "locks" in just above the open tray. If you look at the printer you will see a small square connector block. Now look at the envelope feeder and you will see where the 2 meet together. Then match up the 2 and "lock" it in place.
Dec 08, 2009 | HP LaserJet 4050n Printer
My kids locked my rca dvd player model rc5220p
The Disc Tray is Locked
If the message “Tray Locked” appears on the screen, the retail lock feature has
been accidentally engaged. To unlock the disc tray you must press and hold a
combination of keys simultaneously:
On the front panel of the DVD Player, press and hold the STOP, ON•OFF and
OPEN•CLOSE buttons for at least 3 seconds.
I forget the password Your player is equipped with a “back-door” unlock sequence. Press and hold
the STOP button on the front of the DVD Player and the STOP button on the
remote control at the same time. (Hold both buttons down at the same time
for at least 3 seconds).
Dec 28, 2008 | Televison & Video
My cd trays are locked and wont open on my jvc stereo model #Ca-Hxd77 system #Hxd77 and i dont know how to unlock it.
Most CD trays have a small hole at front for you insert a straightened paperclip about 1-2 mm inwards. This allows release of tray when power is off. I assume this is what you mean by mechanically locked, not locked by software.
Jul 11, 2008 | Audio Players & Recorders
How to open Iomega 650 USB CDRW
Remove the front cover.
Use thin screwdriver to pry side-locking tabs tward the center of drive.
Tabs are on both sides, near the front.
Also on both sides near the back, thru small access holes at the back, on the sides.
Comes right apart, no broken bits.
Feb 02, 2008 | Iomega Ext.DVD Id +/- Rw USB2.0 HD Burner
Graco MetroLite Air 6116 Stroller Logo
324 people viewed this question
Top Graco Baby Gear Experts
Joyce Nokleby
Douglas Dinnebeil
Douglas Dinnebeil
Dennis Crouse
Are you a Graco Baby Gear Expert? Answer questions, earn points and help others
