Question about Makita 10" Dual Bevel Sliding Compound Miter Saw
My blade won't cut threw the intier stock. like somthing is stoping it from breaching the deck. There is no saw dust hindering it anywhere and it used to cut right threw.
    Problem Solver:
  • 8 Answers
Turn the bolt counter clock wise on the arm, this will allow the blade to go lower...don't go too far or u will cut into the base and or fence.
Posted on Aug 18, 2010
New blade tares threw the wood. its hard to push the wood threw the blade
Are you using a new band saw blade? Are you running on a correct speed. I suggest to change the blade. I got 201 Carbon blade from http://sawblade.com/ . Also, make sure you're in right speed so that the blade will make the cut. Don't feed it so hard, let the blade do the work.
Jan 27, 2014 | Ryobi 9" Band Saw Model Bs903
How do i change blade
What is your bandsaw? I have metal and wood cutting band saw. I just follow the procedures in the manual. I am using different Haltbar saw blades,well, actually it would depend on what stock I'm gonna cut. Try reading this blog : http://bandsawblog.com/replacing-the-band-saw-blade-on-your-band-saw/ . Hope that helps.
Feb 09, 2013 | Saws
Smoke
MAYBE YOUR SAW HAS NOT ENOUGH POWER OR THE BLADE IS BAD.
Dec 18, 2011 | Saws
10" table saw suddently has
It could be the particular wood you're cutting, you could have clogged the underside of the saw with dust and need to clean it, you could have your dust collection system running in reverse (heh heh that's a joke son), or it could be related to that particular blade. Different blades are designed for different purposes, and sometimes a rip blade, for example will be designed with gullets that quickly remove the material from the kerf so the blade won't pinch or bog down when ripping. These can tend to throw out more material that an all-purpose (50T) or cutoff blade. Some chip designs may throw more material than others, e.g. ATB versus triple chip, but I haven't noticed this.
Sometimes you will experience more dust when cutting MDF, say, instead of plywood or hardwood. Try a blade with more teeth, perhaps, or a slower feed rate, or equip your saw with a vacuum system to extract the cut dust from below.
Another item to check is the motor itself. Make sure a sliver or shim of wood hasn't fallen through the throat plate and impeded the flow of air to the motor. Make sure the motor is free of dust and can breathe.
In any case, I recommend you wear safety glasses and a dust mask of some sort, to protect yourself.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 26, 2011 | Craftsman Saws
How do I change the blade?
Unplug the saw. Remove the plate that the blade goes through this will allow access to the nut. Raise the blade several inches above table deck. Place a block of wood under the teeth to bind the blade so it won't rotate you should be standing on the infeed side of the blade. With a wrench loosen the nut (Towards You) Reverse to reinstall. It is also a good idea to wear leather gloves in case you slip the blades can still do damage even when dull. Hope this helps please rate if this was helpful in any way. Good Luck and have a great weekend.
Mar 31, 2010 | Jet 10 In. Proshop Contractor Style...
I HAVE THE JET 414458 HVBS SAW.THE SAW CUTS ROUND STOCK CROOKED.IT LOOKS LIKE THEBLADE IS IN CONTACT WITH THE STOCK AT THE START OF THE CUT AND ABOUT .250 AT THE END OF THE CUT THE STOCK IS 1" IN DIAMETER
There are two possible reasons for your band saw to cut crooked.
1 is the set on one side of the saw blade has worn down and you need to change your blade, or
2 your band saw blade is not square to the bed of your band saw.
If the blade is brand new and it still cuts crooked then you need to square the blade to the bed. To check if the blade is square to the bed, lift the head of the saw up a couple of inches and take a square and set it on the bed. Slide the square up to the blade and to see if there is a gap between the edge of the square and the blade. Try to pick a spot on the blade where the tooth is straight or bent away from the square. If there is a gap you'll need to move both blade supports in or out until there is no gap between the edge of the square and the blade.
If you are unable get it squared yourself, contact the place you bought the saw from. They maybe willing to send a service tech out to do it for you. Some band saw blade makers are also willing to send a service tech out to correct any problems that you may have. Lennox is one such company that may send a service tech if you are using their blades.
Hope this helps you,
Hatter1
Mar 06, 2009 | Jet 414458 HVBS - 56M Horizontal/Vertical...
Cut off question
Here a few examples: * 5 inch trim saws, usually with a fine-toothed blade and often with the blade located on the left side of the motor, for easy viewing of the blade path. These are available in 120V, AC models, and rechargeable battery models in various DC voltages. * 6 1/2 inch saws, as shown in the illustration above, used for cutting to length nominal lumber for construction, as well as ripping lumber, and cutting plywood or composite material. * 7 1/4 inch saws, often call skillsaws, from the name of a major circular saw manufacturer, Skill. These are the backbone of the construction industry, used for cutting lumber up to 2 1/4 inch thick. They are used for cutting framing lumber to length, and ripping lumber. They also have a number of optional blades which can be used for cutting composite materials, concrete, ferrous and nonferrous metal sheeting, pipe, tubing, and even cold-rolled steel bar stock. * 8 and 10 inch saws, used for cutting to length larger lumber or timbers, up to 4 inches thick. These are heavier, more cumbersome tools used mostly in industrial work. * Worm-drive saws have a gearbox with a worm-geardrive, and are found in 7 1/4 inch models which are most commonly used for ripping lumber or cutting plywood decking or sheathing. They typically have the blade on the left side of the machine, to make watching the blade path easier when cutting parallel to the edge of a wide sheet of plywood.
Aug 27, 2008 | SAIT Portable Saw Cut-Off Wheel TM 12 x...
Grinder question
Use a pencil and straight edge to mark the cutting line on the wood. Place the wood on the saw table and line the mark up with the saw. Place the mark on the right side of the blade to ensure proper cutting. Plug the saw in and put on your safety goggles. Support the wood on the work surface with your left hand, placing it far from the saw blade. Place your right hand on the handle, and push the trigger to start the saw. Move the saw blade down onto the wood. Put constant pressure on the handle to slowly move the blade through the wood. Release the trigger and raise the blade once the cut is complete. Make diagonal cuts in the same manner, by marking the wood and lining the mark up just to the right of the saw blade. Continue as you would for a straight cut. Remove the wood from the saw. Unplug the chop saw and dust the sawdust off. Remove the dust bag from the back and empty it. Vacuum any remaining dust off of the saw.
Aug 27, 2008 | Dremel 10 Diamond Cut-Off Wheels Saw Disc...
Blade width usage
Blade Width is important when purchasing a band saw. Most saws accept narrow 1/8" blades for cutting detailed designs and tight curves. Better saws also accept wider blades. Wide blades don’t flex as much as narrow ones, but they make accurate straight cuts in thick stock quicker. There are also some wide blades available that can cut metal.
Aug 27, 2008 | Milwaukee Tool Milwaukee 6230 Deep Cut...
Blade size
There are two common blades: Eight-Inch Table Saws are a good choice for crafts and other applications associated with thinner stock.Ten-Inch Table Saws provide the extra cutting depth needed for angled cuts in thicker stock.
Aug 27, 2008 | Jet 708315BTC Jbts 10BT 3 15 Amp Benchtop...
Makita 10" Dual Bevel Sliding Compound Miter Saw Logo
55 people viewed this question
Top Makita Saws Experts
Marvin
Marvin
ray gallant
rlev_7
Level 1 Expert
Are you a Makita Saw Expert? Answer questions, earn points and help others
