Question about Sanyo DS32224 TV
Sanyo DS32224 tv remote
Our remote control seems to be locked up. It will not turn the tv on or off with remote, when you hit the power button, the 'aux' button at the top flashes. when you hit the volume control, the 'tv' button flashes, and it will raise and lower the volume. help!
JILLOMOON@aol.com
  • 2 more comments
  • 4020 Apr 26, 2008
    It won't allow us to switch from VCR, to TV, to AUX...I have been puching the TV button, but nothing happens.
  • 4020 Apr 26, 2008
  • 4020 Apr 27, 2008
    Thanks for your help. It happened one other time, and my husband was able to figure it out somehow...we may just have to buy a new one. Thanks again!
  • 4020 Apr 27, 2008
    You'll never believe it - the remote needed batteries!
    We aren't even blonde! LOL - thanks a bunch for your help!
  • Sanyo Master
  • 5,568 Answers
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Posted on Apr 26, 2008
  • Steve Allison
    Steve Allison Apr 27, 2008
    If you have done the obvious: fresh batteries, you may simply have a failed remote.
    You may find them at a better price but you can buy them here:
    http://remotes.com/remotes/servlet/rs?a=...
  • Steve Allison
    One final note: Does that set still have manual controls?
    If these work as they should, then it is a failed remote.
    If they also don't respond correctly, the problem may be on the receive end of your infrared controls.
    That is internal of course and another remote won't help that problem.
    We had a piece of Ilo junk I mistakenly bought from Wal-mart that had exactly that failure after only six weeks of use.
    In that case, neither the remote nor the set-top controls had any influence on the TV; needless to say, it went away for warranty repair.
    BTW, it is sick again, this time a vertical LCD failure.
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
Where is the mode button so I can sync the remote and the tv? what is the 3 digit code
Hello
Three digit universal remote codes for Sanyo are:-
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:-
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
NB: Switch OFF and switch ON the tv by its front panel power control switch [Not by remote control handset] each time before an other code.
OK
Wish you Happy Peacefull 2011.
Dec 30, 2010 | Sanyo DS32224 TV
I need the codes for my ge universal remote so it will work my sanyo television
if the remote has a "code" button you can search for the code by using the power button on the remote.make sure the tv is turned on first.now press and hold the "code" button till the light on the remote stays on.now hit the "tv button,the light on the remote should still be on.now keep hittin the power button until the tv turns off (careful not to press the power button again when the tv turns off or you'll lose the code) then hit the enter button ont he remote.hope this helps you out:) good luck
Sep 21, 2010 | Universal Remote Control GE174Universal...
Lost remote control can I get another one
contact sanyo at sanyo.com follow instructions to replacement parts
Mar 09, 2009 | Sanyo DS32224 TV
Code for tv
Sanyo is 0154
If this doesn't work with your new remote there is always the way that I have done it in the past and that is to use the find the code function on your new remote. It is a pain but can be done and is quite effective. Each remote is slightly different, but for the most part you would hit the set up botton and hold it in until it starts flashing then hit the T.V. Button and then hit the first code it tells you to hit and then hit the power switch if it doesn't turn off your T.V. then you hit the increment button up, (this is different for each remote so it is important to follow the instruction manual on this part) You bassically keep hitting the incriment button until your code comes up and then it will turn off your t.v.! Then your done. Note: It may take up to 400 pushes of the increment button, but it will work.
Dec 13, 2008 | GE JASRM24912 Remote Control
Sanyo DS32224 TV blurry
Do you have the original remote for that TV set? If you do not, you will need to get one or borrow an original Sanyo remote so you can get into the set's menu and go to puicture set up and try adjusting the constrast up a little bit.
Mar 20, 2008 | Televison & Video
Problem with sanyo tv
Check the menus in the TV. Look for a Display menu. There should be an option somewhere to turn this off. I don't know this TV personally, but it CAN be turned off.
Feb 05, 2008 | Sanyo DS32224 TV
Ds3224
push reset on remote twice quickly
Jan 05, 2008 | Sanyo DS32224 TV
Accidently hit the key lock button
Hi
You can overcome this problem by disconnecting the AC power cord, to turn off the power. Then press and HOLD the select button and reconnect the AC power cord.
This should clear the Lock.
Hope it helps
Dec 08, 2007 | Sanyo PLC XU50 Multimedia Projector
Sanyo DS32224 TV Logo
263 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
