Question about Texas Instruments TI-Nspire Graphic Calculator
The display is not working properly -- grids and lines are showing instead of numbers
    Problem Solver:
  • 14 Answers
If the display is not working properly, try to reinstall the operating system to see if that helps.
Posted on Aug 20, 2010
Panasonic dect 6.0 plus name and number of incoming calls aren't showing on phones. How can this be fixed?
Do name/number display on any other phones on that line?
If that is your only phone, try borrowing another with working call display from a friend or neighbor. If another phone doesn't display caller info, call your phone company - most charge extra to provide caller number ( and in some cases, another extra to add the name). Even if the features are included in your rate, it's possible they weren't turned on correctly.
Your Panasonic may also have a setting to show name or number - depending on the display size, you may have to pick one or the other.
Finally, some phones do not support exactly the same caller ID info that the phone company sends - I have seen some which displayed number instead of names and no name, just because the two pieces of equipment did not agree on the standard. Try your Panasonic on someone else's line with working Caller ID.
Oct 12, 2017 | Panasonic Lands Phones
Why is it that small decimal numbers only show in exponents instead of a long decimal number?
The calculator has three display formats for results: Normal, Scientific, and Engineering. It is possible that your calculator is configured to display results in Scientific Format.
Press the MODE button. On the first line, highlight Normal. After that you can use the Down Arrow to move cursor to the second line and highlight FLOAT.
Oct 05, 2012 | Texas Instruments TI-82 Calculator
My camera has lines running through the screen. Did I break something?
Probably not, many digital cameras have the option to display grid lines on the display to make it easier to frame your pictures. Look in your camera manual to see if you can turn grid lines on or off.
Grid lines can help you frame horizontal pictures (like a landscape).
Hope that helps!
Feb 22, 2011 | Nikon Cameras
It is showing fractions instead of Decimals when i do equations like (4 divided by 9) it gives 4/9 instead of the decimal.
Calculation results will be displayed using
fractions, r, and ?. When you press CHANGE, the display will cycle
through the following display styles:
• Mixed fractions (with or without ?) ? improper fractions (with
or without ?) ? decimal numbers
• Proper fractions (with or without ?) ? decimal numbers.
Feb 03, 2011 | Sharp ELW535 Calculator
How do you program so that when the phone rings you are able to pick up the call without hitting a button. Also when you make an outgoing call and you pick up the phone you get an active line instead of...
Sets that are programmed to ring should automatically have ringing line preference.
Programming is done on M7310, M7324 and T7316 sets.
To set up ringing you need to enter programming by pressing the feature key followed by **266344.When prompted to enter the password enter 266344.
The screen should say TERMINALS&SETS.
The 4 top line/feature keys are now used for programming2.gif.
At the terminals&sets prompt, press the show key (top right arrow).
The display should now ask for an extension number. Enter extension number you wish to program ringing on.
Press the show key (top right arrow)
The display should sat LINE ACCESS
Press the show key (top right arrow) .
The display should say LINE ASSIGNMENT.
The display ask for a line number. press list
The display should say line 001: appear only
press the Chng key till it says appear & ring
press next key (lower right arrow)The display should say line 002: appear only
repeat procedure for remailing active lines
press the heading key (top left arrow) til the screen says terminals&sets again
Prime line assignment is also programmed at the terminals&sets prompt.
press the show key (top right arrow). The display should now ask for an extension number. Enter extension number you want to change the prime line on.
The display should say Line Access
The display should say Line Assignment
Press the next key (bottom right arrow) .
The display should say Line Pool Access.
Press the next key (top right arrow)
The display should say Prime Line
Press the Chng soft key till you get to the desired line or pool to pick up on
Press the release key when finished
Oct 19, 2009 | NorStar Meridian M7310 Phone
My Samsung LN-83251D is not working properly. Instead projecting a picture, it just displays bars and lines. Is my LCD TV broken?
Jul 06, 2008 | Televison & Video
Matrix Style Lines
Yes, this could be a property value set in your display. Go to Control Panel, Display and hunt through your display adapter's advanced settings and see if there is a check box for display grid and turn that off.
Regards,
Worldvet
Jun 21, 2008 | IBM ThinkPad T30 2366 Notebook
Sony kp-53v80
Heres how you get into the service menu. BUT be very careful write down anything that you change as this can screw your set up and if you write down everything you will be able to change it back if it affects your set. You may want to consider getting the service manual which will explain all the details on the convergence adjustments. If so let me know and I will post a link where you can get one along with free tech support to help you out with it.
Put the TV in Standby Mode.
  • Then press the following buttons on the remote:
    {DISPLAY} {5} {VOL+} {POWER}
    or
    {DISPLAY} {5} {POWER}
    or
    {DISPLAY} {5} {PICTURE} {POWER}
    or
    {DISPLAY} {5} {VOL+} {PICTURE} {POWER}
  • The TV will turn on with the Service Menu displayed.
  • Use numbers {1} and {4} to select the item to adjust.
  • Use numbers {3} and {6} to adjust the value of the data.
  • Press {MUTE} then {ENTER} to save new settings.
  • The words "WRITE" in red will show up in the upper right corner if saved.
  • Turn the TV off to exit the service menu.
  • Mar 25, 2008 | Sony KP-53V80 53" Rear Projection...
    What is the focusing screen display?
    There are two display modes newly added for the DiMAGE 7i, grid and scale. The grid mode is to show a grid over the entire screen. This makes it easy to align the camera to objects vertically or horizontally. In the scale display mode, horizontal and vertical lines cross at the image center to divide the view to four sections, and each axis is scaled. This function is useful for close-up photography. The grid or scale on display is not recorded.
    Sep 15, 2005 | Konica Minolta DiMAGE 7i Digital Camera
    Texas Instruments TI-Nspire Graphic Calculator Logo
    76 people viewed this question
    Top Texas Instruments Office Equipment & Supplies Experts
    k24674
    Stevan Milanovic
    Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
