Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
The TV on light lights up and nothing happens and then it keeps going on and off
Tv turns on for less than 30 seconds and turns off and red light is blinking
Hi John,
TV going off in thirty seconds and red light blinking means there is something wrong inside your Tv and it should not be working in this condition and hence is the "going off" happening. The automatic protection inside is switching your tv off. Please consult some local TV tech. There is nothing you can do about it yourself.
Good Luck.
May 23, 2015 | LG Televison & Video
Why is the power button blinking on then off, i can't turn my tv on
The set is in shutdown because of some internal problem. Can be almost anywhere in the set---
Mar 13, 2012 | Televison & Video
Green light flashing on TV. Cannot get it turned off. No pictur
Did you get yours resolved? I had the same thing. The repair guys called it the "flashing light of death". It indicated the TV is dead.
Jul 13, 2010 | Mitsubishi WD-52525 52" Rear Projection...
The screen won't turn on. The tv just clicks and
The power board ic coverter it dead.
U need to replace the power board.
U can go the web and buy this board changes
or get the tv repair man replace part and labor $575.
Aug 13, 2009 | Sony FD Trinitron WEGA KV-32HS510 32" TV
Plasma problems
Well, it may be your power cord, check the cord for bare wiring which is the metal hanging out of the insulation rubber. If it is then go buy another cord.
Jan 29, 2009 | Panasonic TH-42PWD6UY 42 in. HD-Ready...
Theatre View Toshiba Rear Projection TV 50 Inch with no sound or picture and a red light keeps blinking
I have the sames t.v you have to go in the back flip the power cord switch...then reboot the t.v.
Jun 27, 2008 | Televison & Video
MY tV will not power and red light keeps blinking
Check Horiz Out Transistor and we go from there....T.
Dec 19, 2007 | Panasonic CT-32SX31 32" TV
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
61 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
