No power when i turn on my aircondition - Heating & Cooling
  • 69 Answers
Transformer most likely bad on inside unit, but check all breakers and there is a fuse inside unit.
Posted on Aug 06, 2010
What can make the screen go off and the heat and airconditioning not work
Sounds to me like a breaker has popped. In the main power panel, see if one of the breakers is in the center position.
Nov 27, 2014 | Honeywell Programmable Thermostat Heater
Airconditioning unit wont turn on
there is a low pressure sensor that shuts the compressor of to prevent damage
May 31, 2012 | 1999 Dodge Durango
Our airconditioning just shuts off and when we turn the on power is just kicks off. Is there a re-set button?
There should be a main circuit breaker in your switch board. Turn the ac of leave for a min . that will reset it . You might have other problems also
Jan 29, 2012 | Mitsubishi MSZ-A12NA Air Conditioner
When i press the cool button the air turns on for one or two minutes the shuts off
I Have a aircondition Tempstar PGAD36D1K, on the thermosta the target temperature is 78F but aircondition star working at 85F and stop at 82F.
We want to kwow how we can fix that. This is the second thermostat the we buy and we still hace the same problem.
Thanks
Jun 09, 2011 | Heating & Cooling
Acer 4310 laptop: 3/4 of the screen turns white when i am on airconditioned area, but when i am in an ordinary place (not airconditioned) like my house the laptop lc works very fine? any help?
Screen going to soon need to be replaced as air/moisture is getting into the liquid content of the screen, which is changing the liquid crystal pressure.
Jan 24, 2011 | Acer Aspire 4315 Notebook
Aircondition does not drain fould molding smell
yes the dealer has a special machine that sanitizes the AC system and kills the mold that causes the smell, the chemical they use is not approved for sale to the public so they must do the job.
Jul 21, 2010 | 2004 Kia Optima
I have a problem with the aircondition wiring. There are no electrical power at the aircondition pump to activate it. Have already checked the relay in the enjin compartment and thats not faulty. Regards
If the freon is low there won't be power to the pump. If the pressure switch in the low pressure line is bad it won't run. Find the switch and unplug it and jump the hot wire to the ground and see if it will run. In other words if the plug has 2 wires cut a peice of wire and stick it in the plug. It temporally replaces the switch.
Jan 06, 2010 | 2001 Renault Sportwagon
1996 Lumina. Airconditioning fan does not
if it changes tone as the setting is changed it should be getting power , if the fan is not blowing it is the evaporator motor/wiring.
Phil
Jun 09, 2009 | Heating & Cooling
TURNED OFF AND 5 WAY LIGHTS ON AIRCONDITIONER FLASHING, WON'T TURN ON
1.check selector switch.
2.wiring.
3. check cirkit board of aircondition
Jan 29, 2008 | Heating & Cooling
Heating & Cooling Logo
24 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
