Question about Bosch HBL5460UC Electric Single Oven
Oven thinks probe is connected when it is not and asks to remove or set proble
I need to know How Can I change de meat temperature core in SCC202G Rational Oven.
To change that probe you need to remove the top of the oven and at the front and running from right to left is a tube that has the cable for that probe, if that probe has never been replaced before then you can (WITH THE POWER DISCONNECTED FROM THE OVEN) disconnect the original probe wiring and carefully and using electrical tape join the defective probe wiring less the probe body, you should be able to pull the new probe wiring thru that tube and connect the new probe exactly ware you disconnected the old probe, make sure you take a detailed picture of the connection before you disconnect.
Apr 02, 2018 | Ovens
The oven is asking to enter probe time or remove it but we are not using the oven or the probe. we can't use it at all because of this command. Turned power off and on and still the same.
Try plugging in then unplugging the probe a few times. Jack may be greasy and causing the control board to falsely detect that a probe is plugged in.
Sep 07, 2015 | Ovens
Ra610 thermostat
is easy the probe inside the oven is helt there by two clips,remove back off oven after turning off the power to it pull off knob undo nut with long nose pliers and remove change wires over one by one so they are connected right pull out old probe push new probe in though the back to the inside of oven and clip into place
Nov 07, 2013 | Fisher and Paykel Ovens
My GE double oven displays a message to set probe. When I press probe it prompts me to input a code (3 dashes)? Can you provide via e-mail what numbers can be used to set probe?
It is asking for the temperature that you want the meat to be. Example if you want your meat to have a medium doneness then usually it is 150F. You would enter 150. The probe will beep when the meat has reached that temperature
Sep 14, 2010 | GE Profile JTP56 Electric Double Oven
My oven displays error f31. It beeps and when I press clear the beeping stops. But if I try and set the temp it reverts back to f31
The F31 fault code indicates a problem with the oven temperature sensor probe. The temperature probe is secured in the top of the inside back wall of the oven. Unplug the range to disconnect electrical power. Open the oven door and remove the racks. Remove the screws that secure the oven temperature sensor probe in the back wall of the oven. Carefully pull the sensor into the oven until you get to the wire harness disconnect plug. Unplug the sensor probe. Do not let the wire harness **** back through the opening in the back of the oven. Check the resistance of the probe with a volt/ohm meter. At room temperature, you should measure about 1100 ohms of resistance. Since you are getting the F31 fault code, you will not likely measure this resistance. If the resistance is bad, replacing the oven temperature sensor probe .This should fix your problem. You can order this part from the www.appliancehelponline.com If the resistance of the temperature probe is normal (1100 ohms), then I recommend that you access the electronic oven control board in the console (with the range still unplugged ). Remove the upper back panel. Pull the P5 connector on the control board and measure the resistance through the purple wires (pins 12 and 13 as shown below) to check the resistance of the temperature probe through the circuit that connects to the board. If the resistance is drastically different than the 1100 ohms measured at the probe, then the wire harness is bad and will need to be replaced. If you measure the proper resistance through this wiring harness at the control board and the connections are good, then the electronic oven control board will need to be replaced.
Mar 23, 2010 | Ovens
Keep getting a message that says 'remove probe' but we don't have a probe in. Hit 'cancel' and tried reducing the temp on the oven when this message came up ('remove probe'). I hit 'bake' and tried to...
You might want to try and use a q-tip and some rubbing alchohol and try to clean the inside of the probe connector in the oven. Some liquids or something might be in it causing the control board to think the probe is connected. Make sure to do this procedure with the range unplugged. Then wait about 20 minutes before plugging the range back in. Hopefully that will stop the issue. If not could be a control board problem.
Nov 26, 2009 | Ovens
My Jenn Air oven is asking me to remove the meat probe. The only thing I did before it asked me to do that was to turn it try to preheat the oven to 350 degrees
you could have a bad probe receptacle. Or a board problem. Kill power to oven, wait 10 min, cross your fingers and restore power.
Oct 26, 2009 | Jenn-Air Ovens
Superba convection oven probe display problem
I had a similar problem today with my KitchenAid Superba wall convection oven (2002 model). I was roasting tomatoes at 225 degrees F for 3 or 4 hours when the control pad changed and showed that the probe was in use (never have I used it and had to look for it). I, too, tried to plug in the probe and take it out, but nothing changed. My worry was that I could no longer use the timed bake function. After trying to reset by turning off the oven at the breaker, with no change, I turned on the oven to 400 F and left it on for 10 - 15 minutes hoping that the high temperature would dry out whatever moisture that must have gotten in the place where the probe connects. Then I turned it off and just waited. After a half hour or so the control pad cleared and nothing showed (that is what you want when the oven is off!). Everything is back to working now.
Sep 08, 2009 | KitchenAid KEBC107 Electric Single Oven
Oven will ask for temp probe when i am not using one. it then turns itself off.
As you did not include a model number I can suggest you insert your meat probe into it's receptacle and remove it again quickly about a half dozen times.....maybe even a dozen times. The meat probe plug is like an older style headphone plug. The receptacle that it plugs into may need to complete a circuit for the electronic control. When the probe is not in the receptacle, the receptacle contacts touch to complete a circuit. These contacts may have become dirty from normal oven usage. You will be cleaning these contacts using the probe as I explained. If that doesn't solve the problem you may want to call in a professional.
May 04, 2009 | Ovens
KEMS377 Lower electric Convection Oven - no probe, won't work!
"I get a "Door" message when I try to start it. The Message only shows when I try to set the time with one of the function buttons, like and dosent work
Aug 07, 2008 | KitchenAid Architect® KEMS378S Electric...
Bosch HBL5460UC Electric Single Oven Logo
258 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
