Rca color problem
My tv lood like 3d, the colors, red, yellow and blue are not aligment. do you have the part to solve it.
*sorry, my english is bad. I´m from Puerto Rico.
  • 1 more comment
  • anabella83 May 02, 2008
    thank you!
    my tv model is
    rca r52wh74
  • Evangelistda Feb 21, 2009
    I HAVE THE SAME PROBLEM MY TV LOOKS 3D AND IT LOOKS BOW AND THERES TREE LINES IN TOP GREEN RED AND BLUE CAN YOU HELP ME IN HOW TO FIX IT
    MODEL NUM IS MR52WH77
  • 8,617 Answers
Please post the model number of your set and i will post a link where you can get what you need plus free instructions on how to do the repair yourself and save a few hundred dollars.
Posted on Apr 26, 2008
Problem I can't intall my product many times its turn off itself all my installation are well install with my blu-ray ARC tv to ARC Blu-ray are well install I don't understand why its turn off itself
The blue ray turns off or the TV? and what models?
ELECTREPAIRUSA@ELECTREPAIRUSA or you can contact us at that address as we repair/renovate all items electronic and electrical old and new.
Jan 07, 2017 | Televison & Video
I have an LG model 55LH40 purchased in 2010,Screen has a greyish smoke colored vertical streaks in it, very noticeable on a white background. Any ideas what may be wrong?
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jan 07, 2017 | LG 55LH40 55 in. LCD HDTV
My factory DVD player will except disc the ejects it
If I understand your rather cryptic post correctly...
This very well could be a Blue-Ray disk loaded into a
non-Blue-Ray capable DVD player. Your car player's capabilities MUST match the disc, otherwise, the disc won't play.
I've run into this very same problem with my home DVD players. Which both are non-Blue-Ray capable, but I was able to verify the Blue-Ray discs on my PC.
Jan 02, 2015 | Televison & Video
Owners manual english philips pca-061
Contact Philps to request a manual in English.
Jun 02, 2014 | Televison & Video
How do i watch my tv with a broken remote
You can buy a universal remote and program it to work with your TV. I have always had good luck with RCA universal remotes. You can also program the remote to run your cable/sat box and your DVD/blue ray player. You could also go to the web site of the company that made the TV and order a new remote. This would be more expensive but the remote would run all the funcitions while the universal may not.
May 24, 2014 | Televison & Video
How can I fix blue dots on my Sony TV screen?
Seems like a problem with a lot of Sony TV's. Wish i could be of more help, but check this site. Your not alone! Sony LCD Rear Projection TV Problems hope this helps!
May 23, 2014 | Televison & Video
How could I connect a Daewoo 42sm TV?, I can't afford cable so I use a converter box(analog to digital w/rabbit antenna)on my other TV and I was given this Daewoo TV and would like to watch it;please
If your converter box only has RF outpit connectors "F" type screw on it looks like this my be more of a monitor then tv.I took a quick look at the manual and didn't see any RF inputs so it appears it doesn't have tuners built in Looks like you'll need a box that has RCA output connectors.or others that will match what the monitor has on it for input types
Mar 06, 2014 | Televison & Video
Devant ER 31951D remote
Check the remote control for its infra-red emission. Check it with fresh batteries. Check by pressing all the buttons on it; and see whether all of it generates infrared signal while pressing. If it is found OK, check and replace the infrared sensor inside the TV. If you wish to get some details; check the site linked here. It has details about how to check a remote control; by one among the post. Pull up older posts. If the remote control is found OK; check and replace the infra-red sensor inside the TV. Contact any service technician.
http://electro-medical.blogspot.com/
Aug 23, 2013 | Coby TF-TV3217 32 in. LCD TV
Red exclamation point on verizon set top box
How to reset your Set Top Box to fix common problems FiOS TV Residential...
Resetting your Router and Set-Top Box can resolve a variety of issues such as:
  • Missing Interactive Media Guide (IMG) or On Demand menu
  • Unresponsive Set-Top Box
  • DVR recording problems
If you are having any of these issues, you may need to reset your Router and Set-Top Box. Will resetting my Set-Top Box erase the selections I have programmed into my remote?
No, all settings and selections you've entered such as device codes, favorite channels, and recent On Demand selections are saved and available after resetting your Set-Top Box.
Always reset your Router first and then check to see if that resolves the issue. Resetting your router may be all that is needed.
Important note about your router To avoid problems with your FiOS TV service, make sure your router is plugged in and turned on at all times. Even if you are not currently using the Internet, your router still needs be turned on so that FiOS TV can function properly.
To manually reset your router:
  1. Unplug the power cord to your Router for 15 seconds and then plug it back into the electrical outlet.
  2. Wait 30 seconds and then check to see if this resolves the trouble. If you still have the problem, follow the steps below to reset your Set-Top Box.
To manually reset your Set-Top Box:
  1. Unplug the power cord to your Set-Top Box from the electrical outlet for 15 seconds and then plug it back in.
    Note: Don't confuse the power cord that provides electricity to your Set-Top Box with the coaxial cable that is connected to the back of your Set-Top Box. Unplugging the coaxial cable will not reset your Set-Top Box. Since many issues can occur if your coaxial cable is not securely fastened, now would be a good time to check to ensure all connections are securely connected.
  2. Wait for the time to appear on the front of the Set-Top Box, then power it on.
  3. Wait several minutes while the Interactive Media Guide updates.
  4. Check to see if this resolves the trouble. If you still have the problem, your Set-Top Box may need to be re-initialized. Contact the Fiber Solutions Customer Support for further assistance.
I have to reset my Set-Top Box frequently, is this normal?
No, if you routinely have to reset your Set-Top Box more than three times a week, it is likely there is an issue with your Set-Top Box that needs to be resolved. Contact the Fiber Solutions Customer Support for further assistance.
also you can call for tech support at Dial 1-800-VERIZON (1-800-837-4966)
Oct 05, 2012 | Televison & Video
Akai PDP4206EA lost tuner and video inputs
Mine died after a brown out. It turned out to be the main board. They're pretty hard to find.
JE
Aug 14, 2009 | Akai PDP4206EA Television
Televison & Video Logo
122 people viewed this question
Top Televison & Video Experts
Electro Med Services...
