Question about Lexmark X1270 All-In-One InkJet Printer
All in one not found after installation disk used
    Sergeant:
    Champion:
  • 301 Answers
Download revounistaller software its free, unistall the printer with this software, fallow the instructions and delete all options that you can see , and then reinstall the printer driver again
Posted on Aug 06, 2010
Operatering system not found
It may caused by master boot record corrupted, you could use your own windows installation CD to repair it, during boot from the disk there is an repair option. If you do not have installation disk you could use 3rd party tool to rebuild MBR, like AOMEI Partition Assistant to rebuild MBR
Sep 08, 2012 | Computers & Internet
Operating system not found on my laptop wot does that mean?
Operating system not found simply means that the laptop cannot detect that there's an operating system installed on your laptop.
It's either the hard disk got disabled in BIOS or the installed windows is corrupted. You might need to check in BIOS if the hard disk is still detected. If it is, make sure that on the Boot options, hard disk is selected as the first boot option. If it is, then that means that the windows installed on your laptop is corrupted therefore you might need to install windows using the recovery discs of your laptop.
By the way, to go to BIOS start tapping on F10 once the laptop starts to boot up.
Let me remind you that by doing this it will erase everything on the hard disk.
Sep 12, 2011 | Compaq Presario 1692 Notebook
Hard disk problem
neither, the new disk is in need of a driver to operate it it should be in the box with the drive
for some reason it is not seen as plug and play. you could delete it from system in device manager and try plugging it in again. Watch the bottom right of screen FOUND NEW Hware.... Installing new hardware Your hware is ready to use should then show. if that dont occur then the problem is an incompatible new hDD
Jul 28, 2009 | Computers & Internet
Hard disk not found error during Clean XP home Install
That happens because the BIOS uses a SATA controller that is not included in Windows XP install disk.
Usually you can solve the problem going to BIOS settings and changing SATA/RAID settings.Check your BIOS settings, and disable SATA RAID mode.This is done in different ways depending on the BIOS.
On HP/Compaq computers for example you press F2 on startup to enter BIOS, then disable SATA mode on bios settings.
On other makes the procedure can be slightly different.
Another way to fix the problem, is by creating your own XP setup disk with SATA drivers included, see:
Resolving "Setup did not find any hard disk drives" during Windows .
Jul 04, 2009 | Toshiba Satellite A35-S1592 Notebook
Hard drive not installed if os not found re-install hit any key to exit
This usually happens when your BIOS fails to recognise your hard disk or else it is not enabled in BIOS or else there is a loose connection which makes your computer unable to detect the hard disk, You could try and use your BIOS to check if your hard disk is detected. In case it is not, then check the connections of your hard disk or ask your technician to do that
Jun 02, 2009 | IBM ThinkPad T20 2647 Notebook
Operating system not found media test failure will not reboot aspire 3680
Installing an operating system from one computer and inserting it into another computer will not work specially when they are from different manufacturers because the components in them are different.
The Windows install has to be done on the intended computer.
The media test failure error message refers to a faulty disk controller or a faulty hard disk.
Apr 13, 2009 | Compaq Armada 6500 PC Notebook
HP Pavilion Recovery Disks
Sounds like the HDD has failed. Install a new HDD and it should run with the install disks.
May 29, 2017 | Computers & Internet
Unable to start Windows
You can do restore the Operaing system. BUt you need to backup important files, specially my documents.
If you have Disk or installation disk please insert it in the CD/DVD rom and then repair the installation of the windows.
Setup repair installation information can be found here:
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/doug92.mspx
setup fresh installation can be found here:
http://www.microsoft.com/windowsxp/using/setup/winxp/install.mspx
may this help,
melnavz
PS:
pls do not rate me if my solution not solve the issue and you need more further information. but if is invaluable solution rate me fixya.
May 14, 2008 | Computers & Internet
How do i install a mouse on windows98 without original startyup disks
For installing a generic mouse you need not to use any startup disk.
1. Make shutdown your pc.
2. Connect your mouse.
3. Boot your pc.
A message will be display by window that new hardware found, (if your mouse hardware is differ from previous mouse), and window will install the required driver for your mouse.
Thanks
Iqbal
Mar 10, 2008 | Belkin MiniScroller Mouse
Lexmark X1270 All-In-One InkJet Printer Logo
27 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
