Question about Sewing Machines
How to take apart singer ingenuity 7436
Took out screws but it still wont come apart
maklean
  • 1665 Answers
SOURCE: sINGER iNGENUITY 7436 not picking up bobbin thread hitting on plastic piece
did you oil moving parts?
Posted on May 11, 2008
bargainbox
  • 1388 Answers
SOURCE: Need user manual and list of included parts for the Singer 7436
A phone call to a Singer dealer to say you are interested to know which accessories are included with this model will solve the second issue, as to the manual, is the time spent not having one plus the savings you made on original purchase really not worth $15 ?
Sew4Less, or SewUSA may have one, but they will charge....if it is a recent model, the chances of finding a second hand one are remote, and eBay will have machine with manual.
Try the place where you bought it to be certain they don't have the old one kicking around in a dusty corner, or would photocopy one for you ...........a new machine ought to be sold with a manual.
Posted on Jun 01, 2008
SOURCE: Singer Ingenuity Mod. 7436
you can download the manual at: http://www.costco.com/images/content/misc/pdf/334599_instructions.pdf. This site is fairly stupid and won't let me cut & paste the URL so copy it carefully.
Posted on Dec 16, 2008
Mongo32
  • 111 Answers
SOURCE: singer ingenuity 7436 needle wantpick up the bobber
a. needle in backwards
or
b. needle threaded wrong
Posted on May 04, 2009
  • 139 Answers
SOURCE: Have a brand new Singer Ingenuity 7436 and I
http://www.singerco.com/resources/threading.html Check out their threading diagrams, they are really helpful!
Posted on Apr 05, 2010
I am trying to replace a bobbin threader that I broke. I have the part but cannot get the machine apart. I have all the screws out but it wont come apart by the area above the needle. Help!
Newer computerized machines are made (by the manufacturer) so they are difficult to take apart except by technicians. They do come apart but if you don't know how, it's possible to break the plastic clips. You might check with a sewing repair shop to see if they can do it for you for a small price.
In the meantime, you can purchase a standalone bobbin winder at JoAnn's, Hancock's, or Amazon.com for about $30.
Dec 27, 2015 | Sewing Machines
How 2 fix Brother's CS-8060 bobbin auto winder to work?
Replacing the bobbin winder rubber ring.
  • The case halves are held together by 5 larger screws, one under the carry handle, obvious from the holes in the casing, plus one smaller screw up by the foot-raising lever.
  • There is also the final screw, which is a devil to find. You have to remove the plastic tray to which the spool carrier is attached, up by the spool winder. You do not need to remover the spool winder stop but the small screw on the left, in the bottom of the tray-shape.
Next, WITH CARE , lever round the tray with a thin blade and use a small screwdriver to ease it out of the case; there are 2 bits that stick out more than the rest.
  • Once this tray is out you can see a small bar with a screw. Remove this screw and the 2 halves of the case will separate.
TAKE CARE NOT TO DROP THE SCREW INTO THE WORKS!. A piece of sticky-tack on the end of the screwdriver helps here if the screwdriver is not magnetized.
  • Now you can carefully ease the ribbon-strip cable from the circuit board and move the case round to be able to access the screws that hold the circuit board. You do not need to pull out the other cables; just take a tad of care as you work.
The bobbin winder mechanism is held in by 1 screw - take this out and you can then easily replace the rubber drive ring -(which you have providently ordered)
  • Take the opportunity to clear out any fluff and dust while you have the cases apart. Put ONE drop of oil in the center of the bobbin carrier rotating mechanism and one drop on any moving joints.
  • Replace the components/ ribbon cable in the reverse order, taking care not to drop the small screw! It is necessary to carefully line-up the hole into which it fits. It is surprising how easily the tray clips back into place, compared with the hassle you had getting it out.
I took both my CS 8080s apart last week to replace the drive rubbers. The first took nearly 1.5 hours, the next 1 hour as I knew what I was about.
Jun 17, 2014 | Brother CS-8060 Computerized Sewing...
How do I take the machine apart #7469? Where I plug in the foot the plug thing went into the machine
I'm not sure I understand the problem. Is it the foot pedal that you want to remove or is there a problem with it? Exactly what is the problem you're having?
Apr 19, 2013 | Singer Confidence 7469 Mechanical Sewing...
I took my machine apart to correct a problem and I'm looking for help reassembling the machine. I really just need to know where the screws go.
depending on how far apart you took it you may need to take it to a service technician. if its only the cover plates the newer machines usually only have screw holes on the back of the machine and usually under the handle.
Nov 06, 2010 | Brother XL-2230 Mechanical Sewing Machine
METAL PLATE COVERING BOBBIN WON'T STAY DOWN
Take it apart again and compare the original screw with the one you substituted. If they are not the same size, you will need to get one that matches the original.
Re-place the needle plate and when firmly in place, put the screws back in.
Mar 03, 2010 | Sewing Machines
Neddle screw wont tighten neddle in
There is a small metal rod about 1/2" long that fits into the hold in front of the screw that holds the needle secure. I didn't realize that I had dropped the rod until I could not tighten the needle. I found the rod, put it into the hole and was able to tighen the needle.
Jun 22, 2009 | Brother XL-5130 Mechanical Sewing Machine
Took apart tension button on sewing machine
This could be tricky, look on line for a diagram of a typical tension assembly. There aren't that many parts but they can be put on in the wrong order. There is probably a set screw somewhere that has vibrated loose, you need to tighten it after replacing the unit.
Jan 29, 2009 | Janome 2049LX Mechanical Sewing Machine
Feed dogs on Singer 7466 wont stay up.
There is a screw behind the feed dog with a plastic nut ,you need to loosen the nut and move the screw up or down and retighten where needed,,,,,,,,,also there is a plastic support under that screw that could have come out of place ,which means you will have to open the machine to reinstall it.
Sep 01, 2008 | Singer 7466 Mechanical Sewing Machine
Sewing Machines Logo
94 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
