Question about HP DeskJet 3650 InkJet Printer
HP 3650 wont reinstall from disk. Disk is for XP, my computer is a Vista. How it was installed in the first place I dont know. Worked fine for a year. Help.
    Novelist:
  • 113 Answers
according to the HP website, Vista has the correct driver already installed for this printer. Go here for more info:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01655752&lc=en&dlc=en&cc=au&product=304535&sw_lang=&os=2093#N1418
From HP website:
Introduction The driver solution for this product is included in your Windows Vista operating system and is already on your computer. There is no need to download anything. Follow the steps below to quickly and easily get your product working with Windows Vista. The pre-installed (in-OS) Windows Vista driver supports basic printing features.With the basic print driver, the buttons on the product do not function and some of the advanced product features are not available. However, using the workaround procedures in this document, you can still print from a software program. You can also import and view images on a memory card, if your product has a memory card slot.Use the following instructions to install the basic print driver in Windows Vista, and then review the workaround procedures to use the available features for your product. Installing the print driver The method that you use to install the basic Vista print driver depends on whether you use a USB cable or a parallel cable to connect the product to the computer. Use the method for your type of cable .
Method one: USB cable connection When you connect the product to the computer, Windows Vista detects the hardware and automatically installs the correct print driver. A notification lets you know when installation begins and when it is complete. You do not have to download any software or insert the product CD.
  1. Turn the product on.
  2. Connect the Universal Serial Bus (USB) cable to the product and to the computer.
  3. A Your devices are ready to use window might display on the screen. If the window displays and does not close automatically, close the window.
Good luck,
Steve
PS please vote for me or give a testimonial if I have helped.
Posted on Aug 06, 2010
Trying to reinstall printer software from disc. it quits during install. Is it because the computer has Vista and the disc is for Xp? I dont know how it was installed but it worked ok for a year. What do I...
go to the printer manufacturer's website and dnwnload the proper drivers from there. you will have to know if you have a 32 or 64 bit version of vista. to find out, go to "computer>system properties" and it should tell you on that screen whether you need the 32 bit or 64 bit drivers.
Aug 06, 2010 | HP DeskJet 3650 InkJet Printer
Hp 3650 wont reinstall from disk. disk is for xp,my computer is a vista. How it was installed in the first place I dont know.
Vista has drivers in the OS for this printer. Just plug in the printer and connect the data cable. Windows Update will handle the rest if you use the USB cable (you may have to search for updates). For a parallel port printer connection, use the New Hardware Wizard from the Devices and Printers part of the Control Panel.
I hope this helps.
Aug 05, 2010 | HP DeskJet 3650 InkJet Printer
Installallation of xp
the xp does not recognize the SATA hard disk of your computer, you must install SATA drivers during the installtion of XP.
Sep 16, 2009 | Microsoft Windows XP Professional With...
Help required installing OS (Changing OS ) myself on my HP dv9507
There are two procedures, [1]Reformat your hard disk and start a clean installation (this is the easiest thing to do, however not the most convinient) and [2] Using a genuine retail version [NOT a recovery disk] you could do some kind of downgrade [not as easy as it sounds]
I'll go back to solution number 1 (reformating the hard disk). Idearly, you'll want to back up your vista installation just in case things get messed up, then secondly you'll want to create a backup of all your files [dont worry about application data, you'll have to reinstall it all anyway]. After you're done, Insert your Windows XP disk, [it should ask you to press a key to boot from CD, if not you'll have to go into your BIOS and change the boot order], when you're into the setup, the guidelines are pretty simple, you'll have to run one of the formatting options in order to install XP [remember that formatting will erase everything from your hard disk, So I hope you did aBACK UP of all your DATA]...
As for procedure 2, Installing XP without reformating, well, let me know if you're up for the procedure and if you have an XP recovery disc
Jun 20, 2009 | Computers & Internet
Need help on installation disk for both XP and Vista, plus drivers for both. Thanks!
Download the missing software from HP:
http://h10025.www1.hp.com/ewfrf/wc/product?lc=en&cc=us&product=428800
May 22, 2009 | HP PSC 1510 All-In-One InkJet Printer
inser the CD in the CD reader and follow the instruction on the screen.
if you can't install the driver from the CD, then go on ine and go to HP.com http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&lang=en&product=64986
May 22, 2009 | HP OfficeJet D135 All-In-One InkJet...
Problem hp deskjet 3650
This printer does not have driver for Vista, if it is not recognised automatically it won't work on Vista.
If you have Windows XP
Un plug the printer from usb and reinstall the drivers from disk.
If you do not have disk, then download from here : Software & Driver downloads
Oct 25, 2008 | Microsoft Office Equipment & Supplies
I have got a hp pavilion dv 5000 i bught it 16 months ago with windows xp on it but i have put windows vista on it now i dont want vista do you have a restore disk to wipe off vista so i can have xp back...
Hi Harrison685,
Thanks for posting in FixYa.
Sorry Window Xp can not be retrieve back by restoring. You need to Reinstall it. Please use your Window XP Installation Disk for this.
Regards
ELLIN
Sep 16, 2008 | HP Computers & Internet
Can't open HP Director
You say it works with XP, so I assume it doesn't work with Vista? If that's the case you can download the newest Vista drivers HERE.
Hope that helps...
Geno
Mar 25, 2008 | HP Officejet 4215v All-in-One Printer
HP DeskJet 3650 InkJet Printer Logo
192 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
