Question about Magellan RoadMate™ 1212 Car GPS Receiver
I cannot get my gps to turn on - Magellan RoadMate™ 1212 Car GPS Receiver
  • 17,970 Answers
It is good that the temperature was at about 55 because these units will not charge at certain temperatures. I believe the lower limit for charging is the freezing point (32 degrees).
What about the power socket in the vehicle? Does it always have power applied, even when the ignition is not turned on? I know some vehicles turn OFF the power to the lighter and power sockets when the car is turned off.
Have you tried your car charger in another vehicle? Or have you tried another adapter, such as a cell phone charger, in the same power socket in the car? I am just trying to find out if there is power coming from the socket that you have picked. Also, try this:
* Press and hold the POWER button for 10 seconds.
* In the event the unit does not power on, reset it. The reset button is located on the bottom of the unit.
Let us know what happens.
Posted on Aug 06, 2010
TomTom 910 freeze, long turn on
It is possible that the map data(base) and/or the navigation software is corrupted.
Have you tried running a (fix) disk utility against your (internal or external) storage disk for the GPS ?
For instance, connect the GPS to your PC (Windows), and select (highlight) the (internal) "disk" on the GPS device. Under File - Properties, go to the Tools (tab) and run the "Error-Checking" option.
This utility may fix your data error.
If not, consider doing a restore (from backup) of your GPS disk storage.
Mar 26, 2013 | Tomtom GO 910 GPS Receiver
Ine-w927hd gps auto detecting problem
Unit: Alpine INEW927HD
ISSUE: GPS not working - spinning to connect
Symptom: GPS goes into an Off State
Screen states - Auto Detecting GPS Receiver - This went on for days.
My Fix to the issue: Hold down the reset button on the front of the unit for 15 seconds.
After the unit restarted GPS and Maps worked just fine.
Feb 23, 2013 | Alpine INE-W927HD - 7" In-Dash Navigation...
My garmin GPS says GPS off how do I turn GPS on
Look in the menus. There should be a setting to turn GPS on or off. if your GPS has a remote antenna, and it's not connected, make sure it is, that would cause the GPS to 'turn off' the GPS radio.
Feb 23, 2013 | Garmin Touch Screen GPS Receiver
My sat. nav is reading" GPS turned off." How do i
To turn GPS back on go to Tools > Settings > System > GPS Simulator "OFF". This will turn GPS back on.
Hope this Helps!
Feb 17, 2011 | Garmin nuvi 250W GPS Receiver
My Garmin GPS 12 Turns Black On turning on.
Try turning the unit on and hold the left arrow button down for about 10 seconds.
Apr 01, 2009 | Garmin GPS 12 GPS Receiver
New Nuvi 200 will turn on briefly then turn off.
You need to charge your gps from any external charger and check whether screen is working properly .
Also do firmware update for your gps .
By updating firmware your problem can be fixed .
Jan 22, 2009 | Garmin nuvi 200W GPS Receiver
I cant find my gps on my samsung omnia
I have a Samsung Omnia. If you go into settings you can turn on AGPS (assisted GPS) and download some addition software that helps gps. GPS is automatic but you can turn it off or allow windows mobile to manage it which is advisable. You cannot automatically see the GPS but you can buy or get third party software to see when GPS is working.
GPS gate works to turn gps on/off manual but this is just one software.
I have included a link to show where these settings are and if you want to use GPS gate. Note: I am not affiliate with GPS gate at all.
Nov 13, 2008 | Cell Phones
Zumo 550
Make sure that the bike's electrical connection to the GPS unit is actualy not having power once you turn the key off in the bike. This GPS turns on with external power. It is inherent in to its design.
In the case were you cannot have the bike's power source to the GPS turn off with the key, see if you can wire a small in-line switch in series with the GPS unit so that you have an external power switch. This should be easy to do.
The models I have used from Garmin have their own power switch. You should be able to use its power switch to turn it off.
Jerry G.
Jul 19, 2008 | Garmin zumo 550 GPS Receiver
Magellan RoadMate™ 1212 Car GPS Receiver Logo
32 people viewed this question
Top Magellan GPS Experts
Marvin
Marvin
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
