My nec 6.5kg nw 652 won't rinse or spin, just washes and i can't find my instruction book, its a fuzzy logic.
SOURCE: washing machine nec nw-652
I had the exactly the same problem and then got to the stage that it wouldn't work at all. So i looked it up in the manual and found out that it was the filter, (and thats not the lint filters like i originally thought lol) so i cleaned it out and now it works better than new. Hope this helps you cos it was such a relief that i didn't have to buy a new one.
Posted on Jan 10, 2008
SOURCE: My NEC NW 652 washing machine is showing an E9 fault
E9 means the waterlevel sensor is defective or the pipe connected to it is faulty.
Posted on Jan 27, 2009
heatman101
  • 43501 Answers
SOURCE: LG Top Loader Fuzzy Logic 5.5. The water
No you just need to get the drain hose up higher...the water is siphoning out and is either caused by the end of the drain hose still in water and not having an air gap or the hose is not going up higher then the top of your washer...
Lifting the hose up should give you an air gap and get the hose high enough to stop the siphoning...
heatman101
Posted on Apr 28, 2010
Testimonial: "I am extremely impressed that this won't cost a call out service fee. . . and looking like a bimbo. thanks, heatman!"
SOURCE: My NEC fuzzy logic 6.5kg washing machine will not
http://www.agent99.net.au/docs/nfl1265_user_manual.pdf
Have a look in your manual above.
Posted on May 29, 2010
blueextc3221
  • 15935 Answers
SOURCE: Smeg s750 washing machine -how to rinse only?
Advance the timer to rinse/spin part of cycle.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 10, 2010
I have a top lg fuzzy logic washing mechine, it stops at rinse position , display lights , gear are all working. whats the fault please ?
this usually happens when the water pump or the hoses are clogged and it cannot drain, it stops there and does nothing
Feb 10, 2015 | LG Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When I hit the power button the E9 message appears?
Sounds like the water level pressure sensor is not working. The code (E9) means the switch is open.
You'll need to replace the pressure switch. Check the manual for the repair procedures.
Apr 25, 2014 | Washing Machines
Hi i have an LG 5kg Fuzzy logic top loader and it will wash and fill the water but wont rinse or spin it does not beep or anything it just stops and the time displays stays on the same numbers and i can...
Need to check during the wash cycle that the power goes to the motor during the rinse or spin cycle. Try and see if you can manually go to the spin cycle without the fuzzy logic. If so the program controller unit is a suspect as the microprocessor internal memory is faulty and executes the program with error or no output.
Jan 21, 2011 | Washing Machines
Nec nw-891 washing machine will not complete the programmed cycle
Apparent malfunction in the timer circuits. Specific Component replacement not available.
Jun 30, 2009 | Washing Machines
Mar 16, 2009 | Washing Machines
My NEC NW 652 washing machine is showing an E9 fault. When i hit the power button the E9 message appears
Jan 13, 2009 | Washing Machines
Washing machine nec nw-652
i am having the almost the same problem with what i have, if it is turn, the water will just keeping on pouring in non stop, it does matter wether it is wash, rinse, dry or spin the water will just keep on pouring in at all time, it is not a good machine at all.
Sep 09, 2007 | Washing Machines
Washing Machines Logo
98 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
