FixYa.com
Tags:
Neon EL Wire / Wire
Did I kill my el-wire with current?
posted by kinetical on Apr 26, 2008
I was running el-wire off of a heavy duty 10 amp 12 volt power supply and it worked ok for awhile, then quit.  I thought the driver died but I have tried it with a working fish driver and nothing happens.  Can the el-wire be no good anymore or do I just have the wrong power supply?  It also doesn't work on a 9 volt.  It is several years old, like maybe 5.  How long is the stuff supposed to last normally?
Thanks for your advice,
Tracy
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 12, 2008
Not Rated (0)
mangoeater2
Rank:Guru Guru
Rating: 86%, 100 votes
I don't know anything about el-wire except what I have just read on this site:
http://www.elec2go.com.au/category5_1.htm
It looks like there are limitations to the inverters and length of liffe due to outputs and frequencies. Length of wire will govern which inverter to use.
Maybe your HD 10 amp 12 volt power supply simply burnt out the wire? Consider that (on the page I have just looked at) inverters are run on 2 AA batteries or 6v inverters and output 6 mAmps (not 12 volt and definitely not 10 Amp!). Is this Power Supply an inverter specifically for the el-wire?
Read up this web site (and others) and you may find the solution (and the cause of the problem).
Sorry I can't help any further than directing you to the Internet.
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these System Cooling problems?
System Cooling
driver
i face the problem about driver... Answer This...
System Cooling
damaged printed circuit board...
I don't think I'm in the right... Answer This...
System Cooling
Air Condition
Ac only works for a minute or... Answer This...
System Cooling
Trying to replace both the...
The easiet solution to changing... Answer This...
System Cooling
renault clio
does my clio 1.8i have a brake... Answer This...
Repair Service
Find System Cooling Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
