Question about Samsung Televison & Video
Child threw remote at tv and 1/3 of the screen has vertical lines going through it..the rest of the picture is good and sound is good.what do i do?
  • 10,594 Answers
OK, I'm not sure why you rejected chat assistance, anyway, lcd panel need to be replaced as mentioned in chat session and I gave you all required info for that.
Thanks.
Posted on Aug 06, 2010
  • 11,361 Answers
You will need new LCD panel, sell this one for parts and use the money to buy a new TV, LCD panel is the most expensive part of the TV.
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Picture was working day before I have sound but no picture just vertical lines moving from left to right, what is the cause
Sounds like,the TVs main power circuit is going bad.Can,try your,remote go to Input information for the TV.,and find energy saver on the power your using.,also check the screen size your using to.,go,to MENU .,on remote and find TV screen size.,adjust it.,that might help a bit.Good luck.
Sep 03, 2015 | Televison & Video
Picture blank
Maybe it needs to be replaced with something more up-to-date.
Jun 26, 2017 | Sharp LC32D62U 32 in. LCD HDTV
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Line across middle of screen, rest of screen black
The problelm is a defective vertical deflection system. Could be the amplifier, vertical output driver or whole printed board that supports the vertical deflection activity. It is considered to be a serious failure.
The cost of repair will be around $200 to $300.
Aug 05, 2009 | Hitachi 50UX58B 50" Rear Projection...
SanyoTV-blk screen w/thin line of light across screen great sound
Your Vertical Amp is probably Blown (bad) , but before you change that check all capacitors around the vertical amp IC and / or resolder resistors and diodes around vertical amplifier.
And NO it is NOT the Picture Tube
Good Luck
JG
Apr 18, 2009 | Sanyo DS27820 27" TV
Sharp lc46d64u screen has vertical green lines
Unfortunately my friend, there is not a whole lot that can be done. Sharp has a great limited warranty, but it does NOT cover ANY problems due to physical damage. Getting screens replaced often times cost more than the tv itself. Save yourself the trouble of getting pissed off at sharp because they wont help you if you decide to call and replace the tv. Good luck 2 u
Feb 16, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Sep 28, 2008 | Philips 50PFP5332D 50 in. Plasma...
Here we go again
Sounds like a deflection problem you will need to troubleshoot the deflection circuit.
Feb 26, 2008 | Panasonic PT-47WX53 47" Rear Projection...
Thin horizontal line
Solder bad connects in vertical circuit,especially vertical output
IC pins.................T.
Dec 26, 2007 | Toshiba 35A44 35" TV
No picture
You have an intermittant vertical sweep circuit! It could be the vertical out put IC solder connections on the printed circuit board, or maybe the IC itself has poor connections between the IC and the contact legs that mount the IC, or another componet in the vertical sweep circuit. If you know how to solder and unsolder, work on printed circuit boards, then you shoul have no problem replacing the vertical sweep circuit. Good Luck
Oct 09, 2006 | Panasonic CT-25G6 25" TV
Televison & Video Logo
57 people viewed this question
Jerry Greenberg
Jerry Greenberg
