Question about Kenmore HE2 Plus Front Load Washer
WE HAVE A FRONT LOAD HE2T. WHEN WE START THE WASHER IT ACTS LIKE IT IS NOT GETTING WATER. IT MAKES A GRINDING SOUND. PLEASE HELP. WATER IS TURN ON TO THE MACHINE
  • 2 more comments
  • dkmartin618 Aug 06, 2010
    THANK YOU FOR YOUR HELP. ALTHOUGH I DID DISCONNECT THE INNER HOSE AND TURNED THE MACHINE ON. I HAD A CUP INSIDE THE WASHER TO CATCH THE WATER AND IT FILLED THE CUP IN A COUPLE OF SECONDS. I THINK THE VALVES ARE WORKING.
    I AGREE ABOUT THE PROBLEMS BUT I CANNOT TAKE IT BACK TO SEARS NOW. STILL NEED HELP.
    AFTER FURTHUR INVESTIGATION I FOUND THE GEARS ON TOP OF THE SOAP BOX ARE HANGING UP. HOW DO I FIX THIS?
    PROBLEM IS NOT WATER INLETS IT IS THE "PLASTIC" GEARS ON TOP OF THE SOAP BOX. CAN I REPLACE THESE AND HOW.
  • Kenmore Master
  • 8,220 Answers
  • 15,935 Answers
Replace the water inlet valve on the machine.
Thanks!!
Posted on Aug 06, 2010
  • 4,070 Answers
The water inlet valve is on the back where the hoses connect to the washer. See if that's where the noise is coming from. That would mean it was trying to open but is stuck and need to be replaced. It is a dual valve with two valves. One for hot ,cold and it mixes for warm.
  • 10,865 Answers
Hello. Many consumers feel that they got taken with this expensive machine... more problems than most for sure. Here is a link that you should peruse. http://www.epinions.com/msg/sec_~forums/show_~threads/cat_id_~17/id_~6621/forum_id_~409/pp_~2
J.
  • 11,896 Answers
If you hear the grinding sound, don't run the machine! That is your water pump trying to run without water. That means your water inlet valves are not opening. They are inside your washer. The inner and outer hoses connect to it. You can test power to the valves with a voltmeter. If you are getting power, than the valves are not functioning.
  • Nate Stansfield
    Nate Stansfield Aug 06, 2010
    If the water is coming through the inlet hoses, mabey the pump is blocked and not getting the water. Or the pump may be jammed with something.
F-24 error code so I ran a clean washer cycle, and the laundry room is now flooded.
what's f24 code? - Kenmore Elite HE3 Washing Machine ...
https://www.ifixit.com/Answers/View/85549/what's+f24+code
iFixitAug 21, 2015 - Aiman, The F24 error code indicates a water temperature sensor reading that is ... The Kenmore Elite HE3 is a washing machine by Kenmore.
F24 Error Code on My Kenmore Washer ' eHow
www.ehow.com > Home
F24 Error Code on My Kenmore Washer. Kenmore washing machines have several high-tech features, such as a stain treatment option, reduced energy and ...
Kenmore HE2 Plus Front Load Washer F24 error code ...
www.fixya.com > ... > HE2 > Kenmore HE2 Plus Front Load Washer
...error code F24 I have a Kenmore HE2T washer and I keep getting an F24 error on it.. I have no idea what is means can't find the manual help!!! The "F24" error ...
I have a Kenmore HE2T error code F24 - Fixya
www.fixya.com/support/t3608391-kenmore_he2t_error_code_f24
Dec 9, 2009 - Posted on Dec 09, 2009.
Dec 06, 2015 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE2t i keep getting error f21 i cleaned the trap and it still does it
You may have to unplug it for about 15 minutes and try again. I had a similar problem and this helped.
Mar 19, 2014 | Kenmore HE2t 3.7 cu. ft. Front Load Washer
I have a model #110.47561601, Kenmore HE2t Front load washer Type 832. I am getting a code of F-24, when I try to start the cylce. What is the problem that prompts a F-24?
Hello
F-24 is a water temp snsor error.Try running the machine in spin and drain.Once empty unplug machine for 3 min.Then try load of wash again.This time use cold water until error clears.
Aug 27, 2011 | Kenmore HE2 Plus Front Load Washer
Every time I start my Kenmore HE2t washer there is
If it has a clean cycle that says, "Bleach Only," run it with 1/2 cup bleach right in the machine. If not, run it on the longest, hottest cycle you have. In the future, leave the door open slightly between loads.
Oct 29, 2009 | Kenmore Elite 45986 Front Load Washer
The washer will not spin
my washer will not finish spin and reins cycles please HELP ME
Jan 10, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Frigidaire front load washer FWT449GFS1 grinding sound
If the tub seal lets go water will weep into the tub bearing. This will rust the basket shaft and normally wreck the tub bearing. Once the bearings starts to get worn enough it usually gets very noisy. The tub bearing is pressed onto the outer back half of the tub shell assembly. Normally need to replace the inner basket/shaft assembly and the outer shell with the tub bearing.
Sep 07, 2008 | Frigidaire GLTF2940ES Front Load Washer
Making a grinding sound
I had the same problem. Turns out there was part of a pen stuck in the pump. First load after the technician left, same problem. Once they remove the rest of the pen still in the pump, problem no longer exists.
Aug 14, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag MAV7700, Grinding and water leak
open the front with a puttyknife there are 2 clips about 4" in on each side this wil open the top so you can remove the 2 screws holding the front panel on once removed you can see the guts of the unit..Let me know if you need more help
Jan 28, 2008 | Maytag MAV7600 Top Load Washer
2006 kenmore smartwash quietpak4 he3t F20 code washer
F20 ERROR CODE ON A KENMORE HE2T FRONT LOAD WASHER.THE FIX FOR ME WAS TO REPLACE THE TUBE THAT RUNS FROM THE PRESSURE SWITCH TO THE BOTTOM OF THE WASHER.YOU MUST REMOVE THE TOP AND BACK COVERS OF THE MACHINE(EASY).REPLACED TUBE WITH3/16 INCH CLEAR TUBE.THE ORINGINAL TUBE HAD A PIN HOLE FROM RUBBING AGINST THE SIDE OF THE MACHINE AFTER 5 YEARS OF USE.THIS COST UNDER $10 DOLLARS TO FIX. NO SERVICE GUY=MORE BEER MONEY GOOD LUCK.
Nov 07, 2007 | Kenmore Elite 45986 Front Load Washer
Kenmore HE2 Plus Front Load Washer Logo
46 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
