Question about LG Computers & Internet
I have a brand new computer(no operating system) and I can't get anything to be displayed on the monitor. I can't install the Monitor drivers without the operating system(can I?), and I can't install the operating system without a monitor. Should the monitor be working out of the box without any driver installs?
  • LG Master
  • 5,568 Answers
Every monitor I have seen in the last decade would put a notice on the screen if the input cable is detached. It should say something like "Monitor is working-check cable" or "No input."
Regardless of operating system you wish to install, any of them will choose a basic VGA resolution or at least text, to display the first messages, and if the monitor is working, you should also be able to see the initial text messages from the BIOS.
If you are seeing nothing under any of those mentioned conditions, you may just have a 'DOA' monitor; it happens.
Posted on Aug 06, 2010
27" monitor display not magnifying to fill edges
To help you we'd need to know what Computer Operating system you're using, and what computer brand you're using. VGA is a bad choice, you need the others; the reason they're grayed out is probably due to a missing driver for your graphics interface, and so you'd need that first. Then once you have other options, it would be an easy fix. So, the real problem appears to be: How do I install a graphics driver for my computer, and we'd need information to help you with that! :-)
Jul 03, 2017 | DoubleSight DS2700DW Monitor
My Monitor ViewSonic E70fSB 17" Monitor is working
Causes of OSD LOCK
1. The monitor is incompartible with the system unit, especially for newer version units versus older monitors
2.Older monitors display attempting to much up to the improved definition functions of newer system units display an operating system malfunction, interpreted as monitor malfunction instead. OPERATING SYSTEM DISPLAY MALFUNCTION
hardware checks
1. consider changing the graphic card on the system unit after attempting to adjust the appearance settings on the desktop once the computer is powered on.
2.Once changing the graphics card on an old system unit, consider changing the processing chip for reasons of achieving peak performance of the new part installed.
3. Once the fxing of the parts are complete, the monitor would continue to display OSD requiring entire system restart or book. after which, adjusting the appearance setting that should by which time display new list capacities due to the new device changes
Dec 06, 2010 | ViewSonic E70f 17" CRT Monitor
No display on a brand new Samsung EX2020 monitor.
mcdevito75 here Refer to the instalation instructions that came with your new PC and monitor, Also you cantry to hit the auto switch on the monitor or check with the menu on the monitor, press menu and see instructions / options.
Jul 03, 2010 | Samsung SyncMaster 2233BW 22" LCD Monitor
Can't find driver for my monitor for XP... can somebody help me?
I have located the driver for your Hannspree HW173DB0 monitor. Click here go to the official download page
Jun 14, 2010 | Hannspree HW-173DB0 Monitor
Unable to load display driver for Pavilion t3000, Dell Monitor
What operating system do you use? When you boot up your computer, can you see anything on the screen.
If you can, just load the drivers for the monitor from the CD when you boot into windows.
If you can't see anything, you need to connect a different monitor or there is possible issues with the video adapter built into your motherboard.
Jul 12, 2009 | Computers & Internet
Screen will not display
Have you ensured that your display card driver AND correct monitor driver is installed. This is to make sure that your display card only generates signals that your Acer monitor is capable of handling. If you do not have the driver CD for your monitor you can download the software from www.acer.com. The problem is most likely that your display card is generating a refresh rate which your monitor cant handle. Go to your display properties and lower the refresh rate of your display card and see if this solves the problem.
Best wishes,
Graemevm
Jun 29, 2009 | Acer H233H bmid Monitor
BRAND NEW MONITOR OUT OF THE BOX? DRIVER WILL NOT LOAD. DRIVER WONT LOAD FOR HP W2007 WIDE LCD MONITOR (32 BIT) HAVE DISK. (STILL WILL NOT LOAD)
This monitor doesn't need a driver installed. If you can see an image on it, you don't need the driver for it. Windows will install the default monitor driver, and that works for 99.99% of monitors on the market. You need to go into the Display control panel and change your resolution. If the monitor's native resolution isn't available as an option in the control panel, it's because your video card can't display it, not the monitor's fault.
Jun 17, 2009 | HP W2007 LCD Monitor
Display on mac mini only shows no signal and turns black
his step-by-step guide describers how to obtain and install ViewSonic VA720 drivers for Mac.
1. Define your ViewSonic Monitor device model.
2. Define your operating system to install your ViewSonic Monitor device. Note: Update Drivers in Mac
3. Browse Monitor Drivers.
4. Find ViewSonic Monitor Drivers.
5. Select ViewSonic VA720.
6. Download ViewSonic VA720. Note: you can update all Drivers automatically with RadarSync (Freeware) or Driver Detective (Shareware).
7. Install ViewSonic VA720.
8. Restart or reboot your computer to finish your driver installation. Note: you can backup your computer drivers before updating.
May 03, 2009 | ViewSonic VA720 17" LCD Flat Panel Monitor
Display problem with ViewSonic VX1962wm 19" wide monitor
id say this is a compatability issue before interference from other sources(Undefineable)
Jan 30, 2009 | ViewSonic VX1962wm LCD Monitor
New 17" monitor, display is wide and short, not proper proportion
The monitor should have came with an installation or drivers cd. Use this disc to install the monitor specific drivers for your operating system. If you do not have the cd then you should be able to download them from the support section of your monitor manufacturers website. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | E-Machines 17" Widescreen Flat Panel LCD...
Computers & Internet Logo
53 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
