Question about Watts Onan Portable Generator - 4000 , Model# 5500
When i start the onan 5500 it takes 4 or 5 times then when it does start it runs low then high rpm then low again where do i start
  • 144 Answers
Adjust the carberator. You have to do this while the engine is running and it usually takes a straight slot screwdriver. You can turn a spring loaded screw to adjust fast or slow which ever is needed.
Posted on Aug 05, 2010
The generator surges and stops while rv is in motion.
Did you get this fixed? this is an old post. If not visit www,advanced-power-technologies.com (Cert Cummins Dealers) They can answer your questions.
Oct 05, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Where is the fuse on the onan 5500 built in generator?
Try under the bench seats around the table, near the heater.
Jul 14, 2014 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan 5500 marque gold turns over but, won't start. fault code is 32 but, batteries ok, air cleaner ok, fuel pumping, oil changed, won't start
Code 32 is a low cranking speed sense. You didn't mention a Spec # which would help. You say batteries are ok, but the generator is not getting enough cranking amps or voltage to maintain the control properly. Check, battery voltage, wiring, any in line isolation solenoids, check generator solenoid, also make sure there is no mechanical binding on the generator, a good way to do that is remove the spark plugs DISCONNECT THE BATTERY to prevent starting, underneath where the air intake is under the alternator is a plastic plug, remove that and you can put a socket I believe 3/4" up onto the alternator shaft and rotate the engine, if it tuns freely there is no binding, if you feel it is hard to move, check the drive train, belts, pulleys underneath (A lot of work, best to take to a dealer if it is mechanically bound)
Sep 13, 2012 | Onan Marquis Gold Quiet Gas Generator 5500...
Onan 4 ky generator quits when a/c is turned on? Has no other load on it.
Is your generator 4 kW or 4000 Model 5500.
If 5500 as on the picture over your question the reason may be short in the receptacles or low voltage/ rpm.
If 4 kW MicroQuiet, there the reasons may be too much, that you will nead a troubleshooting manual.
Jun 14, 2010 | Watts Onan Portable Generator - 4000 ,...
Onan 5500
well they have an expensive card in there that controls rpm and voltage to maintain 120v. there is a safety for oil temp in some of those maybe bad try bypassing it after it heats up to pin point it. maybe time to clean brushes?
Apr 13, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan generator MODEL 7NHM FA 26106 F
4psi is the correct parameter for this unit.
Mar 01, 2009 | Watts Onan Portable Generator - 4000 ,...
Onan 20K Generator runs constantly in stand by mode
Your remote start wires going into your transfer switch are closed, which means you transfer switch is the problem.
Feb 11, 2009 | Watts Onan Portable Generator - 4000 ,...
Watts Onan Portable Generator - 4000 , Model# 5500 Logo
313 people viewed this question
Top Watts Electrical Supplies Experts
rlev_7
Level 1 Expert
Steve
Are you a Watts Electrical Supply Expert? Answer questions, earn points and help others
