Frigidaire Tumble Action washer 2005 Water is not pumping out. I removed pump from front panel. Very hot to touch. What would you suggest?
  • 343 Answers
Check first that the pump isn't jammed with a coin or similar. This can cause heating...
The other most likely cause is a failed, or failing pump motor. Replace the pump motor and if all else is ok, the problem should go away..
Good luck....Nomess
Posted on Aug 07, 2010
My frigidaire wont spin or wash
Remove the 2 screws on the top panel and remove the panel. Check the wiring connections on the control board.
Nov 11, 2012 | Frigidaire GLTF2940FE Front Load Washer,...
It will not let the water out or spin I think it is the water pomp how do I change the pump I have a frigidaire tumble action washer
First try pressing the start and cancel buttons for about 3 seconds and see if there is an error code, then you can troubleshoot from there....Have you checked the drain lint trap? It is inside the accordian looking drain hose that attaches the drum to the pump. It may be clogged. Use a wet/dry shop vac to remove as much water as possible. Unplug the machine. then remove front panel and remove clamps to check if it is clogged. Hopefully that is the problem!
Mar 25, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Need to replace water pump in Frigidaire tumble action front loading washing machine. Parts are hard to reach/get to. Is there a step by step for the process available?
After unplugging the machine, turn it around and remove the rear cover, After that all the parts are relatively easy to access and it will be obvious how to replace the water pump.
Feb 13, 2011 | Frigidaire 14 Cycle Tumble Action Washer
Want drain water out giving e20 error
Hi
Error code e20 means a clogged drain pump. This might have happened due to small clips, pins, coins, etc being stuck in the pump. Please note that error e20 can also occur when the drain pump is not pumping fast enough or when the pump fails. To fix the issue you'll need to check the drain pump.
Remove the 2 screws from the bottom of the front access panel, it will come off. Now check for the pump on the right side and remove hoses from it. Remove pump from machine then remove whatever is there in the pump. Hope this helps... Please post back for any further assistance.
Jan 13, 2011 | Frigidaire 14 Cycle Tumble Action Washer
I have a 7 year old Frigidaire washer (Model #GLWS1349AS1) and the water drains really slow and the spin starts before all the water is drained and then the washer leaks as water is still in it during spin...
you have a restriction in the drain somewhere or there is something inside the pump housing,chk every line from the tub to pump to drain pipe and hoses for blocks or kinks
Apr 09, 2010 | Frigidaire FTF2140ES King Size Front-Load...
Water Will not drain after cycle
The filter for the drain is located under the drum assembly. It is inside the rubber cover between the drum and the pump. It has 3 clamps that you will need to remove, than you can get at the filter inside the rubber housing. It will be clogged with coins, or lint from the wash, and once this is cleaned, the machine will work like new.
Joe the Plumber
Mid Hudson Heating & Plumbing
Woodstock, NY
Jan 03, 2009 | Frigidaire ATF6000ES Front Load Washer
What can I do to repair water not draining out of tub?
remove bottom access panel(2 screws on each corner of bottom)look on rt side,you will see pump with a rubber boot and clamp connecting them together.bail water out of tub and remove clamp on pump and clamp on drain.there will be some water,have some towels handy.remove connector(2wire electrical connection).you will see 2 5/16 screws holding pump down onto base(remove)look inside impeller and remove item jamming it and reinstall.if there is nothing in pump,replace it..good luck
Sep 28, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Leak
remove bottom panel 2 screw ckd pump and connecting hoses ckd drain hose in particular then have been known to crack
Jun 03, 2008 | Frigidaire FTF2140ES King Size Front-Load...
Frigidaire Front Load Washer Shrinking clothes
check to make sure you water line arnt hooked up backwards. if hot is to cold and cold to hot your washing in hot water when your trying to use cold
Nov 20, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Frigidaire Tumble Action Washer won't move to the next cycle
your pump is blocked or faulty a way to check is pull your washer out put your outlet hose to the ground placed either in a bucket or out the door if water comes out pump is faulty if it doesnt than its blocked were your outlet pipe goes into back panel is were your pump is make sure washer is switched off undo tip up undo clamp water will come floding out better of doing this outside if it comes out of pump than your pipe is blocked
Aug 13, 2007 | Frigidaire 14 Cycle Tumble Action Washer
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
