Question about Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
Water is leaking inside the fridge - Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser
  • jacob_f Jan 18, 2009
    I have a whirlpool fridge and water is dripping from the top inside seems to be comming from the freezer
Wateer is leaking inside fridge.
Posted on Dec 03, 2008
How come fix wate r leaking inside
Posted on Sep 04, 2012
2 Suggested Answers
Gort007
  • 1187 Answers
SOURCE: water leaking from the roof of the fridge inside.
That is condensation. The rubber insulator (gasket) on the door may be damaged or worn. The door does not close and seal properly.
Make sure that nothing that is on top of the refrigerator is "hanging" into the path of the door seal (like a bread bag ponytail).
Also to consider:
Door hinge is loose so that door is not aligned for proper door seal.
Refrigerator is not "level" so that door is not ...
Freezer is defrosting (heating elements will warm up the coils, so "dew point temperature" may have been reached.
Check the door gaskets.
Posted on Sep 21, 2009
I have a water leak inside of my maytag fridge and it leaks out onto the floor from the inside. What is the couse of this problem?
Have you checked to see if your condensation tray is too full? The tray will be located at the bottom of the fridge and should slide out easily.
Feb 19, 2012 | Maytag Refrigerators
Hoover Contour refrigerator HE383TF. Water is leaking inside the fridge. It appears as a puddle under the vegetable compartment and then leaks onto the floor. I have completely defrosted and then poured...
Could be the little red stopper at the back of the fridge on the inside has come off, and this is where the water is coming from, look inside on the lower shelf and you will see a round opening which should have a red stopper in it.
Dec 30, 2010 | Hoover Refrigerators
Water leaking from inside the fridge
Clear ice build up from drain plug using hot water in a syringe. Works well I just did mine. Located behind access panel inside fridge. Blue tube running down the back. Pull down and remove ice from the drain at the top.
Jun 22, 2010 | Refrigerators
My fridge is leaking water inside of the main fridge compartment. It is coming from the top and I can see water dripping out of one the hole. There are two small one inch square holes near the back top...
The defrost drain hole is frozen over.
When your fridge goes into defrost mode the water has no where to go but inside the fridge,not down the drain hole.
Turn the fridge off for 24 hours and open the doors. Let it defrost naturally to clear it out.
May 23, 2010 | Whirlpool Refrigerators
Water is leaking onto the inside floor of the fridge. when u used the water dispenser it leaks even more
You have a leaking water tank inside the refrig behind the crispers . The tank ( now plastic hoses ) is easily replaceable . Called a water resevoir technically .
May 12, 2010 | Refrigerators
Water leaking from underneath. Not currently
This could be a blocked drain.Behind the fridge is a hose/pipe running from the inside of the fridge down to the compressor where the water will then evaporate.If this pipe is blocked,the water will push up back into the fridge.Try to blow the hose clean from inside the fridge.This should solve your problem.
Regards
Andre Nagel
Mar 13, 2010 | Freezers
Water leaking from underneath fridge
If you have a ice maker inside your freezer, check where the water connects to the back. I think you will find a leaking connection. Tighten connection to fix the leak.
Please rate this solution
Sep 06, 2009 | Frigidaire Refrigerators
Fridge constantly dripping wet
water inside, too much condensation from humid air entering fridge from bad seals. replace the seals. could also be that the condensate drain is clogged. if it's leaking from the bottom of the fridge, make sure the tubing is still inside the condensate pan underneath the fridge.
Aug 24, 2009 | Whirlpool Freezers
Puddles of water in Fridge
you may want to check your door seal, air leaking thru the door seal causes condesation,also make sure that the drain tube is clear under the defrost element in your freezer.
Dec 18, 2008 | Refrigerators
Water leaks when filter is connected
Does it leak from the back or the front of the appliance ??
Aug 25, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Kenmore 18.3 cu. ft. Top Freezer Refrigerator w/Through-the-Door Water Dispenser Logo
481 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Arnel
Arnel
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
