Question about HP Mini 1000 Netbook
I get the following message on startup: "Windows could not start because the following file is missing or corrupt: \windows\system32\config\system" Is there any way to solve this problem?
  • 31 Answers
As the message says, “Missing/Corrupt”
You have to Reformat you Computer...
Salim
Posted on Aug 06, 2010
I have an evo n610c and it started up with a message that says, "Windows could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM You can attempt to repair thi
To repair missing or corrupted system file/s, boot up with the Windows installation CD then - Press R to repair when instructed. Press 1 or Enter to repair the C:\Windows folder. Then type chkdsk /r and then press Enter. The repair process will take quite a long time.
Feb 15, 2013 | HP Compaq Evo n610c Notebook
Acer aspire 1 startup main 339: mscomctl.ocx missing or incomplete
It seems that this file is corrupted or missing. What you can do is to manually replace this file. Follow the steps below to replace the file.
  1. Download the mscomctl.ocx file to your desktop (right-click on link and choose 'Save link as...')
  2. Then go to My Computer > C: > WINDOWS > SYSTEM folder to check if you have a previous version of the mscomctl.ocx file. If yes, just make a backup of it.
  3. Copy the downloaded file from the desktop and paste it in C: > WINDOWS > SYSTEM folder.
After replacing the file, you will need to register the newly downloaded file. To do, follow the simple following steps.
  1. Click on 'Start' button and click on 'Run'
  2. In the 'Open' line, type : regsvr32 \windows\system32\MSCOMCTL.OCX
This command will register the file you have downloaded and added to the SYSTEM folder. You should see a message saying "DllRegisterServer ... succeeded" if registration is OK.
Please note that you have to enter the command exactly as it appears above. (You may copy and paste it).
May 10, 2011 | Acer Aspire One PC Notebook
Ntfs is missing
To resolve this problem, replace the missing or corrupted Ntfs.sys file:
  1. Use the Windows Vista startup disks or the Windows Vista CD to restart your computer.
  2. When the "Welcome to Setup" screen appears, press R to select the To repair a Windows Vista installation using Recovery Console, press R option.
  3. Type the number of the Windows installation that you want to access from the Recovery Console, and then press ENTER.
  4. Type the administrator password when you are prompted, and then press ENTER. If no administrator password exists, just press ENTER.
  5. At the command prompt, type the following commands (press ENTER after each command): cd \windows\system32\drivers
    ren ntfs.sys ntfs.oldNote This step renames the corrupted Ntfs.sys file to Ntfs.old. If the Ntfs.sys file is not found, the file is missing.
  6. At the command prompt, type the following command, and then press ENTER: copy cd:\i386\ntfs.sys drive:\windows\system32\driversWhere cd is the drive letter for the CD-ROM drive that contains the Windows Vista CD, and drive is the drive where you installed Windows Vista .
  7. Remove the Windows Vista CD from your CD-ROM drive, type quit at a command prompt, and then press ENTER to quit the Recovery Console.
  8. Restart the computer.
  9. rate me 4 thumbs up please
Jan 10, 2011 | Microsoft Windows Vista Home Premium with...
Misssing partmgr file how can I load this thanks
To resolve this issue, start the computer from the Windows XP CD, start the Recovery Console, and then use the Bootcfg.exe tool to rebuild the Boot.ini file. To do this, follow these steps:
  1. Configure the computer to start from the CD-ROM or DVD-ROM drive. For information about how to do this, see your computer documentation, or contact your computer manufacturer.
  2. Insert the Windows XP CD-ROM into your CD-ROM or DVD-ROM drive, and then restart your computer.
  3. When you receive the "Press any key to boot from CD" message, press a key to start your computer from the Windows XP CD-ROM.
  4. When you receive the "Welcome to Setup" message, press R to start the Recovery Console.
  5. If you have a dual-boot or multiple-boot computer, select the installation that you have to use from the Recovery Console.
  6. When you are prompted, type the administrator password, and then press ENTER.
  7. At the command prompt, type bootcfg /list, and then press ENTER. The entries in your current Boot.ini file appear on the screen.
  8. At the command prompt, type bootcfg /rebuild, and then press ENTER. This command scans the hard disks of the computer for Windows XP, Microsoft Windows 2000, or Microsoft Windows NT installations, and then displays the results. Follow the instructions that appear on the screen to add the Windows installations to the Boot.ini file. For example, follow these steps to add a Windows XP installation to the Boot.ini file:
    1. When you receive a message that is similar to the following message, press Y: Total Identified Windows Installs: 1
      [1] C:\Windows
      Add installation to boot list? (Yes/No/All)
    2. You receive a message that is similar to the following message: Enter Load Identifier This is the name of the operating system. When you receive this message, type the name of your operating system, and then press ENTER. This is either Microsoft Windows XP Professional or Microsoft Windows XP Home Edition.
    3. You receive a message that is similar to the following: Enter OS Load options When you receive this message, type /fastdetect, and then press ENTER.
      Note The instructions that appear on your screen may be different, depending on the configuration of your computer.
  9. Type exit, and then press ENTER to quit Recovery Console. Your computer restarts, and the updated boot list appears when you receive the "Please select the operating system to start" message.
Apr 13, 2010 | Computers & Internet
On startup cannot find script file 'cleanvirus.vbs'
May be you affected with a virus or missing some files...try to restore go to start /Accessories/System tools/System restore...try it
Feb 04, 2010 | Microsoft Windows XP Home Edition
Following repair by an anti-virus file UACxitmtbjtwv.dll seems to have been damaged or removed, can you help? I need to replace / repair this file but don't have original discs, can I download? Regards,
I can't find any mention of this dll file anywhere. I believe that what you have is a remnant of a virus. I think it was a program that was set to run when Windows started up that probably kept reinfecting your computer with the virus and now that you have repaired the virus, this program is still trying to start but is missing that file. I would recommend running "msconfig" and going into the startup configuration and seeing if you can find any unfamiliar programs that are loading on startup. It will probably be a trial and error type of troubleshooting where you disable and enable them one at a time and try to find which program is causing that error message for that file when it loads. It could also be under "Start" "All Programs" >"Startup".
Jan 09, 2010 | Microsoft Windows Vista Home Basic Edition...
Message read/ missing export user 32.dll update layerd window.
Greetings,
To resolve this issue, follow these steps:
  1. Restart your computer using the Windows 98 or Windows Me Startup disk.
  2. On the Startup menu, choose the correct CD-ROM support for your computer.
  3. Type the following commands, pressing ENTER after each command:
    c:
    cd <windows>\system
    ren user32.dll user32.dlx
    ren gdi32.dll gdi32.dlx
    ren winmm.dll winmm.dlx
    <ramdrive>\ext.exe
    where <windows> is the name of your Windows folder and <ramdrive> is the virtual drive created by the boot disk (probably e:\ or f:\).
  4. Type the following line, and then press ENTER: For Windows 98:
    <CD-ROM drive>:\win98
    For Windows Me:
    <CD-ROM drive>:\win9xwhere <CD-ROM drive> is the drive letter assigned to your CD-ROM drive. Note that this letter may be different when you boot your computer with the Windows Startup disk.
  5. Type the following line, and then press ENTER:
    user32.dll gdi32.dll winmm.dll
  6. Type the following line, and then press ENTER:
    <drive>:\<windows>\system
    where <drive> is the drive on which Windows is installed, and <windows> is the folder containing Windows.
  7. Review the information displayed. If it is correct, press Y.
  8. Type the following commands, pressing ENTER after each command: cd
    ren Cmapieng.vxd Cmapieng.vxx
  9. Restart your computer.
  10. Once Windows has restarted, run the Defragmentation application.
When Ext.exe has finished extracting the files, follow these steps:
  1. Remove the Windows 98/Me Startup disk, and then restart your computer.
  2. Press and hold down the CTRL key as your computer restarts. On the Windows 98 Startup menu, select Safe Mode.
  3. After Windows starts, on the toolbar click Start, point to Settings, click Control Panel, and then double-click Add/Remove Programs.
  4. On the Install/Uninstall tab, click any utility that you have installed, and then click Add/Remove to remove the utility. Repeat this step to remove any utilities you have installed.
  5. On the toolbar click Start, point to Settings, and then click Taskbar And Start menu.
  6. Click the Start Menu Programs tab, and then click Remove.
  7. Double-click Startup, click the appropriate entry, and then click Remove.
  8. Click Close, click OK, and then restart your computer.
  10. In Microsoft System Information, on the Tools menu, click System File.
  11. Click Settings, on the Advanced tab, click Restore Defaults, and then click OK.
  12. Restart your computer.
Sep 20, 2009 | Microsoft Windows 98 for PC
Laptop won't start up in Windows due to a missing or corrupt file
No all you have to do is follow its instructions and use the Windows XP cd and during startup boot to the cd and during installation choose the repair option.
This will not make you lose any files and then you will be able to get in and back to work or whatever it is for again.
Dec 18, 2008 | Toshiba Satellite A100-S8111TD Notebook
Problem with pc
Here is the solution right from Microsoft.
SYMPTOMS
When you try to start or restart your Windows XP-based computer, you may receive one of the following error messages:
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SYSTEM
Windows XP could not start because the following file is missing or corrupt: \WINDOWS\SYSTEM32\CONFIG\SOFTWARE
Stop: c0000218 {Registry File Failure} The registry cannot load the hive (file): \SystemRoot\System32\Config\SOFTWARE or its log or alternate
CAUSE
This issue can occur if the System or Software hive for the Windows XP installation is missing or damaged.
RESOLUTION
To resolve this issue, use one of the following methods.
Use the Recovery Console Tool
To restore a damaged registry hive, use the Recovery Console to restore the backup copy of the hive from the Repair folder. The Repair folder contains a copy of the system's registry hives that were created after the first successful startup of Windows XP.
WARNING : Although data should not be affected by the following procedure, you may need to restore changes you previously made to programs or system settings since the first time you successfully started Windows XP.
To replace the damaged registry hive and restore the backup copy of the hive from the Repair folder: Start your computer to the Recovery Console.
Determine if the file that is mentioned in the "Symptoms" section of this article is present, and if it is, rename it:
In Recovery Console, change to the c:\Windows folder.
Type cd sytem32\config , and then press ENTER.
Type dir system , and then press ENTER.
If you cannot run the preceding command successfully (because the file is missing), skip to step 3. If you can run the preceding command successfully, type ren system system.bak , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type ren software software.bak (instead of ren system system.bak ), and then press ENTER.
Type copy c:\windows\repair\system , and then press ENTER.
NOTE : If the message that you received referred to the software file, replace "system" with "software" in the preceding command. For example, you would type copy c:\windows\repair\software (instead of copy c:\windows\repair\system ), and then press ENTER.
You should receive a "One file copied" informational message. For additional information about how to use Recovery Console during startup, click the article number below to view the article in the Microsoft Knowledge Base:
Q307654 HOW TO: Install and Use the Recovery Console for Windows XP
IMPORTANT : If you encounter problems when you run the preceding commands, you may need to use the Change Directory command ( cd ) one folder at a time before you run the preceding commands. For example, type cd system32 , press ENTER, type cd config , and then press ENTER.
Type exit , and then press ENTER to quit Recovery Console and restart the computer.
Oct 23, 2007 | Computers & Internet
Startup problem
From: http://www.computerhope.com/issues/ch000646.htm If the ntoskrnl.exe file is corrupt or missing this can also generate the error. To restore this file follow the below steps. 1. Insert the Microsoft Windows XP CD. Note: If you have a recovery CD or a restore CD and not a Microsoft Windows XP CD it is likely the below steps will not resolve your issue. 2. Reboot the computer, as the computer is starting you should see a message to press any key to boot from the CD. When you see this message press any key. 3. In the Microsoft Windows XP setup menu press the R key to enter the recovery console. 4. Select the operating system you wish to fix, and then enter the administrator password. 5. Type expand d:\i386\ntoskrnl.ex_ c:\windows\system32 6. You will then be prompted if you wish to overwrite the file type Y and press enter to overwrite the file. 7. Type exit to reboot the computer. If you only have a restore CD, this probably won't work. You should just start the restore all over again, if this is the case.
Jun 05, 2007 | Acer Aspire 5003WLMi Notebook
HP Mini 1000 Netbook Logo
232 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
