A triangular piece of paper measures 8cm, 12cm, and 15cm. what is the perimeter of the piece of paper?
    President:
  • 2,678 Answers
35 cm
Posted on Aug 05, 2010
What is the perimeter of this chicken?
Chicken???
11 is a prime number so the only number it is divisible by is 1 or itself. So if it was a piece of material it would measure 11 feet by 1 foot so the perimeter is the sum of the four sides (11+11+1+1) which equals 24 feet.
If it was circular the perimeter would be a little over 23.
Oct 20, 2015 | Office Equipment & Supplies
Tip
Removing a recessed downlighter
To remove a small recessed downright from a paperboard ceiling first isolate the power supply
then gently prise the fitting slightly away from the ceiling about 1cm and measure the size of the hole in the paperboard. (It's probably about 7cm)
Get a piece of hardboard or plywood about 15cm x 15cm (6"x6") . Cut a U shaped slot the same width as the hole (7cm in my case) to make shield to fit around the cylindrical part of the light and protect the plasterboard
Now, holding the shield in place with your thumbs, pull the light further out with your fingertips until you can see the springs that are holding it in position .
Use long nosed pliers to compress the coiled part of a spring you should then be able to prise it off the lugs on the light fitting. Do the same with the other spring and the fitting will be released.
on Feb 22, 2018 | Home
The perimeter of one square exceeds that of the another by 12 cm and its exceeds twice the other by 14 cm sq.unit. find the sides of the squares?
There are two solutions:
The two squares are 1cm and 4cm respectively, or 5cm and 8cm respectively.
If this is homework, be sure to show your work.
Oct 05, 2014 | Office Equipment & Supplies
Volume of a cylinder formula
Volume of a right circular cylinder of radius r and height h is
V=PI*(r^2)*h
Figure out which is the radius and which is the height, then plug in the formula above. Result is in cm^3
Jun 26, 2014 | Office Equipment & Supplies
Only 5 of 8 brain burn athena
Hi THERE, This model is now discontinued.
The replacement is DUP-DP-AS3-11B.
*NOTE: Item is not compatible with LG GH22LS30 (Directron part number DVR-GH22LS30)
Now you can easily build a Blu-ray duplicator with the Athena SATA Blu-ray controller. SATA interface simplifies cable management comparing to IDE with narrower cables and smaller connectors. SATA interface supports cables as long as 90cm without sacrificing data integrity and system reliability. Hence Athena SATA controller can be installed on the top drive bay even in an 11-target tower duplicator. Maximize your productivity and efficiency today with Athena SATA Blu-ray controller.
Features:
  • Standalone, no PC required.
  • DDR2 Technology allows up to 8x Blu-ray duplication.
  • SATA Advantages - Thin cables for easy routing and improved cooling inside the duplicator chassis, increasing product reliability.
  • Dynamic Hard Drive Partitioning automatically adjusts hard drive partitions based on the size of your master disc.
  • Master Error Proof prevents duplication failures caused by disc errors. Simply exchange the failed master disc with a working disc without interrupting the duplication process.
  • Dual-Level Security provides separate Startup and Setup passwords for complete restriction and protection against unauthorized users.
  • Advanced Diagnosis Mode troubleshoots and sets adjustment for optimal performance.
BACK TO TOP
Specifications:
  • Operating Type: Controller only
  • Internal Interface: SATA
  • Targets: 11
  • Reading Speed: 18x DVD-ROM
  • Maximum Writing Speed* (*Actual write speed depends upon media and drive specifications) : BD-R SL: 8X BD-R DL: 4X BD-RE SL: 2X BD-RE DL: 2X DVD+RW: 8X DVD-R: 20X DVD-RW: 6X DVD+R: 20X DVD+R DL: 8X DVD-R DL: 8X CD-RW: 32X CD-R: 48X
  • Supported Disc Formats: BD ROM, BD-R, BD-R DL, BD-RE, BD-RE DL, DVD ROM, DVD-R, DVD-RW, DVD+R, DVD+RW, CD-DA, CD ROM, CD-R, CD-RW, Multi-session Photo CD, CD-I, Video CD, CD ROM XA, & CD Extra (CD Plus)
  • Supported Recording Discs: 12cm 25GB BD-R 12cm 25GB BD-RE 12cm 50GB BD-R DL 12cm 50GB BD-RE DL 12cm 4.7GB DVD-R/RW 12cm 4.7GB DVD+R/RW 12cm 8.5GB DVD+R DL 12cm 8.5GB DVD-R DL 12cm 80min / 700MB CD-R 12cm 74min / 650MB CD-RW 8cm 1.47GB mini DVD-R 8cm 24min / 210MB mini CD-R 8cm 50MB Business Card CD-R
  • System Buffer: 128 MB (Optional upgrade to 512 MB)
  • Hard Drive Supported: Up to 1TB (optional)
  • Power Adapter: Input: 100 ~ 240V AC Output: +5V DC, 3.8A
  • Operating Temperature: 40oF ~ 95oF
  • Operating Humidity: 20% ~ 90%
  • Regulation: FCC, CE, RoHS
Aug 27, 2011 | Athena SATA CD/DVD/Blu Ray Duplicator...
1.the ratio of the corresponding sides of two similar traingle is 3:2 what is the ratio of there height 2.the ratio of the corresponding sides of two similar traingle is 5:9 what is the ratio of...
1. the ratio of there height is 3:2
2. the ratio of areas of the triangle is: 125:6561
3. the perimeter of smaller parallelogram is: 40 cm2
4. THe real length of the object is 7 cm
Jan 21, 2011 | Dell Computers & Internet
What is the area of the triangle if its sides are 8cm., 17cm.&15cm.
Hello
OK, the formula for the Area of a triangle is A=0.5xBasexHight. For this formula to be applicable you will need to have a 90 degree angle in this triangle.
For example:
Base = 8
Hight = 15
A = 0.5x8x15
Let me know if you need any further assistance.
Kind regards
Andrea
Nov 20, 2010 | Health & Beauty
Menu display intermitent
display is disclosed which produces multiple visual displays in an intermittent manner which includes a display housing having a perimeter wall which is transparent during visual display and is an opaque mirror between visual displays. The perimeter wall of the display housing is a composite structure which preferably includes a transparent cylindrical substrate which is coated with an optical film and an opaque mask which defines display windows. Multiple visual displays are produced by a rotating display base which carries rows of rotating display elements. Preferably, the display elements are elongated triangular elements having three image faces which bear images which create the visual displays. The triangular display elements are arranged in a triangular configuration wherein the rows intersect one another at acute angles and are carried by the rotating base. The rotating base includes three display positions and each of the triangular elements includes three display positions. A stationary observer would see nine different visual displays and may see themselves mirrored in between and during the changes of visual displays. The perimeter wall of the display housing becomes transparent as the triangular display elements are backlit along their entire length by elongated fluorescent or neon light tubes. When the light tubes are off, the cylindrical display housing is an opaque mirror, preferably, about its entire periphery and height. Other embodiments of the invention include a single row of triangular display elements, and a rotating display base which includes display faces consisting of only a single display element.
Feb 25, 2008 | Solarism LM-1730 (Black) 17 in. Flat Panel...
Computers & Internet Logo
53 people viewed this question
Alun Cox
David Payne
David Payne
