Question about Electrolux Central Vacuum
Suction is low, but bucket is not full and filter is relatively clean
  • 694 Answers
The filter may be relatively clean, but if there's a lot of fined dust in your area the pores of the filter will fill and clog fairly quickly. Try replacing the filter and see what happens. If you don't have a spare, consider purchasing one for use while the other is drying out. Then alternate.
A leaky hose could also cause a loss of suction, as could a broke or cracked flex tube (the short piece in the power head).
Posted on Sep 22, 2010
Centralux
Low suction is either a clogged pipeline (very rare), a broken or open inlet valve in the system, a clogged hose or wand system, a clogged washable filter, the small screen behind the filter when removed needs cleaned, or the motor itself. Would need more detailed info. to pinpoint but hope it helped!
May 31, 2014 | Electrolux Vacuums
Low suction
We have one of these a few years old without the ball, pull out and see what suction is like with just the hose and the attachment for it, am I wrong and it (yours ) does not have the pull up and out hose? low suction is almost always a blockage in the air path between motor and cannister.
Dec 13, 2012 | Dyson DC25 All Floors Bagless Upright...
I have a Dyson dc21 ... it has low suction... never happened before approx 4 years old
try completely cleaning it out and clean the filter or get a new one. sometimes when my vaccuum has low suction theres dirt clogged in the hose or the vaccuum itself. try cleaning it out and if that doesnt work try and see if the settings are messed with (if there are different settings of course)
May 23, 2011 | Vacuums
It's blowing dirt out the bottom/back
this is caused by a plugged up suction hose AND / OR a dirty filter.
clean the filter - and remove the bottom floor plate and clean out the hose where it bends down to the floor unit ( this is always where the dirt collects when the filter gets dirty and suction is low ).
c...
Feb 22, 2011 | Bissell 6594 PowerForce Bagless Upright...
I have a Hoover Wind Tunnel Self propelled 12amp. There seems to be very little suction. I have cleaned the hoses and filters but still not much suction. any ideas? thanks.
Make sure all filters are cleaned out and entry ways are clear of all debris. Remove hose and check for blockage. Usually the low suction can be remedied when all filters are cleaned. Hope this works for you.
Jul 17, 2010 | Hoover Self-Propelled WindTunnel Bagless...
Is there a second filter
You have not posted a brand, however central vacs with an internal hanging `self cleaning ` filter seldom contain another filter with the exception of Eureka or Kenmore which may have a secondary optional paper filter installed. Check the bucket and the gasket first. Eureka and Kenmore made by Eureka are prone to a defective gasket which disintegrates with wear. The bucket should sit snug on any unit with no play.
To test for proper suction check at the vac intake itself. If the suction is strong here and weak elsewhere your problem will be either a clogged vac line, a leak in a pipe or an inlet door sagging open, last of all a clogged or partly clogged hose.
Check your hose by dropping a coin through the handle and shaking it down to the other end. If a coin makes it through your hose is clear.
You can test each inlet with a numbered tissue and your hose. Mark one for each inlet and check the tank to see what made it through. If any fail to make it through, go to that inlet with another vac and draw the blockage backwards out the inlet. Then retest
Also listen for a hiss at each inlet with the hose plugged in elsewhere. The hiss indicates a leak behind the inlet in the wall. Check for worn seals or misaligned o rings in the backing plate where the inlet connects.
Last of all inspect the pie for possible cracks from impact . If you listen closely you will hear an audible echo along the pipe path (even within the wall) if a connection has separated or a pipe is damaged.
Please post back with what you find or if you need more help.
Oct 13, 2009 | Vacuums
No Suction + loud Noise
motor is probably is full of dust or needs replacing
May 11, 2009 | Vacuums
Bissell 2x steam cleaner
Usually when it won't pick up water is because the bucket isn't seating all of the way down. Or there is a window gasket or seal, it goes bertween the clear window and the bucket, if it is missing, yiu get no suction thru that clear window. The other is on the one side of the lid for the bucket is a filter, is it clean? And the seal that that filter sits on, is it sealing? If the moror is running, it is sucking, but any leak will cause it to loose that suction.
Aug 30, 2007 | Bissell 1697-7 Powersteamer Pro Deluxe...
Vacuums Logo
105 people viewed this question
Top Electrolux Vacuums Experts
Marvin
Marvin
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
