Question about Samsung Digimax L730 Digital Camera
Lens won't open or pop out...charged all night long. should I take it to a local camera repair shop?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Samsung Master
  • 102,366 Answers
Posted on Feb 11, 2013
5 Suggested Answers
  • 6 Answers
SOURCE: my brand new kodak m340 won't stay on. the lens
I had the same problem after a day at the beach. What I did was get a can of compressed air (from the computer section) and blow air around the lens as I repeatedly turned it on. It took about five cycles, but I eventually cleared whatever was preventing the lens from fully opening.
Good luck.
Posted on Sep 28, 2009
t00nz
  • 4738 Answers
SOURCE: lens error, restart camera
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Posted on Oct 13, 2009
Testimonial: "Thanks."
  • 11967 Answers
SOURCE: I dropped my camera and the lens has tilted. My
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 08, 2010
Testimonial: "fantastic ideas and I will let you know how it works out thank you"
lock123
  • 6831 Answers
SOURCE: Panasonic Lumix DMC -FH20 lens
Hello
Thank you for using FIXYA!!!
This is a suggestion. If you do not feel comfortable trying it, you will need to take the unit to your nearest service centre. Feel free to let me know if you need any assistance.
The problem might be that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair centre for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance. Also, please be so kind to let me know if you found this helpful.
Regards
Andrea
Posted on Aug 15, 2011
Nikon coolpix s70 has blurry pictures even after resetting to default settings. Camera has not been damaged or dropped.
Hi you have lens unit defective. Even if you didn't damaged and dropped, its appearance problem is the lens unit, you can bring to your local repair shop. It is quite easy problem. some point they could save part, but time is money. they would want to change the part. your part from nikon usa is very expensive, but from ebay it is very cheap. It is used but it would be reliable in most case. http://cgi.ebay.com/Camera-LENS-ZOOM-UNIT-Nikon-Coolpix-S70-BLACK-/180672085419?pt=Digital_Camera_Accessories&hash=item2a10e53dab#ht_500wt_1156 If you buy and bring it with camera to your local repair shop, they would charge less labor then you bring camera only. repair shop would consider that you know what it is going on. Thanks and kindly! ( labor they would charge around $25 to 75 depend on what they want to charge)
Jun 02, 2011 | Nikon COOLPIX S70 Digital Camera
Cannot open my digital coolpixs5 lens cover error
Hi your camera just lens cover problem? it could be very simple. your local repair shop would charge around $35 to 85 depend on what they really want to charge. Thanks and best regard!
May 24, 2011 | Cameras
Dropped my canon power shot SD1400is and it will not turn on is it fixable
Here is a tip that I wrote about How toget a Digital Camera Lens to work again
Steps toRepair a Digital Camera Lens
heatman101
Lens error, restart camera....the lens cover is stuck slightly open. I have tried all suggested methods. Is there anthing else?
hi
if you see lens error on back of lcd and lens barrel is stuck, then your camera would need replacement of zoom control gears or a whole lens unit. Either way your local repair shop would charge you almost same cost depend on time consume. the cost would be around $75 to 135 depend on what they realy want to charge.
May 23, 2011 | Canon PowerShot SX100 IS Digital Camera
I turned off my camera (Canon powershot G9). After 2 seconds i turned it back on the lens popped out but the camera wouldnt turn on. Now the lens is still popped out, wont go back in. I tried recharging...
hi would you tell me more about condition? does it power on, do you see back of lcd any message, if power on, then you have lens unit is defective. no power at all, then you have either power control pcd(dc/dc convoertor) or main pcb. If main fail, then you have to send canon factory. but lens unit or power pcb problem can solve in your local repair shop. They would chage you around $65 to 165 depend on what they really want to charge. Thanks and best regard!
May 23, 2011 | Canon PowerShot G9 Digital Camera
My Panasonic Lumix DMC TZ3 has two small scratches on the centre of the lens. Can it be repaired and is it cost effective? Otherwise the camera functions perfectly. Is it better to purchase a later model?
hi does it affect to picture? If it big scratch, it will. But most of case it won't affect on your picture. However it does, try magic black ink on scratch.( non gloss black ink) it will help a lot. Thanks and best regard! If you really want to change, your local repair shop would charge around $85 to 135 depend on what they really want to charge.
May 22, 2011 | Panasonic Lumix DMC-TZ3 Digital Camera
There is caution that lens error.will shut down automatically,restart camera
hi if your lens looks bad like crooked, then you have to send to canon. They don't sell lens unit to local repair shop. but not serious problem (lens repairable) then bring to local repair shop. canon will charge you about $135, local repair shop would charge you $65 Thanks and good luck with you!
May 21, 2011 | Canon PowerShot SD1300 IS IXUS 105...
Lens will not retract and battery charging light does not come on
The lens barrel stuck up or mechanical gears problem this is repairable .
You take the camera to local service man to repair .
You can also repair but at times you may damage . So take to repair shop.
Thanks for using Fixya
SAM ANDERSON
Sep 18, 2008 | Kodak EasyShare M853 Digital Camera
Lens Cover Won't Open
NO Super glue this can be fixed pretty easily to get fixed. most local shops will not charge you to much to fix it maybe 15 to 20 at the most i figure. or you can remove the lens cover by putting a very small flat head screw driver on the side of the lens and with the camera off pull away from the camera and it should just pop off. Superglue if you get it on the lens will rune the whole thing. Just tiring to help out . I repair lens shutters all the time they are just mechanical parts nothing really special about them.
Apr 16, 2008 | Panasonic Lumix DMC-FX9 Digital Camera
Samsung Digimax L730 Digital Camera Logo
27 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
