Question about Car Audio & Video
After instal of JVC KD-R610, the words 'protect' flashes, and I'm not sure what i've done wrong. Wires match, connections are good, i tried the rest...???
    Genius:
  • 1,066 Answers
This usually happens when there is a short in the speaker wiring (wires crossed) or when you have too many speakers hooked up. rule out these factors.
Posted on Aug 06, 2010
My jvc kd-r520 will not turn on. It's as if
make sure the fuse in the fuse box is good then check the relay to the radio is good ( factory relay ) if all thats ok, check the fuse on the backside of the head unit.....
then while the head unit is out check the wires to make sure a mouse did not bite any wires...
Feb 24, 2012 | JVC Car Audio & Video
I can not get my jvc kd-r610 on fm radio. lost the manual. help
You can download the manual from the manufacturer's web site at
http://books.jvc.com/booklist.asp?Model=kd-r610
Aug 20, 2011 | JVC AM FM CD DET FACE CAR STEREO
I have a 1991 buick regal limited. took out the stock radio and cassette player and put a jvc kd-r610 in its place. hooked all the wires up,grounded it,and it doesnt turn on
Double check that the wires are connected properly. Also verify that all of the leads are operating as they should with a multimeter. If you used a harness adapter verify both before and after the adapter.
Mar 15, 2011 | JVC AM FM CD DET FACE CAR STEREO
Installing Jvc KD-R610 into 02 Nissan Frontier, where I have removed older JVC. Using old harness, but blue wire labels do not match... One says "amp power" and other says "power...
well it sound like your ground wire is not connected the properly way this wire is black make sure
the other 3 are connect right are Yellow is constant power ,Red is acc.ingnition,Blue is the remote.
that would complite your conection done.
Dec 27, 2010 | JVC AM FM CD DET FACE CAR STEREO
JVC KD-R610 is stuck in Protect mode
Try disconnecting your battery, reconnecting it, and resetting your stereo. If that doesn't work, the constant power (yellow wire) or ignition wire (red wire) may have come in contact with ground or isn't properly connected. Make sure everything is connected properly and try resetting your stereo. If it is still flashing "protect", the unit needs servicing Contact JVC Customer Care Center at: 800-252-5722.
Jul 22, 2010 | JVC AM FM CD DET FACE CAR STEREO
1994 toyota pickup - trying to install a jvc car stereo - all wires match up, clock will come on for a moment and then turn off. no sound either.
First of all have you tried to check the set before installing. If not test this once again. please take care to see if the main power , the standby power and the ground is given right and into the right path. make sure that the ground is taken correct. once this is right , your set must work. switch off and then you can connect the speakers. Hope this helps. good day
Jul 06, 2010 | JVC KD-S550 CD Player
Wired and Installed a jvc KD-R610 deck in my 95 mustang and deck will not turn on
You should verify your wiring .Also check all fuses. that is on the radio and for the power wire (red) .
May 12, 2010 | Car Audio & Video
Need to wire JVC model KD-G340 into a 97 Kia Sephia
Do not cut the wires from the car. Instead, call Crutchfield at 888-955-6000 and order the adapter part number 120701003. When you call them, ask for color coding. For JVC, refer to the attached picture. Match the adapter color code with that of JVC. If the adapter color code is the same, then connect ground (black), battery (yellow), and wire from ignition switch (red) securely. Turn on the car and see the radio works. If it works, connect one by one speakers and confirm. Remember, perfect connection gives reliable installation.
Nov 22, 2009 | JVC KD-G340 Car CD/ MP3 Player
My JVC KD-SX650
get a good service manual for your car that shows the wiring for the stereo plug. match up the wires to your JVC's wires (solder tie wire-to-wire behind the car's connector)
May 26, 2007 | JVC KD-SX650 CD Player
Car Audio & Video Logo
245 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
