Question about Garden
I have a Genie garage door opener when i press the switch the door goes up but I won't come down can you help?
  • 144 Answers
There are codes on the back of the opener unit. One set is for going up and one set is for going down. Both sets on the back of the unit must match your opener or the frequencies will not open and close your door.
Posted on Aug 06, 2010
Re-engage carriage on genie garage door opener
good morning Anonymous.
Usually there is a hand-switch where the arm from the door connects to the Drivescrew. It will often have a cord hanging down that you can pull to disengage the arm from the screw. It's there so that you can manually move your door if the power goes out. If the drivescrew spins and nothing moves, then you probably need to get on a stepstool and click the lever back up to re-engage with the screw. Good Luck!
Feb 16, 2015 | Genie Company Genie Garage Door Opener...
Why won't my Genie garage door opener close without going back up.
So it seems the Main garage door unit on the ceiling is ok. The problem is with hand held unit. Usually the circuitry is ok. Try changing the battery. It has helped me. Also make sure the sensor on ceiling unit is not blocked ad is free of cobwebs.
Jun 26, 2013 | Genie Company Garage Door Parts Genie Gwkp...
Genie H4000A manual
The garage door will only go down by holding the button on the wall switch
Aug 30, 2012 | Sears Genie Garage Door Gpwk12 Wireless...
My friend has a bad Genie garage door opener down limit switch (Door goes down and right back up again). Limit switch is made by Tane with part No.'s on it: FM-102BR-138 and 33969B. Would Limit Switch...
This is the close limit sensor so yes it should work. They have them for $2.40 right now from an Amazon vendor - http://www.amazon.com/Genie-Excelerator-Close-Switch-33950S/dp/B00283OBXY/ref=?ie=UTF8&m=A1CTO3U79X1RZ3
You can also buy replacement sensors as a 10 pack in case you end up needing more from here -
http://dpcdist.com/flangemountcontactandmagnetendleads.aspx
Sep 16, 2011 | Genie Company Genie Excelerator Down Limit...
I want to program my Genie ecellerator isd 1000 so that I can use my Homelink system in my car and my wife can continue to use her Genie remote that came with the opener. How can i do this? Thanks
Inside the car press the 2 outer buttons on the homelink until the led light by it goes out or flashes rapidly. This erases all old/factory codes. Hold the remote 1" from the button you want to program and press the button on the remote and the homelink button until it flashes rapidly. Then press the learn button on the motor head and then press the button on the homelink you pressed before 4 times and this should code in. Thanks BB
Aug 21, 2010 | Sears Genie Garage Door Gpwk12 Wireless...
Garage Door stuck open
IT COULD BE THE SAFETY EYES.
ARE THEY ALIGNED? BOTH LED'S LIT?
YOU MAY HAVE A CABLE OFF OR BENT TRACK.
IS THE SENSITIVITY SET TOO LIGHT?
IF YOU CAN'T SEE A PROBLEM, I WOULD CONSIDER CALLING A PRO THEY CAN NORMALLY FIX A MINOR PROBLEM FOR UNDER $ 100.00. CALL THEM. GIVE THEM A DESCRIPTION OF YOUR PROBLEM. ANSWER A FEW QUESTIONS FOR THEM AND GET A PHONE QUOTE
HOPE THIS HELPS
Dec 24, 2009 | Genie Company Genie Excelerator Down Limit...
Genie garage door won't shut. the down limit switch wire (brown) got caught and I had to reconnect...stripped and twisted wires (just the brown down switch wire) together ... door still won't shut , it...
You don't say which model you have, however, MOST Genie systems use the switches as temporary contacts. By twisting them together, the computer board is reading it as a short. You need to replace the switch and route the wires properly.
Nov 21, 2009 | Genie Company Genie Excelerator Down Limit...
Genie garage door openner won't stop when it goes down or up
there should be a "travel distance" adjustment screw on the opener.
Apr 20, 2009 | Sears Craftsman LiftMaster Chamberlain...
Programming the garage door opener
Homelink Garage Door Opener Programming Procedure:
The procedure described below was successfully applied to a 2005 Jaguar S-Type.
To begin with, several attempts were made using the programming instructions contained in my Jaguars owners manual. Though the procedure described in the owners manual was straight-forward and understandable, I was unsuccessful in getting the vehicles remote to make my garage door opener function. The particular garage door openers I have are both made by Genie. Both openers utilize the Rolling Code feature.
To begin with, be sure to clear previous codes on your Jaguars garage door opener by first turning (rotating) the ignition key to the I position (first notch). Next, simultaneously hold button 1 (left most button) and button 3 (right most button) down until the middle buttons red light changes from continuous on to a rapid flash. This process takes approximately 20-25 seconds. What follows is a two part process. In the first part, get your Genie portable remote and hold it near (approximately 3 inches away from) your Jaguars garage door opener console buttons. Choose which button on your Jaguars remote you wish to dedicate to your Genie door opener and simultaneously press and hold your Genie opener button and your Jaguars opener button. The red light on your Jaguars center button (button #2) will light up and within 1-2 seconds will begin to flash rapidly. You have just completed part 1 of the two part process.
Part two: Now it is time to utilize the Learn function on your Genie garage door opener. Press the Learn button on your Genie garage door opener. The red LED adjacent to the Learn button will begin to flash. You now have 30 seconds in which to program your Jaguars opener button. Using the same button you just used in the part 1 procedure, press and hold the same button for several seconds. As before, your Jaguars red light in the middle button will light up and within 1-2 seconds, it will flash rapidly. Release the button you are programming. Now, here is the key piece of information! Once again, press and hold that same button. Once again, the center buttons red light will flash rapidly. Release your newly programmed button. This procedure proved successful in my application. Here is what has just happened. The first time you pressed your Jaguars remote button tells the Genie opener that it exists and that it is a viable candidate for making your life easier (opening the damn door). The second time you press your Jaguars remote button confirms to the Genies rolling code that your Jaguars signal is legitimate and is to be trusted from then on.
Jun 06, 2008 | 2003 Jaguar XJ-Series
Garden Logo
158 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
Marvin
Marvin
