Question about Whirlpool MH7140XF Microwave Oven
The front door of the microwave is cracked. The microwave seems to work fine. This is for a rental unit, so I do not have immediate access to the unit. Do you have the dimensions for model # mh714oxfq-1
3 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: The door handle cracked from the door. The unit
Or, if the handle itself is the only piece damaged, you can simply replace the door handle.
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The panel is pressed in place and can be removed by using a small screwdriver or putty knife and carefully insert along the seam of the inner panel to pry the plastic up. Work your way slowly around the perimeter of the glass to pop the panel loose. Use care not to pry against the glass. The glass is tempered and also has an RF shield that shields you from harmful RF radiation.
With the inner panel removed, the door handle screws are visibile and can easily be accessed with a screwdriver. Simply remove the broken handle and install the new one. Re-insert the inner door panel, gradually working your way around the perimeter of the door glass to ensure it snaps back into place and seats properly.
This repair can be done with the door in place, or you can remove it for easier access. If you decide the remove the door, open it all the way and lift straight up at the hinges. The door will lift off of the hinge pins. On some microwaves, you may have to remove the upper grill cover over the door (if equipped) to accommodate door removal. Place on a hard flat surface with some towels under it for padding. This protects the door facing from scatches.
NOTE: Some doors have a hinge pin that needs to be removed, or screws holding the door in place at the hinge.
You can view an exploded view diagram of your microwave at any of the following websites for reference: searspartsdirect.com pcappliancerepair.com appliancepartspros.com Just type in your model number and locate the parts listing for the door. If you have any questions, or require additional assistance, please let me know. I hope this helps you.
Posted on Dec 23, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: microwave will not turn on -- light does not come
Chances are good that you have a bad door switch.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on May 28, 2010
Anyone perhaps know why my LG microwave LMV1683ST will not function with a new door assembly?
I hate to be the bearer or conduit of bad news, but IF the old (broken) door works, but the new door does not, the new door may not be the exact replacement part! Otherwise, the operation would be identical. Clearly, the problem is not with the microwave circuits because they work fine with the original door! Is there a flexible circuit strip that plugs to or from the door, to the control board in the main unit? If so, does it look any different than the original counterpart to it?
Apr 18, 2017 | LG Microwave Ovens
My nn-s963bf starts operating when door is opened
The electronics have lost their marbles. When a nuker door is opened the safety switch connected to the door is designed to turn the unit off and not on. You just better work fast when you put stuff in or take it out!!!!!!!
Nov 24, 2013 | Panasonic NN-S963BF Microwave Oven
My sharp carousel microwave only works when I depress the door knob halfway down. What could be wrong ?
All microwaves have a safety lever or switch that prevents the unit from working if door is not closed all the way. Most of them you have to take the unit apart as access to it is from inside--what happens is when door is closed the latch or door moves the lever--seen a number where lever is loose or even the holder for it cracked.
Most shops are familiar with this and it should if the problem not be a real expensive repair.
Jun 16, 2012 | Sharp Carousel R530EST Microwave Oven
Microwave will not turn on -- light does not come
May 22, 2010 | Whirlpool RMC275PD Microwave Oven
Everything else seems to work fine but when I take
Magnatron has failed, possible internal fuse to the Magnatron,or the Magnatron itself has gone bad.
Both are replaceable, but the microwave will have to be taken down to gain access to these parts to be serviced.
Now, depending on the age of the unit, it may not be wise to invest the cost for this repair, unless, is it still under the manufactures 1 year warranty or did you purchase an extended service contract on this unit?
Good Luck !
May 02, 2010 | Maytag MMV4205 Microwave Oven
Clarification on microwave "cover" access
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101-=-=]
Apr 26, 2010 | GE JVM1440 Microwave Oven
Faceplate of door by lower L/H hinge cracked. How do I remove the door to replace the Faceplate?
Front doors are attached inside the microwave at the top and bottom of the oven cavity. Top case has to come off using, likely, security torx screw drivers.
Remove the top hinge.
Remove the bottom hinge.
Door falls off.
Replace the front panel of the door.
Reinsert the lower hinge with the door, close and latch the door.
Holding the door firmly to the microwave, tighten the door hinge. Replace the top hinge.
(On some units, both hinges need to be installed at the same time. Use masking tape to hold the lower hinge - makes it easier.)
Apr 19, 2010 | Sharp R-1490 Microwave Oven
Microwave oven only operates if the door is held closed
If the microwave oven operates with the door open it is a serious issue. DO NOT OPERATE IT. Call a technician immediately. The RF frequency is extremely dangerous. the safety switches inside the oven are malfunctioning and needs to be replaced
Jul 03, 2009 | Microwave Ovens
How to change the handle
To access the door handle mounting screws, you have to remove the inner door panel that goes around the perimeter of the glass. You can use a small screwdriver to simply pry the plastic up and work your way gradually around the perimiter of the glass. Most microwave ovens have grooves in the panel that you can insert the screwdriver into. Use care not to pry against the glass. The glass is tempered and also has an RF shield that prevents harmful microwaves from potentially harming the consumer. If you break the glass, you will need to purchase a new door.
The door handle screws are located behind the inner panel. Simply remove the broken handle and install the new one. Re-insert the inner door panel carefully and gradually work your way around the perimeter of the door glass and make sure it snaps back into place.
If you have questions, please let me know. I hope you find this information helpful.
May 14, 2009 | Kenmore 62702 Microwave Oven
Daewoo microwave that won't cook
More than likely a door switch inside the unit is misalligned or faulty. Crack it open and check for proper allignment and good open/closed circuits with a VOM.
Sep 24, 2008 | Daewoo Microwave Ovens
Whirlpool MH7140XF Microwave Oven Logo
62 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
