Question about Minn Kota Mk1DC Single Bank DC Alternator Charger
I installed a minn kata mk-1-dc charger it was working for a week and now does not charge I have a green power light with engine running but no battery charging light
2 Suggested Answers
emissionwiz
  • 81400 Answers
SOURCE: my mk-315 3 bank on
we do nnot have a manual for this, but the lights indicate a defective battery.
Posted on Oct 07, 2010
Why does the red indicator light stay on when I connect to the battery?
That battery may be completely toast, Jacob. Or... it might just be the silly "smart" electronics - an old-style basic battery charger may be able to recover that battery.
Aug 12, 2014 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Batteries 1 and 2 will charge fully, but battery 3 will not fully charge
By reading this.. I am assuming #3 is the crank battery....
Try this.. (from experience) remove all wires (or big terminals) from the battery and see how that works.. I have a 3 bank and use a stand alone charger!! Works BETTER!!!
Mar 21, 2014 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
I have a Minn Kota MK 460 on board charger that the number 1 red light is on and it is not charging that battery. When you hook up to the other 2 batteries the light still continues to stay on. I had the...
is this a 3 or 4 bank charger I had the same problem but my battery was bad if you don't have the charger on the battery it goes to you will have a red light if your battery are hooked in series to check your charger disconnect the cross over wire and put charger on battery see if red light goes out if so you have charger on wrong battery or you have a bad temp.sencer in charger cord on # 1 feed
Sep 26, 2013 | Boating
Minn Kota mk25 light will not move from yellow to green. I have moved the connections from one battery to another. I replaced a dead starter battery, and my trolling battery tested out at 100%. what could...
Do you remove the trolling motor wires before charging..? ...If not.. try that......mine started taking a LONG time to charge.. after I remove the trolling motor cables.. it take less time and charges better!!!
Feb 25, 2013 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Hello, I have a Minn Kota 440 4 Bank Charger. I recently heard it spark when I plugged into my 115V AC power source. Since then I have no charging light indicator and no actual charging occuring. I tried...
Hello Brad / Colee
The voltage converter in the charger has gone out (violently). Do not use this charger in your craft anymore. There is no longer any kind of guarantee of isolation, and galvanic corrosion may be accelerated if the boat is sitting in the water and you try to charge batteries.
Replace the charger. Your craft and your lives aren't worth the risk. You can try contacting Minn Kota to see if there might be some kind of warranty assistance.
Aug 29, 2010 | Garmin Minn Kota MK 440 On-Board Charger...
ONLY THE check connection light comes on. There is
I am having the same issue with My Mk 210 charger and have tried contacting Minn Kota two times for help? Have you had any luck finding the solution ?
Jul 27, 2010 | Garmin Minn Kota MK 440 On-Board Charger...
Wiring diagram for a minn kota mk220 2 bank charger
First. the +/positive/hot wires go to the respective/separate +positive/hot side battery terminals.. and the -/negative/ground wire go to their respective/separate -/negative/ground battery terminals.
The wires from the charger are "paired out".. meaning the + and - pair must go to the same battery. .. you can't mix and match.
Feb 27, 2009 | Johnson Minn Kota Mk 25 & Mk 35 On Board...
Minn Kota Mk1DC Single Bank DC Alternator Charger Logo
Top Minn Kota Boating Experts
Mike Marcotte
Mike Marcotte
Andrew Taylor
Andrew Taylor
Colin Stickland
Colin Stickland
Are you a Minn Kota Boating Expert? Answer questions, earn points and help others
